Black Hole Vu+ Uno 1.7.3 (Skin Tribute)
Hum, idonno-- i upload immidiatly , dint switched on to see. i have more here.-. but its comes from the factory i opened the BIG box. i must check?
oh,-i did the FPGA upgrade- thats was the first thing..
-Shoild i open one more to answer the question?
Use the plugin for "genuine vu+",,,or "return the love" plugin for checking or if there a sticker for info about update or upgrade!
Any way I think U may have colon,,,as I can read from U'r post#78 that " I reupload my backup from 172 . it works fine for now."
(that was your statment)
Here @ V-C community we only give help for GENUINE vuplus STB's and BH images!
RgdZ
a911
RgdZ
a911
Hey, it msut be an ORIGINAL unit, its NO doubt about it, its come from the official reseller, - i really cant understand your attitude with me, i DO NOT do anything with the clones. Please , i just wanted a help from here, no reason for this metter. , but- okay just to see clear: im doing the test for you-for us.
OK fine!
Its just what I read from your statement about 1.72 backup, here we do not support backups!
So please, do not upset your self, just do the test and we can start correctly from there..;) !
Thanx
a911
I did: authentication: SUCCES with love.. and how i know - NO UNO clones for now.. sorry if i disturbed the forum.
-Oh-no im not upset--- just confused- what i want to say about the "backup" that the backup works FINE(ITS MY PERSONAL FULL BACKUP from usb) but the 173 stops working-- last time when i want to full backup: pictures still, and must reboot , then i put back the 172 into unit.
-so i want help for the 173. it was a "virgine" swf from this site.
thx for want to help-
-Oh-no im not upset--- just confused- what i want to say about the "backup" that the backup works FINE but the 173 stops working-- last time when i want to full backup: pictures still, and must reboot , then i put back the 172 into unit.
Am glad its SUCCES with love!
Now, try to download BH1.73 from the from here and install it.
Do not re insatll your old setting, try with a new one, if possible ,or use one from BH Addon server!
Thanks Dude.. i ill do this way. but "unfortunatly" NADAL- DJOKOVIC is running ... but i will do this as you suggested..
Have a wonderfull sunday afternoon!
Okay, i upload the swf from here, also upload with Vhannibal last setting, not touch anythinm more.
Enigma stop working after 10 minutes, going back to 172?
Image is for sure OK. Using it from first time after release, no problems to now. Check top and temperature of box. Do you have any HD installed?
The box is cool, i mean cold.
-yes i do have sata HDD installed, since i use 172 again, its working now. i also had a crash (freez) when i listen a music via HDD. its just stops. Also stop to react to any command.
-same hdd now recording the program, w/o problem..
-Think its a hdd issue?
Friends.. we are closer every day. I reporting to you that the 172 also stops. but takes longer. i unplugged the Esata now, and it works from today mornig but still 172.. i was sure that the 173 also perfect. no doubt. Something Esata related problem i have. Is there any file that cousing the stops? i have some bacups from dream, also from vu, epg dats, picons.. shuold i delete everything exept the muvis and music? zhanks guys
-i have a last crash log. may i send it to somebody to check?
<?xml version="1.0" encoding="utf-8"?>
<opendreambox>
<enigma2>
<crashdate>Sat Apr 21 03:20:21 2012</crashdate>
<compiledate>Apr 8 2012</compiledate>
<contactemail>crashlog</contactemail>
<skin>skin.xml</skin>
<sourcedate>Apr 8 2012</sourcedate>
<branch>vuplus_experimental</branch>
<rev></rev>
<version></version>
</enigma2>
<image>
<kernelcmdline>bmem=232M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync</kernelcmdline>
<imageversion>
<![CDATA[
version=1000201204082314
comment=Vuplus
target=9
creator=OpenEmbedded <oe@vuplus.com>
url=http://www.vuplus.com/
catalog=http://www.vuplus.com/
</imageversion>
<imageissue>
<![CDATA[
Vuplus 2.2.0 + BlackHole 1.7.3 %h
</imageissue>
</image>
<software>
<enigma2software>
<![CDATA[
enigma2 - experimental-git20110922-r26
enigma2-defaultservices - 1.0-r5
