Black Hole Vu+ Ultimo 2.1.1
lorenzo64
Black Hole 2.1.1
By Black Hole
  • New skin MX SkyLine SE
  • Add new Crypto systems in OSD: Biss, Bulcrypt, Betacrypt, PowerVu (By Ev0)
  • Add parental control in Bh extra settings panel
  • HbbTV enabled by default for Duo2, Solo2, SoloSE, Ultimo
  • Removed mytube plugin (can be installed from BhSpeedUp)
By Vu+
Kernel:
  • Update Kernel 3.13.5(solo2, duo2, solose)
  • Update Kernel 3.9.6(duo, solo, uno, ultimo)
Drivers:
20140715(duo, solo, duo2, solo2, solose)
20140716(uno, ultimo)
  • - Support SoloSE
  • - Switch to Kernel 3.13.5 (solo2, duo2, solose)
  • - Switch to Kernel 3.9.6 (duo, solo, uno, ultimo)
  • - Fix sound drop in radio channel
  • - Improve PIP (solo2, duo2, solose, Needs E2 update)
  • - Allocate more memory to linux (duo2)
  • - Improve media playback
20140721
  • - Fix vfd problem
Misc:
  • Update r8192cu (4.0.2)
  • Update bridge-utils (1.4 -> 1.5)
  • Set sync PCR at PIP mode.
  • fix duo harddisk detection
  • [hbbtv] fix UI position
  • [hbbtv] upgraded to 'opera-hbbtv_0.2.bb'
  • disabled copy libs to sysroot
  • [hbbtv] reduce CPU usage
  • [hbbtv] fix ipc protocol
  • [hbbtv] fix flickering some channel.
  • support seeking the recorded video
  • lcd4linux: update to 4.1-r2
WARNING! DO NOT USE PERSONAL BACKUP FROM PREVIOUS BLACK HOLE IMAGES, AS THIS WILL MIX KERNELS AND LIBS CAUSING MANY MALFUNCTIONS.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-2.1.1-vuultimo_usb.zip
superglud
BH Lover
1. "Hauppauge pctv nanostick t2 290e usb-tuner" is not detected by BH 2.1.1
( UsbTuner v0.3.14-BETA1 (Build using DVBAPI 5.10) )
reported in "Black Hole Usb Tuners Drivers" section
2. Rebooting Ultimo takes forever (after 20 minutes i gave up waiting)
3. Shutdown and new startup is working but is very slow
Fyi: fresh install, no backup is in use, i am setting all up from scratch
Best regards
helmy
Black Hole 2.1.1
By Black Hole
By Vu+
Kernel:
Drivers:
  • - Support SoloSE
20140721
  • - Fix vfd problem
Misc:
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
xfiler
Best regards
I have the same issue - after installing and then rebooting the system just sits there and nothing happens. Have to now re-install 2.1.0 as this release can't be used unfortunately. If you need something from me let me know and I'll try and send it on to assist with your debugging.
