Black Hole Vu+ Uno 1.7.3 (Skin Tribute)
Does this release support the plugin Webbrowser??
Yes. But it uses apprx 33.17 MB of space! It is better to place Webbrowser in MeoBoot. You can download Webbrowser from Setup, Software Management, Manage extensions, Network, Web Browser.
To use remote for Webbrowser leave Mouse, Remote Control and Keyboard, EventO.
Thanks for this new version.
But, I have the same bug after one day of use with this new image.
Impossible to have the channel name on the display, i have the selected menu.
Is it a bug that happends after a time, is it an option?
For this problem, the unique way for the moment is to flash again the last image.
Is there another solution ?
Sorry, what do you mean by install image agn !!??
Well install BH image twice .
One in flash and one on USB with webbrowser.
It's a good idea if you do not use permanent webbrowser.
Webbrowser use/holds a lot of flash and slows image work .
When you need Webbrowser then you use BH image on USB with installed Webbrowser.
Congratulations is a spectacular work ... every day are overcome more and do wonderful things .. thanks friends
Great Work ! ! !
USB DVB-T works fine.
Only issue is when PIP in activated, with SD DVB-T service in PIP Window,
the frame rate of PIP window is 1-2 frames per second (like stop motion).
:thanks: BH Team. ! !
P.S
which VU+ Drivers Version Please?
when i start online videos from web player , youtube , dailymotion , machine crach and green screen
how can i fix the problem
