Black Hole Vu+ Ultimo v.2.0.6
All seems to work good except for NO dvb-c using this image.
Can't find any channels on dutch cable (ziggo).
Therefore for me it's a useless image!
I can see the dvb-c tuner in the tuner setup, but simply doesn't provide any signal.
Doing a scan doesn't find anything & putting in a channellist by SETEDIT doesn't help either.
Also i have 1 request if you please can include the CABLE SCAN plugin which is available in almost any other image (except for Blackhole & VTI) in future releases.
Thanks!
Nolan
I can confirm that the latest VU Ultimo image 2.1 taken from http://code.vuplus.com does indeed work good concerning the DVB-C part.
I did a manual scan on DVB-C and this works fine.
For now i went back to OpenPli 4
regards,
nolan
Many thanks for the new image
I have 2 questions:
1- Can I use Personal Settings Backup from BH 2.0.5 on BH 2.0.6 after re-flashing ? if so, will that restore all my configuration, Satellite positions, channels, addons, skin, plugins, customisation and so on ?
2- What HDMI settings I need in order to have my TV switch automatically to the correct AV channel when I turn on my VU+ Ultimo (the Ultimo is connected directly to the Panasonic HDTV via HDMI 1.3 cable)
I have 2 questions:
Yes and Yes (, mount your usb)
Hdmi-Cec Vu+ TV interaction (Black top-button = On, Red top-button = Off)
(Translation (ja=Yes, nej=No))
Best Regards
Thanks superglud, I have tried the HDMI settings you recommended above but still not working, the TV won't switch to the corresponded AV channel automatically when I switch the Ultimo on, anyone else have any other suggestions ?
Try to set:
Vu on => TV activity: Source active
