Black Hole Vu+ Ultimo 1.7.7 HbbTv
lorenzo64
Black Hole 1.7.7 HbbTv
  • What is HBBTV?
    HBBTV is a pan-European specification for interactive TV applications with its roll-out in Germany, France and more countries are now following. HBBTV has been developed in order to fulfil the needs of seeking ways to deliver interactive services through a single web-based user interface. The fundamental goal is to create open standards providing the seamless TV experience to customers.
  • Note for Vu+ Ultimo and Vu+ Uno boxes:
    Remeber to upgrade the firmware to the version 4.5 before you install Black Hole 1.7.7
  • Note HbbTv:
    To access HbbTv functions: Short press red button / Long press blue button
  • Warning Parallel Universes:
    Bh parallel universe panel has been moved to: Long press red button
  • What is new ?
  • Vu+ dvb drivers updated to 20120824
  • Vu+ OE updated to 20120830
  • Vu+ Enigma2 updated to 20120830
  • Army skin Transparency-HD updated for HbbTv
  • [librtmp] fix build bug
  • Enigma2-defaultservices : update default services
  • Opera hbbtv:
    - upgrade libdvbsi++ package.
    - include hbbtv plugin.
    - packaging opera-hbbtv binutil.
  • Fix libpcsclite build
  • RemoteControlCode : support for all models except duo/solo.
  • [firmware upgrade] fix fimrware data filename.
  • Add opera browser.(with hbbtv)
    - handle error for forbidden stream.
    - activate red button.(ready for ait..)
  • keymap.xml: Red button remapped: short = hbbtv, long = parallel universes
  • BhEi: fix satellite name and position in osd (thx Sato)
  • Add filesystem choice to usb format wizard
  • Remove Vu+ Device Manager, using Bh device panel instead.
  • Set platform profile and check HbbTv application version.
  • HbbTv: fix bug of setting orgid.
  • Fix lamedb.192.
  • [hbbtv] fix bugs.
    - add platform profile.
    - add application version.
    - notify error for failed to load.
WARNING: This Image is not compatible with the previous skins
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-1.7.7-vuultimo_usb.zip
scoot1690
usual high standard as usual guy's thanks again for all the hard work and dedication simply the best image ever
nolan
Just tried the image. Works fine.
However some problems are left unresolved:
BITRATE plugin still doesn't work!
This works in every image except for Blackhole!
DVD BACKUP plugin still doesn't work.
After installing you can't find it anywhere!
It would be nice if these could be fixed.
And one other thing puzzles me.
In Blackhole you can't download any settingslists? At least I Can't find it anywhere.
regards, Nolan
angelofsky1980
BlackHole Driver Specialist
Thanks BH team.
Could we have Gradient and Mood skins for this new image;)
Army will update their skins ASAP :)
And how again You cam modules, such as Polsat cam
If you have that CAM module you can test directly and report if works or not.
Have you fixed the problem of reproduction. Avi files???
I've tested some Avi files and all works properly without freezes or other artifacts.
