Black Hole Vu+ Ultimo 1.7.8
INFO
All my skins for BH 1.7.7 you can use in the BH 1.7.8
No significant changes in skin coding.
On the server names of those skins , with BH 1.7.x in the name of the skin.
EXAMPLE :
EclipseHD BH1.7.X
INFO
EXAMPLE :
EclipseHD BH1.7.X
Nice image also mediaset epg display fixed:)Thanks.
INFO
EXAMPLE :
EclipseHD BH1.7.X
Could wish Army SmokeProHD was also comapible with 1.7.8 ... GREAT skin , I love it .
Maybe it could be coded in the next release :notworthy:
Thank You, although after inputing my location in Blackhole weather, it now greenscreens every single time you try and open it.
There is no option to change location, as it crashes on starting of BH Weather ;)
Changing channels and jumping between different providers is now greatly improved!!!
1 second change... Thank You
Black Hole Vu+ Ultimo 1.7.8 is great update,
I have RAM alomost full 98%, is this normal, i use swap 256 mb
is anybody have same issue?
Also i have suggestions:
kindly need to add these features:
edit settting of clock watch manuly
finding chaneel name by alphpet (put 1st letter of name)
restoring after upgrade BlackHole image not restore setting only, it restore old image and settings together,,need to fix it.
need to have deep standby.
Thanks a lot,
Eng. Badie
Saudi Arabia
1.finding chaneel name by alphpet (put 1st letter of name) You can
2.restoring after upgrade BlackHole image not restore setting only, it restore old image and settings together,,need to fix it.You can
3.deep standby ???
search forum for info
3.deep standby ???
hello
by pressing 1st letter it dosent go on that channel any idea?
3.deep standby ???
Thanks a lot,
1- finding chaneel by alphapet now works fine,
2- i belive deep stand by replaced by shutdown, is it correct?
3- (restoring after upgrade BlackHole image not restore settings only, it restore old image and settings together)
after search i found language which i don not understand!!! not in english,, kindly if you can send me link in english language.
4- Searching for RAM problem gave me this message(Keywords:
The search could not be completed because the search keywords were too short, too long, or too common.)
kindly if you can send me link.
My regards,
Eng Badie
Thanks a lot,
My regards,
Eng Badie
2.deep stand by = Shutdown
3.Backups in Main Menu
Option 1 BlackHole Full Backup (image backup)
Option 2 BlackHole Personal Backup (Partially backing up the user's configuration ,backup settings etc)
Option 3 Backup with Setup Menu >> Software managment
different options
1.Backup system settings /Restore system settings
2.Advanced Options
You can Choose backup files and folders with yellow button (select)
and Save with green
To be able to use the advanced options you must have in System Menu >> Customize
Setup Mode ................ Expert
after change if you do not have already Setup Mode Expert in Customize
restart box or restart Gui In Black Hole Shutdown Menu.
4. Ram
Someone use SWAP for RAM problems
I do not use because I do not have Ram problems
But I also not overload image with plugins, to much EPG etc.
Almost full RAM does not mean that you have always ram problem
Try to find on forum more information about Ram , Swap
There have been several discussions on this topic.
SWAP you have in
blue>blue>>Swap File Settings
Rgd MX
