Black Hole Vu+ Ultimo v. 2.0.4
Hello.
Disk Seagate Backup Plus 3Tb (NTFS) with a Black Hole Vu+ Solo2 2.0.3 Hyperspace does not work (with the Black Hole 2.0.2 rev. E and with OPENaTV (kernel 3.3.8) - works fine!).
WiFi adapter TP-Link TL-WDN3200 can't be detected.
the same problme reported by oldfox on solo2
Hello.
About Wifi, please open a dedicated thread in Wifi area.
About NTFS disks I should make some tests BUT I've only a small disk (500Gb).
HI
I have just reported the message of oldfox, i don't have a problem with the wifi, my problem is external HDD is detected correctly 4000G, but the files inside is not detected!!!
thanks
Please can you go back and enable plugins one at time and let us know what is that really needed ?
We need your help because we cannot recreate the bug.
I disabled the plugin, and I restart the system, but the hard drive continues to function properly! several times I even unplug the hdd and I start the system and I connect the hdd later and this still works!!
to respond to your question I have to reinstall the BH2.0.4 again, and this time I activate plugin by plugin:notworthy:
Yes i understood. This because your hdd need a dependency that we don't know and that is used by one of that plugins.
When the plugin is installed the dependency install the extra package. The extra package stay in the system also when the plugin is removed.
For this reason your hdd continue to work.
The only way to know what is the application needed is to reflash.
the first package to try to add is Djmount because it install fuse and fuse module that are the major candidtate in my opinion for hdd NTFS stuffs.
Do a full backup of your current setup first.
That way you can just do a fresh install, add the packages until your hdd works correctly as shiro has said.
Then to save you time, just reflash with your full backup and everything was back to how it was before :D
