Black Hole Vu+ Ultimo 2.1.7
Hi,
I have installed the latest version and now I am unable to view any recordings. When I select the button on the remote to view the recordings nothing happens. Also once this happens the entire system is locked and I am unable to change channels.
Lastly when I power off the TV and power it back on it crashes.
Any ideas?
Thanks for your help.
Also I have switched back to version 2.1.6.1 and now have the exact same problem.
Hi,
Any ideas?
I Have found out the issue - the plugin SerienFilm 1.1 is the issue. This must be removed and then all works fine.
Hi, great job, but I install new BH image on my Vu+ ULTIMO and with new BH cant work with tuner USB OMEGA T900 DVB-T (Chip IT9135 BDA). An earlier version 2.0.9 everything worked perfectly. And for this reason I returned back to version 2.0.9. Can I do something about it, whether it needs updating the new BH. I enclose dmesg file, it can help solve the problem.
Thanks for the new Image, Just wanted to ask a question, after installing 2.1.7 my H Drive would not mount, went back to 2.1.6 still the same. I had to disconnect the drive then flash 2.1.7 then re initialize and delete for it to work again. Has 2.1.7 a different mount format.
Hi all Boys,
i've just a question.
Can someone help me to find steps (manual or guide) for upgrade Black Hole (on my Duo2) from 2.0.x to 2.1.7?
Thanks anb Best regards
Hi angelofsky1980,
ok for usb upgrade, but steps are:
1. Shut down VuPlus
2. Attach usb key to usb port
3. Power Up VuPlus
...and upgrade start directly?
Thanks a lot
4. When requested, press - on the touch panel on the box to stard flash.
5. When the flash process done, remove USB stick
6. Shut down box from rear button
7. Turn on it from rear button
I have problems with timezone. Tuner always shows GMT time, I need +2 hours. Changing in "timezone" don't affect real time. I have tried from -5 to +5, but its always the same time. How to fix it?
FYI
BH2.1.7.1
Vu+Ultimo
Crash while creating a personal backup.
Fyi: After the box came alive again, i rebooted and i immediately tried personal backup again, and the personal backup ended successfully.
Best regards
Hi guys
All the time I want to use the WEBRADIOFS I gor crash.... I just post the crash log if someone can help me where is the problem.. thanks
<?xml version="1.0" encoding="utf-8"?>
<opendreambox>
<enigma2>
<crashdate>Tue Oct 27 11:02:27 2015</crashdate>
<compiledate>Jul 7 2015</compiledate>
<contactemail>crashlog</contactemail>
<skin>skin.xml</skin>
<sourcedate>2015-07-07</sourcedate>
<branch>master</branch>
<rev>2.1.4-67-g9ccd154</rev>
<version>3.0.0</version>
</enigma2>
<image>
<kernelcmdline>bmem=232M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync</kernelcmdline>
<imageversion>
<![CDATA[
version=1000201507071544
</imageversion>
<imageissue>
<![CDATA[
BlackHole 2.1.7 %h
</imageissue>
</image>
<software>
<enigma2software>
<!-- Cannot allocate memory -->
</enigma2software>
<dreamboxsoftware>
</dreamboxsoftware>
<gstreamersoftware>
</gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
C] start cleanloop
[EPGC] stop cleanloop
[EPGC] 46311613 bytes for cache used
nr_read 20348 nr_write 39596
sum 59944 prev_sum 59944
hdd IDLE!
[IDLE] 780.000001907 600 True
action -> MoviePlayerActions leavePlayer
playing service..
stopping thread.
FILEPUSH THREAD STOP
thread joined 0
decoder state: pause, vpid=-1, apid=-1
DEMUX_STOP - video - ok
VIDEO_STOP - ok
AUDIO_STOP - ok
DEMUX_STOP - audio - ok
AUDIO_CONTINUE - ok
DEMUX_STOP - ttx - ok
not pauseable.
RemovePopup, id = ZapError
allocate channel.. 0010:22d4
opening frontend 2
[eDVBCAService] new channel 0x88e3dd8!
