Black Hole Vu+ Uno 1.7.3 (Skin Tribute)
Great job,great.Only problemsometimeschannelscan not be seen
and you have to"startcams"to be able tosee again.
BHTHANKS
As we do not support cams, you are not allowed to talk about cams on this forum, so we can't help you with that i'm afraid.
Small bug
In Radio mode when you select a channel does not go into full screen mode, and remains in the channel selection.
Small bug
It is not a bug.
Please go into menu,setup,system,customise and go to Alternative radio mode, and change to yes.
Thanks again to our Great team BH,in my personal opinion i tried also the two images of BP but as always i am still found that BH images is much better.Thanks again BLACK HOLE TEAM :yahoo::notworthy:
Big Problem!!!
After I run the update the box reboots with nothing on screen. The OSD says "VU+ UNO" and I can ssh to the IP address of the box but there is no display, my TV just says "Check Signal Cable". Also, the webinf is up but nothing is running and I can't do anything.
Can anyone help!? My box is unusable at the moment.
EDIT: By taking a Screen Grab on the WebINF I can see the box is waiting in setup mode. I took a screen shot after every answer and I managed to get it up and running - weird that it didn't output the setup mode to HDMI
Is there anyway to disable the Video Enhancement Settings? I was previously on BH1.65 (I think) and since the upgrade my HD image is terrible. I see the Video Enhancement Setting seems to be set to a strange default setting and I think this is the problem - can this be disabled and allow the TV settings take control?
Grand bel lavoro, ottimo. unico problema ogni tanto canali si blocano
e bisogna fare "start cam" per potere vedere di nuovo.
BH GRAZIE
First: this is ENGLISH / INTERNATIONAL section. Only English language is allowed.
Second: your question break Board rules. The image has no problems and it's an YOUR issue with external software components NOT SUPPORTED here.
Hi Friends
I installed 1.7.3, the Media Center subtitles of the films are small...
Is there a way to increase the size of the legends of Media Center ?
It can be totally removed!
long blue>software manager>advance options>packet management!
Or DCC,,etc!
