Black Hole Vu+ Uno 1.7.2 (media-tree)
Goodmorning guys,
just for confirm:
i have a vu+ uno with "bh1.7.1 server tuner - meoboot emedded",
can i install 1.7.2 in HD for start in multiboot?
If NO, i can use meoboot in 1.7.1 just with other images an no BH images?
thks
Giacomo
Goodmorning guys,
just for confirm:
thks
Giacomo
You have to install this img in flash.
You can have this img in multiboot only if you have 172 also in flash.
BH VU Uno 1.7.2 does not detect the usb tuner pctv74e :(
And when trying to restart the image on the box is blocked 1.7.2 with pctv74e inserted into the USB port.
Please support the usb tuner pctv74e!
On Uno box the AS102 driver has some problems and we are working to solve this issue.
Thank you very much BH Team.
Where is the menue to change skin with this from Matrix10 (Elegance) ? I did not find it :(
First you have to download and install the skin:
BH Green Panel > Addons Manager > Addons Download Manager > Black Hole Image Skins > Elegance HD...BH 1.tx
Then:
Menu > Setup > System > Skin > Elegance HD
Thanks for this new version.
Playing avi and mkv files works better.
But after, when we return to channel TV, the memory is not cleaned.
Regards.
Hi,
amazing work, thanks a lot for that.
But I have a question/problem: Every channel works fine except for HD (in germany DasErsteHD, ZDF HD, arte HD, and so on). The screen keeps dark, no error message, no sound, no picture. All SD channels are fine.
Whats going wrong?
Regards
Krümel
I just did a channel scan. The channels which doesn't worked before has gone now! :eek:
But why? Before I flashed this version they were there!
hello all,
do I have to upgrade the bootloader to flash this image ?? If yes where can I find it ??
Thanks !!
snet
There is couple of things that need to be fixed and that are inflecting with every day use of the STB.
First of all the LNB pass through must be enable on standby or deep standby. There is no signal pass through the tuner.
And second there must be an option of having Dolby Digital through HDMI.
These are not BH image bugs and your post is out of place in this thread.
