Black Hole Vu+ Uno 1.7.2 (media-tree)
I have problem, after update to latest B.H : version : Feb 4 2012-vuplus_experimental , Image : BlackHole 1.7.2 , Tuner : Vuplus DVB-S NIM ( DVB-S2) i dont have signal from satelite but when im check in setting ( signal tuner ) is OK but when im choice program from list, nothing display in TV only logo B.H..
when searching for channels, nothing is find :(
Upgrade FPGA with the corresponding plugin, then reboot your box.
I do experience occasional green screens using BH 1.7.2 firmware.
- It seems to occur a short interval after a channel change. Will try to get more specific conditions: The last crash involved also a satelllite change (DISEQ switch) for sure and teh new channel was encrypted HD , old channel was FTA and SD.
- The GUI seems to crash and restarts automatically
- After coming back the channel reverts back to a previously selected channel (not sure it is really the most recent one)
You should attach the crash log to understand what's the problem.
You should find it into hdd directory: /media/hdd
hello everyone can i install latest drivers to BH 1.7.2. i have with meoboot or i must install them in flash image only?
Hello Team , i have update B.H. from 1.6.6 to 1.7.2 in VU+ Uno with f/w 4.4 . All is OK but dtt Aver TV Volar Green HD has very slow sensibility now. I receive few ch and the time for change from one ch to another is very long. I have applied .ppk for AF9035 without result. :(
Will be possible to have a new AF9035 driver good like the old one ?
Thanks for your excellent job
I follow for BlackHole Team. It was necessary to change Dreambox 800HD on Vu + Uno. I again with the favorite team.
As always fine image, excellent work BlackHole team. Has found 2 small lacks. HDMI-CEC some options not always work correctly. At switching of the menu of a receiver on Russian language, the receiver display displays not all symbols of Cyrillics. It can be corrected?
Dream Multimedia added some useful functions to Enigma2. You can read about them in quote below.
Enigma2: Release 3.2
Machine: Dreambox dm800
Date: 20110929
Issuer: Dream Multimedia
Link: flashable firmware images for dm800
MD5: e98ec6e1a7e84b47313c0e79785f7e5b
Description:
CHANGELOG DM800 RELEASE 3.2.0
enigma2 (20101216 rel31 -> 20110929 rel32)
added basic support for remote TS services in bouquets (rdp, udp, http, iptv)
put USB harddisks into stand-by
So the question is have you any plans to add them to you images or it depends on VU+ development only or in general have you any information about this?
From September 2011, DM has changed the E2 project from OSS to Closed source project.
Vu+ has continued the development of DVBAPP (E2 OSS fork).
