Black Hole Vu+ Uno 1.7.2 (media-tree)
In what may be a problem - does not see the flash drive with NTFS ?
Fat32 or ext3 sees normally.
opkg update
opkg install kernel-module-ntfs
* Cannot find package kernel-module-ntfs.
opkg update
Into BH 1.7.2 you should use ntfs-3g utils (already installed) to manage NTFS volumes.
As I understand, NTFS in BH is used only for reading, because i can not make a swap file.
in BH 1.7.2 installed ntfs-3g - 2011.4.12-r0 = but that gives me this, how do I used it?
ntfs-3g 2012.1.15, released on January 22, 2012.
Maybe it will help me, because after mounting of USB sticks (NTFS): Kingston DT400 16gb, DT101 8gb, Transcend 16Gb JetFlash 600, swap is not created. Crossepg not see flash drive
Hello Guys!
Need your support on the following problem. I've installed BH 1.7.2 without FPGA update, now I'm trying to update FPGA both ways - USB and Internet and getting error message " Can't find checksum file" or "Can't load MD5 file". What I'm doing wrong? By the way I'm trying to update it on Ultimo, think no any differance between UNO and Ultimo regarding FPGA upgrade. Thanks in advance.
Hello Guys!
Double post in wrong section.
Respect general forum rules please.
Hello,
I have a changement in the LCD display. The channel names are not displayed.
Is it an option ?
Impossible to find a method to return to the good state.
If somebody have a solution?
Regards.
@ Dudule22
If there is no menu associated with your skin, you can download an other one with green button; then delete the previous one, and finally download again the one you were using :) .
@nighou
It is not a problem with the menu. On the TV screen all is OK. The default is on the display of the VU+ box.
Impossible to have the channel name on the display, i have the selected menu.
Is it a bug that happends after a time, is it an option?
For this problem, the unique way for the moment is to flsah again the last image.
Is there another solution ?
As far as I know, the display on the front display is given by the skin and not the image...
If you have the same issue with a different skin, may be it is a harware problem ? Did you check if the connector of the front display is properly plugged ?
@nighou
I have the same problem too. I tried to change skin, but witouth success. Is there a way to set up the contents of the display?
hi, i had a timer setup to record gold rush on discovery 9pm, i had it setup to record weekly, however the series has finished and now wheeler dealers is on at 9pm, the box is still recording and i can not edit or delete the timer, is there anyway i can stop it recording or can i ftp to the box and delete it manualy, if so, which file do i edit and were is it located?
Press recordings botton, i think you should be able to stop it.
