Black Hole Vu+ Ultimo 2.1.5
hi .when i flased the image all was good exepts the picture is blue ,isnt red like i saw in image. i mean the picture with letters vu black hole 2.1.5. how to change from blu to be red? thanks
Is just a bootlogo ( you only see this when the box turns on / off ... on booting ... on restarting enigma ... or shutdown ), but i tihnk you can find this on the feeds, blue, yellow, red and black ( via addons )!
can not restore personal backup and channel list
it says not compatable?????
any solution????
Restore the image you have maded ( backup one ) and with an tool settings manager ( dreamset 243 or dreamboxedit 6.0.1.2 ), download settings from your STB to a PC ).
Install your new BlackHole image, and with the same tool upload the settings to your STB.
Best regards
Nunigaia
Hello
Is it possible to get a recording to make a mark when commercials start and end ?
so you can just skip it afterwards, when you are playing the recordings :-)
Hello
so you can just skip it afterwards, when you are playing the recordings :)
You will need cutlisteditor and moviecut from the extensions plugins...
Once installed, highlight the movie you want to cut, and then press the menu button. There's an option in there to use the cutlisteditor. Go to the position where the movie starts, pause it, and then press the "OK" button. Then, select the "Remove before this position" or something like that. Then, go to the end position of the film, and pause again. Press the OK button, and choose the "Remove after this position". This will leave you with the movie left. Then, exit the cutlisteditor, choose the "Cut movie" or "Movie cut" (can't remember exact name). This will give you some options. I'd choose the "Cut this movie to a new file" or something along those lines. You can then check that it worked properly before deleting the cut, in case you didn't do it properly.
Note: Before proceed, make a copy of the "full movie" you want to cut, to know how it works!
Hello,I set up BH 2.1.5 in my ultimo in the start it is ok & after one month of using when I start up my STB not open anymore and then set up BH 2.1.4 working good for few days & stop working again , but before with old BH this problem not happen I did not add any plugin I am asking why this image not staple with my ultimo I need help please.
I don't understand what you mean... Explain BETTER what you want to speak please.