(2)tune
tuning to 578000 khz, bandwidth 0, crl 9, crh 9, modulation 6, tm 2, guard 4, hierarchy 4, inversion 2, system 0, plpid 0
OURSTATE: tuning
allocate Channel: res 0
[eDVBCIInterfaces] addPMTHandler 1:0:19:BE:10:22D4:EEEE0000:0:0:0:
allocate demux
resolve: resolve ${sysconfdir}/scan_tp_valid_check.py
resolve: -> /etc/scan_tp_valid_check.py
[SEC] startTuneTimeout 5000
[SEC] setVoltage 0
[SEC] setFrontend 1
setting frontend 2
cannot blit 8bpp from 32bpp
(2)fe event: status 0, inversion off, m_tuning 1
(2)fe event: status 1f, inversion off, m_tuning 2
OURSTATE: ok
[eDVBCAService] channel 0x88e3dd8 running
[eDVBLocalTimerHandler] channel 0x88e3dd8 running
no version filtering
0014: 70 00 00 00 00 00
mask: fc 00 00 00 00 00
mode: 00 00 00 00 00 00
[eEPGCache] channel 0x88e3dd8 running
stop release channel timer
[EPGC] next update in 2 sec
0012: 4e 00 be 00 00 00
mask: ff ff ff 00 00 00
ok ... now we start!!
0000: 00 00 00 00 00 00
mask: ff 00 00 00 00 00
eventNewProgramInfo 0 0
have 1 video stream(s) (05dd), and 1 audio stream(s) (05df), and the pcr pid is 05dd, and the text pid is 044e
allocate demux
disable teletext subtitles
decoder state: play, vpid=1501, apid=1503
DMX_SET_PES_FILTER(0x5dd) - pcr - ok
DEMUX_START - pcr - ok
DMX_SET_PES_FILTER(0x5df) - audio - ok
DEMUX_START - audio - ok
AUDIO_SET_BYPASS(1) - ok
AUDIO_PAUSE - ok
AUDIO_PLAY - ok
Video Device: /dev/dvb/adapter0/video0
demux device: /dev/dvb/adapter0/demux0
VIDEO_SET_STREAMTYPE 1 - ok
DMX_SET_PES_FILTER(0x5dd) - video - ok
DEMUX_START - video - ok
VIDEO_FREEZE - ok
VIDEO_PLAY - ok
DMX_SET_PES_FILTER(0x44e) - ttx - ok
DEMUX_START - ttx - ok
VIDEO_SLOWMOTION(0) - ok
VIDEO_FAST_FORWARD(0) - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
not pauseable.
[AutoRes] service changed
+ 1/1 TID 00
done!
PATready
use pmtpid 05dc for service_id 00be
05dc: 02 00 be 00 00 00
doing version filtering
0000: 00 00 00 37 00 00
mask: ff 00 00 3f 00 00
mode: 00 00 00 3e 00 00
-+ 1/2 TID 4e
++ 2/2 TID 4e
done!
0012: 4e 00 be 39 00 00
mask: ff ff ff 3f 00 00
+ 1/1 TID 02
done!
05e2: 74 00 00 00 00 00
have 1 video stream(s) (05dd), and 3 audio stream(s) (05df, 05e0, 05e1), and the pcr pid is 05dd, and the text pid is 044e
[eDVBCAService] new service 1:0:19:BE:10:22D4:EEEE0000:0:0:0:
[eDVBCAService] add demux 0 to slot 0 service 1:0:19:BE:10:22D4:EEEE0000:0:0:0:
[eDVBCIInterfaces] gotPMT
demux 0 mask 01 prevhash 00000000
[eDVBCAService] send 59 bytes
9f 80 32 37 03 00 be 03 00 13 01 81 08 ee ee 00 00 00 10 22 d4 82 02 01 00 84 02 05 dc 06 04 4e 00 00 1b 05 dd 00 00 03 05 df 00 00 03 05 e0 00 00 03 05 e1 00 00 05 05 e2 00 00
05dc: 02 00 be 03 00 00
+ 1/1 TID 74
done!
AITready
Section Length : 98, Total Section Length : 101
found applicaions ids >> pid : 5e2, orgid : 38, appid : 16501
Save Data Len : [101]
Found : control[-1], name[T5HD HBBTV], url[http://hbbtv.mediaset.es/hbbtv.xhtml?c=5]
URL : http://hbbtv.mediaset.es/hbbtv.xhtml?c=5
OrgID : 38
AppID : 16501
Control Code : -1
Profile Code : 0
(-1, 'T5HD HBBTV', 'http://hbbtv.mediaset.es/hbbtv.xhtml?c=5', 38, 16501, 0)
[AutoRes] determineContent
[EPGC] start caching events(1445939979)
sdt update done!
