Black Hole Vu+ Ultimo 1.7.7 rev. B
lorenzo64
Black Hole 1.7.7 rev. B
  • [hbbtv] add playback status.
  • [hbbtv] add volume control.
  • [hbbtv] add connection progress.
  • [hbbtv] fix stream player.
  • [hbbtv] fix status message.
  • [hbbtv] fix cpu load.
  • Delete invalid channel from userbouquet.favourites.tv.
WARNING: This Image is not compatible with the previous skins
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-1.7.7-vuultimo_usb.zip
DeLaGrooV
Can one do an online update with BH images.
I was testing 1.7.7 and wonder if online update to 1.7.7 b is possible
rocuelo
surfing on hbbtv in channels like ARD is still very slow.. the menu from hbbtv doesn't charge at all... :(
TUT
Can i backup my settings from BH 1.7.5 and then install them into BH 1.7.7 as i have a motorised settings and don't the hassle & time of going through the setup and scanning stas again
Thanks for the great work
angelofsky1980
BlackHole Driver Specialist
You can backup manually your settings with some utilities (DreamSet, Dreamboxedit) or use BH Personal Backup :)
TUT
Many thanks Angelofsky1980
I have 2 more questions please:
1- How to display the date along with the time on the VU+ Ultimo front LCD ( i have seen this on the VIX image)
2- How to enable automatic HDMI channel switching on the Ultimo like the rest of the HD devices i have (when i turn any of my HD device on, the TV automatically switch over to the correct HDMI input but it won't change automatically when I switch on the VU+ Ultimo and i have to switch to the TV correct HDMI input manually using the TV remote control)
Many Thanks
angelofsky1980
Many Thanks
1) it's a skin coding.
2) you should play and modify the options into HDMI-CEC plugin to optimize it.
TUT
thanks angel
I have tried all the settings in the HDMI-CEC plugin but could get it to work !! , Do you know what setting i should enable/disable in the HDMI-CEC plugin to enable automatic HDMI channel switching
>>Artorius<<
>>English Admin<<
Try a skin from the server by Matrix10
Norman
Update,tried new rev b 1.7.7, and open web if no longer works, did work fine on bh 1.7.6
Anyone else have openwebif working on latest bh 1.7.7 b
Problem sorted,i had internal IP Change[ unknown to me] that just put spanner in the works
Thankyou for looking
thijss
i do like this image went from 1.7.4.0 to 1.7.7 but my wifes eyesight isn't great so she finds it hard to read the writing on this skin.
Anyway of getting the skin of the 1.7.4 image on this one
Thanks for the work put into this image i hope the stream tv will get better and better;)
Mito
You can download several skins by our server.
Green Panel > Addons > Addons Download Manager > BH E2 Image Skins
