Black Hole Vu+ Ultimo 1.7.7 rev. B
You can download several skins by our server.
Green Panel > Addons > Addons Download Manager > BH E2 Image Skins
i often tried that but i always get "sorry connection failed" message
is there any i can manually install?from temp folder
Evidently your local network setup is ok, but there is a problem with internet connection.
i can connect to my tube and most of the streams no bother ,just not the black hole server.
Is there anything i can check or fix to make it work?
sorry now guys but one more thing wich other skin will work on the 1.7.7 image cause i tried a good few and sofar none are compatible
hello
is it possible to add rtmp streaming link in it and is it possible to edit whole file with ftp coz to add with remote but difficult,
and when i try rtmp link it always crach, any idea?