[eDVBLocalTimerHandler] diff is 0
[eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
[eDVBLocalTimerHandler] not changed
action -> InfobarInstantRecord instantRecord
self.recording: []
action -> WizardActions ok
pre:
[TIMER] record time changed, start prepare is now: Tue Oct 27 10:59:22 2015
sanitycheck
check
checkTimerlist
recording service: 1:0:19:BE:10:22D4:EEEE0000:0:0:0:
record: 0
recording service: 1:0:1:77BF:40A:1:C00000:0:0:0:
record: 0
record: 0
[Timer] Record <RecordTimer.RecordTimerEntry object at 0x745a2c50>
ProcessRepeated
It's now Tue Oct 27 10:59:42 2015
[TIMER] activating state 1
begin_date: 20151027 1059
service_name: Telecinco HD
name: EL PROGRAMA DE ANA ROSA
description:
[TIMER] Filename calculated as: '/hdd/movie/20151027 1059 - Telecinco HD - EL PROGRAMA DE ANA ROSA - '
recording service: <enigma.eServiceReference; proxy of <Swig Object of type 'eServiceReference *' at 0x24fde30> >
record: 0
[add callback]
use cached_channel
RECORD service event 6
tuned..
[TIMER] record event 2
RECORD service event 5
[TIMER] record event 6
query epg event id 96
found event.. store to disc
[TIMER] prepare ok, waiting for begin
[TIMER] activating state 2
[TIMER] start recording
[TIMER] record event 0
AddPopup, id = None
Recording to /hdd/movie/20151027 1059 - Telecinco HD - EL PROGRAMA DE ANA ROSA - .ts...
start recording...
RECORD: have 1 video stream(s) (05dd), and 1 audio stream(s) (05df), and the pcr pid is 05dd, and the text pid is 044e
ADD PID: 0000
ADD PID: 044e
ADD PID: 05dd
ADD PID: 05df
before: 1
after: 1
setIoPrio realtime level 7 ok
FILEPUSH THREAD START
[TIMER] record event 4
next real activation is Tue Oct 27 12:55:00 2015
[timer.py] next activation: 1445940083 (in 99956 ms)
after:
[<RecordTimer.RecordTimerEntry object at 0x745a2c50>]
-+ 1/2 TID 4e
+ 1/1 TID 00
done!
PATready
++ 2/2 TID 4e
done!
getting PCR failed!
[eDVBServiceRecord] now running: EL PROGRAMA DE ANA ROSA (13800 seconds)
[TIMER] record event 9
+ 1/1 TID 02
done!
start recording...
RECORD: have 1 video stream(s) (05dd), and 3 audio stream(s) (05df, 05e0, 05e1) (044e), and the pcr pid is 05dd, and the text pid is 044e
ADD PID: 05dc
ADD PID: 05e0
ADD PID: 05e1
[eDVBCAService] add demux 0 to slot 1 service 1:0:19:BE:10:22D4:EEEE0000:0:0:0:
demux 0 mask 01 prevhash 05dc0101
[eDVBCAService] don't build/send the same CA PMT twice
+ 1/1 TID 74
done!
AITready
RECORD service event 10
Timeout!
[EPGC] abort non avail schedule other reading
[EPGC] abort non avail viasat reading
[EPGC] abort non avail mhw reading
[EPGC] nownext finished(1445939986)
[EPGC] schedule finished(1445939996)
[EPGC] stop caching events(1445939996)
[EPGC] next update in 60 min
no ancillary data in audio stream... abort radiotext pes parser
It's now Tue Oct 27 11:00:03 2015
[timer.py] next activation: 1445940103 (in 99998 ms)
[EPGC] start cleanloop
[EPGC] 46299073 bytes for cache used
nr_read 20356 nr_write 39726
sum 60082 prev_sum 59944
hdd was accessed since previous check!
[IDLE] 0 600 False
[EPGC] 46298771 bytes for cache used
It's now Tue Oct 27 11:01:22 2015
[timer.py] next activation: 1445940183 (in 99998 ms)
nr_read 20357 nr_write 39878
sum 60235 prev_sum 60082
[IDLE] 0 600 False
It's now Tue Oct 27 11:01:43 2015
[timer.py] next activation: 1445940203 (in 99999 ms)
action -> InfobarChannelSelection switchChannelUp
allocating new converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
action -> ChannelSelectBaseActions showFavourites
action -> OkCancelActions ok
playing service..
[eDVBCAService] free slot 0 demux 0 for service 1:0:19:BE:10:22D4:EEEE0000:0:0:0:
decoder state: play, vpid=-1, apid=-1
DEMUX_STOP - pcr - ok
VIDEO_STOP - ok
AUDIO_STOP - ok
AUDIO_CONTINUE - ok
not pauseable.
allocate channel.. 0005:0085
available channel.. 0010:22d4
opening frontend 1
[eDVBCAService] new channel 0x6efa22d8!
