Black Hole Vu+ Ultimo 2.1.5
Sorry sorry my mistake I sent wrong crash file !
The correct version is below !
The error is
global name 'getImageDistro' is not defined
  File "/usr/lib/enigma2/python/Components/ActionMap.py", line 46, in action
    res = self.actions[action]()
  File "/data/devel/blackholesdk/openvuplus/build/vuultimo/tmp/work/mips32el-oe-linux/enigma2-plugin-systemplugins-crossepg/enigma2-plugin-systemplugins-crossepg-0.8.1+gitr1+0c341c38fa4697ee524c9c98baf97c15ffad6e4d-r2-bh0/git/src/enigma2/python/crossepg_menu.py", line 154, in openSelected
  File "/data/devel/blackholesdk/openvuplus/build/vuultimo/tmp/work/mips32el-oe-linux/enigma2-plugin-systemplugins-crossepg/enigma2-plugin-systemplugins-crossepg-0.8.1+gitr1+0c341c38fa4697ee524c9c98baf97c15ffad6e4d-r2-bh0/git/src/enigma2/python/crossepg_menu.py", line 182, in downloader
  File "/usr/lib/enigma2/python/mytest.py", line 302, in openWithCallback
    dlg = self.open(screen, *arguments, **kwargs)
  File "/usr/lib/enigma2/python/mytest.py", line 312, in open
    dlg = self.current_dialog = self.instantiateDialog(screen, *arguments, **kwargs)
  File "/usr/lib/enigma2/python/mytest.py", line 247, in instantiateDialog
    return self.doInstantiateDialog(screen, arguments, kwargs, self.desktop)
  File "/usr/lib/enigma2/python/mytest.py", line 278, in doInstantiateDialog
    dlg.applySkin()
  File "/usr/lib/enigma2/python/Components/GUISkin.py", line 112, in applySkin
    self.createGUIScreen(self.instance, self.desktop)
  File "/usr/lib/enigma2/python/Components/GUISkin.py", line 30, in createGUIScreen
    if val.applySkin(desktop, self):
  File "/usr/lib/enigma2/python/Components/GUIComponent.py", line 39, in applySkin
    skin.applyAllAttributes(self.instance, desktop, self.skinAttributes, parent.scale)
  File "/usr/lib/enigma2/python/skin.py", line 308, in applyAllAttributes
    applySingleAttribute(guiObject, desktop, attrib, value, scale)
  File "/usr/lib/enigma2/python/skin.py", line 208, in applySingleAttribute
    ptr = loadPixmap(value, desktop) # this should already have been filename-resolved.
  File "/usr/lib/enigma2/python/skin.py", line 176, in loadPixmap
    raise SkinError("pixmap file %s not found!" % (path))
skin.SkinError: {MX_HQ3/skin.xml}: pixmap file /usr/share/enigma2/MX_HQ3/progress_c.png not found!
Have you tried with default skin?
@Matrix10 should help you.
The error is
    dlg.applySkin()
It's stable with skin I'm using now, but this afternoon, it was doing my head in thanks for for your reply !
hi what that means???
Please use software manager to backup your settings before you flash.
wich software manager I have to use??? and How to do it
thanks
thanks
Menu>>Setup>>Software managment>>system-backup
Save on HDD or USB
After installing the new image
System Restore in software management
In software management backuplocation you can choose (HDD, USB)
Guys use the search option on the forum
Some issues have certainly dozens if not hundreds of replies.
Black Hole 2.1.5
  • New: HQ 5 Full Hd Skin 1920x1080 (duo2, solo2, soloSe, uno, ultimo, zero)
  • New: OpenGL animations and Xbmc (duo2, solo2, soloSe)
  • All drivers updated
  • fix autoresolution plugin
  • [hbbtv] fix crash parsing xml
  • [hbbtv] fix VOD play problem
  • fix keymap bug
  • fix channel skip
  • change default resolution to 1920x1080 (only models with full hd skin)
  • update languages hr, it, no
  • meoboot: add support for OpenGL and Xbmc images
  • update Usbtuner
  • WIFI: update driver RTL8188EU
  • WIFI: update driver RTL8812AU
Warning: This image MUST BE INSTALLED IN FLASH.
Warning: Don't mix images with OpenGL animations and images without animations in multiboot because they use different drivers. If you have an OpenGL image in flash you can only use OpenGL images in Meoboot.
Warning: Previous personal backups are not compatible with this image. Please use software manager to backup your settings before you flash.
Known Issues: Xbmc External Player not working yet.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Save on HDD or USB
Thnans MATRIX, just one question more, this backup is total?? with ******* and bouquets?
EDIT ADMIN
Read the forum rules
We must make a difference between
problems caused by the image and those caused by the plugin.
Your problem is caused by a plugin.
So ask authors for FIX, TSmedia.plugin
Hi,
Makes perfect sense. Sorry - not a BlackHole issue - a plugin image. Will ask the authors to see what can be done.
Many thanks and keep up the good work.
Hi,
It is strange that the majority of users looking for image change
and not vice versa plugin change .
Strange multiple recording issue, never seen before
Despite no conflict when setting up multiple recordings, then often the actual recording, is not choosing a tuner, that makes the recording possible.
Resulting in corrupt recordings (0 minutes)
BH 2.1.5
Ultimo configuration:
Tuner A: Vuplus DVB-S NIM(AVL2108) (DVB-S2) - slot A
Tuner B: Vuplus DVB-S NIM(AVL2108) (DVB-S2) - slot B (loop from tuner A)
Tuner C: Vuplus DVB-S NIM(AVL6222) (DVB-S2) - slot C
Tuner D: Vuplus DVB-S NIM(AVL6222) (DVB-S2) - slot C ("internal loop" from tuner C)
2 feeds (A and C)
Best regards
