Black Hole Vu+ Ultimo 2.1.7
Thanks for the image. I have however ran into big problems trying to update. The box will turn on without asking me to update and hence could not press - button. The box then just got stuck on logo. I deleted the vuplus folder via network from the computer and still failed to initiate the software. The Ultimo box is now saying it is empty when accessed via network. It says 3.70GB of 3.79GB free spacewise even though I have a 2TB disk inside which has worked brilliantly for over a year. I will appreciate help trying to get the box to work again. I managed to upgrade Solo2 and Duo2 without any problems. Thank you in advance.
I have a problem after installing this, when i bring up the menu it's all the way of to the far left border on my screen. Almost like everything is zoomed in to much. I have looked thru the settings for some kind of boarder calibration but can't seem to find anything. Anyone else experiencing this problem?
If you want to adapt the UI, you can use the UI Position Setup plugin.
Black Hole 2.1.7 MultiBoot
WHAT IS NEW
    • New switch from MeoBoot to OpenMultiBoot to use different kernels and drivers for each installed image.
    • New skin MX i6p By Matrix10
    • Vu+ drivers 20150623
      - Fix tuning problem(AVL6211, duo2, solose)
      - Improve vtuner(satip support)
      - Fix scrambling bit in recording
      - Improve transcoding
    • Xbmc Support 576/720/1080 resolution
    • Updated Vuplus-Blindscan
    • Updated HbbTv
    • Updated WebManual
    • Added Sat>Ip Client
    • Included UiPositionSetup
    • Removed MeoBoot
    • Added OpenMultiBoot
    • Updated Lcd4Linux
    • Updated MediaTree (usb tuners drivers)
    • Fixed random socket error
    • [ScanSetup] fixed error on complete scan with T2 tuners
    • [ScanSetup] fixed TT3L10 automatic scan problem
    • [unicable] support JESS(EN50607) and update unicable.xml
    • AnimationSetup: set default to animations disabled
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
gracias.
WHAT IS NEW
    • Updated HbbTv
    • Updated WebManual
    • Removed MeoBoot
    • Updated Lcd4Linux
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
