Black Hole Vu+ Ultimo v.2.0.6
Thanks Mito but still doesn't work, my Sky HD box switch to the correct AV channel when turned on, my DVD recorder also, I am not sure why the Ultimo doesn't ?
It is a successful and high-quality image,but need to know what to install on it, you risk of blockages.
Success of those who have worked for them.
What is error ? Dont start my vu ultimo
Logo out serial:
Configuring network interfaces... nmbd: error while loading shared libraries: /lib/librt.so.1: ELF file data encoding not little-endian
smbd: error while loading shared libraries: /lib/librt.so.1: ELF file data encoding not little-endian
run-parts: /etc/network/if-up.d/01samba-start exited with code 127
bcmemac: eth0 NIC Link is Down
Starting portmap daemon...
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
crond[526]: crond: crond (busybox 1.19.4) started, log level 8
/bin/pp: line 1: syntax error: unexpected "("
/etc/rcS.d/S97service: line 3: /bin/mii: not found
/etc/rcS.d/S97service: line 6: /bin/mii: not found
INIT: Entering runlevel: 3
dbus-uuidgen: error while loading shared libraries: /lib/librt.so.1: ELF file data encoding not little-endian
Logo out serial:
Seems you have installed something not compatible with Vu+ architecture (MIPSel).
I suggest to reflash your box.
When I use PIP on an HD channel, I always see the channel stops, this does not happen with SD channel, Is it a problem of the decoder and therefore has no solution?.
Thanks.
It is the second time that both error happens after stendby confort first appeared with 2.05 and now with 2.06, yes I put new 2.07 image but do not know the cause of this error
Have I found that when I change the channel, it occurs randomly, audio is heard wrong, the only solution is to change the channel again, is known this problem?.
Best regards.