(1)tune
RotorCmd ffffffff, lastRotorCmd ffffffff
prepare_sat System 0 Freq 12460500 Pol 0 SR 27500000 INV 2 FEC 3 orbpos 192 system 0 modulation 1 pilot 2, rolloff 0
tuning to 1860 mhz
OURSTATE: tuning
[eDVBCIInterfaces] addPMTHandler 1:0:2:AD:5:85:C00000:0:0:0:
allocate demux
[SEC] set static current limiting
set sequence pos 3
set sequence pos 4
[SEC] setVoltage 2
[SEC] sleep 200ms
[SEC] invalidate current switch params
[SEC] sendDiseqc: e00000(DiSEqC reset)
[SEC] sleep 50ms
[SEC] sendDiseqc: e00003(DiSEqC peripherial power on)
[SEC] sleep 150ms
[SEC] sendDiseqc: e01038f3
[SEC] sleep 50ms
set sequence pos 3
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] update current switch params
[SEC] setFrontend 1
setting frontend 1
[SEC] sleep 500ms
(1)fe event: status 0, inversion off, m_tuning 1
(1)fe event: status 1f, inversion off, m_tuning 2
OURSTATE: ok
[eDVBCAService] channel 0x6efa22d8 running
[eDVBLocalTimerHandler] channel 0x6efa22d8 running
[eEPGCache] channel 0x6efa22d8 running
0012: 4e 00 ad 00 00 00
have 0 video stream(s), and 1 audio stream(s) (0150), and the pcr pid is 0150, and the text pid is ffffffff
allocate demux
PES filter: DMX_SET_PES_FILTER - Invalid argument
decoder state: play, vpid=-1, apid=336
DMX_SET_PES_FILTER(0x150) - pcr - ok
DMX_SET_PES_FILTER(0x150) - audio - ok
AUDIO_PAUSE - ok
AUDIO_PLAY - ok
AUDIO_CONTINUE - ok
showSinglePic /usr/share/enigma2/radio.mvi
[SEC] set dynamic current limiting
[eDVBLocalTimerHandler] diff is 1
[eDVBLocalTimerHandler] update RTC
[eDVBLocalTimerHandler] time update to 11:02:19
[eDVBLocalTimerHandler] m_time_difference is 1
[eDVBLocalTimerHandler] set Linux Time
+ 1/1 TID 00
done!
PATready
use pmtpid 0085 for service_id 00ad
0085: 02 00 ad 00 00 00
0000: 00 00 00 2d 00 00
+ 1/1 TID 02
done!
AUDIO_CONTINUE - ok
[eDVBCAService] new service 1:0:2:AD:5:85:C00000:0:0:0:
[eDVBCAService] add demux 1 to slot 0 service 1:0:2:AD:5:85:C00000:0:0:0:
demux 1 mask 02 prevhash 00000000
[eDVBCAService] send 34 bytes
9f 80 32 1e 03 00 ad 07 00 13 01 81 08 00 c0 00 00 00 05 00 85 82 02 02 01 84 02 00 85 03 01 50 00 00
0085: 02 00 ad 07 00 00
action -> InfobarShowHideActions hide
[EPGC] start caching events(1445940140)
timeout 0012!
sdt update done!
action -> InfobarExtensions extensions
unknown action InfobarExtensions/extensions! typo in keymap?
action -> WizardActions right
unknown action WizardActions/right! typo in keymap?
action -> InputActions right
unknown action InputActions/right! typo in keymap?
action -> DirectionActions right
unknown action DirectionActions/right! typo in keymap?
action -> DirectionActions rightUp
unknown action DirectionActions/rightUp! typo in keymap?
File "/usr/lib/enigma2/python/mytest.py", line 201, in processDelay
callback(*retval)
File "/usr/lib/enigma2/python/Screens/InfoBarGenerics.py", line 1503, in extensionCallback
answer[1][1]()
File "/usr/lib/enigma2/python/Tools/BoundFunction.py", line 9, in __call__
return self.fnc(*self.args + args, **newkwargs)
File "/usr/lib/enigma2/python/Screens/InfoBarGenerics.py", line 739, in runPlugin
plugin(session = self.session, servicelist = self.servicelist)
File "/usr/lib/enigma2/python/Plugins/Extensions/webradioFS/plugin.py", line 193, in main
File "/usr/lib/enigma2/python/Plugins/Extensions/webradioFS/webradioFS.py", line 153, in <module>
OSError: [Errno 12] Cannot allocate memory
(PyObject_CallObject(<bound method Session.processDelay of <__main__.Session instance at 0x19e2a80>>,()) failed)
</enigma2crashlog>
<pythonMD5sum>
</pythonMD5sum>
</crashlogs>
</opendreambox>