enigma2-meta - experimental-git20110922-r26
enigma2-plugin-extensions-cutlisteditor - experimental-git20110922-r26
enigma2-plugin-extensions-dvdplayer - experimental-git20110922-r26
enigma2-plugin-extensions-graphmultiepg - experimental-git20110922-r26
enigma2-plugin-extensions-mediaplayer - experimental-git20110922-r26
enigma2-plugin-extensions-mediascanner - experimental-git20110922-r26
enigma2-plugin-extensions-mytube - experimental-git20110215-r4
enigma2-plugin-extensions-openwebif - 0.1+git332+866c808-r0.71
enigma2-plugin-extensions-pictureplayer - experimental-git20110922-r26
enigma2-plugin-extensions-vuplusevent - experimental-git20110922-r26
enigma2-plugin-systemplugins-autoresolution - experimental-git20110215-r4
enigma2-plugin-systemplugins-blindscan - experimental-git20110922-r26
enigma2-plugin-systemplugins-commoninterfaceassignment - experimental-git20110922-r26
enigma2-plugin-systemplugins-factorytest - experimental-git20110922-r26
enigma2-plugin-systemplugins-fpgaupgrade - experimental-git20110922-r26
enigma2-plugin-systemplugins-hdmicec - experimental-git20110922-r26
enigma2-plugin-systemplugins-hotplug - experimental-git20110922-r26
enigma2-plugin-systemplugins-manualfancontrol - experimental-git20110922-r26
enigma2-plugin-systemplugins-networkbrowser - experimental-git20110215-r4
enigma2-plugin-systemplugins-networkwizard - experimental-git20110922-r26
enigma2-plugin-systemplugins-positionersetup - experimental-git20110922-r26
enigma2-plugin-systemplugins-remotecontrolcode - experimental-git20110922-r26
enigma2-plugin-systemplugins-satfinder - experimental-git20110922-r26
enigma2-plugin-systemplugins-skinselector - experimental-git20110922-r26
enigma2-plugin-systemplugins-softwaremanager - experimental-git20110922-r26
enigma2-plugin-systemplugins-ui3dsetup - experimental-git20110922-r26
enigma2-plugin-systemplugins-uipositionsetup - experimental-git20110922-r26
enigma2-plugin-systemplugins-videoenhancement - experimental-git20110922-r26
enigma2-plugin-systemplugins-videomode - experimental-git20110922-r26
enigma2-plugin-systemplugins-videotune - experimental-git20110922-r26
enigma2-plugin-systemplugins-wirelesslansetup - experimental-git20110922-r26
enigma2-plugins-meta - experimental-git20110215-r4
enigma2-skins-meta - experimental-git20110128-r0
enigma2-streamproxy - 1.0cvs20101014-r0
task-vuplus-enigma2 - 1.0-r15
</enigma2software>
<dreamboxsoftware>
<![CDATA[
libdreamdvd0 - 0.10+git20110129-r0
</dreamboxsoftware>
<gstreamersoftware>
<![CDATA[
gst-plugin-alsa - 0.10.35-r0.0
gst-plugin-apetag - 0.10.30-r0.0
gst-plugin-app - 0.10.35-r0.0
gst-plugin-audioconvert - 0.10.35-r0.0
gst-plugin-audioparsers - 0.10.30-r0.0
gst-plugin-audioresample - 0.10.35-r0.0
gst-plugin-autodetect - 0.10.30-r0.0
gst-plugin-avi - 0.10.30-r0.0
gst-plugin-cdio - 0.10.18-r0.0
gst-plugin-cdxaparse - 0.10.22-r0.1
gst-plugin-decodebin - 0.10.35-r0.0
gst-plugin-decodebin2 - 0.10.35-r0.0
gst-plugin-dvbmediasink - 0.10+git20110210-r1
gst-plugin-dvdsub - 0.10.18-r0.0
gst-plugin-flac - 0.10.30-r0.0
gst-plugin-flv - 0.10.30-r0.0
gst-plugin-fragmented - 0.10.22-r0.1
gst-plugin-icydemux - 0.10.30-r0.0
gst-plugin-id3demux - 0.10.30-r0.0
gst-plugin-isomp4 - 0.10.30-r0.0
gst-plugin-mad - 0.10.18-r0.0
gst-plugin-matroska - 0.10.30-r0.0
gst-plugin-mpegaudioparse - 0.10.18-r0.0
gst-plugin-mpegdemux - 0.10.22-r0.1
gst-plugin-mpegstream - 0.10.18-r0.0
gst-plugin-ogg - 0.10.35-r0.0
gst-plugin-playbin - 0.10.35-r0.0
gst-plugin-rtp - 0.10.30-r0.0
gst-plugin-rtpmanager - 0.10.30-r0.0
gst-plugin-rtsp - 0.10.30-r0.0
gst-plugin-souphttpsrc - 0.10.30-r0.0
gst-plugin-subparse - 0.10.35-r0.0
gst-plugin-typefindfunctions - 0.10.35-r0.0
gst-plugin-udp - 0.10.30-r0.0
gst-plugin-vcdsrc - 0.10.22-r0.1
gst-plugin-vorbis - 0.10.35-r0.0
gst-plugin-wavparse - 0.10.30-r0.0
gstreamer - 0.10.35-r0
libgstapp-0.10-0 - 0.10.35-r0.0
libgstaudio-0.10-0 - 0.10.35-r0.0
libgstcdda-0.10-0 - 0.10.35-r0.0
libgstinterfaces-0.10-0 - 0.10.35-r0.0
libgstnetbuffer-0.10-0 - 0.10.35-r0.0
libgstpbutils-0.10-0 - 0.10.35-r0.0
libgstriff-0.10-0 - 0.10.35-r0.0
libgstrtp-0.10-0 - 0.10.35-r0.0
libgstrtsp-0.10-0 - 0.10.35-r0.0
libgstsdp-0.10-0 - 0.10.35-r0.0
libgsttag-0.10-0 - 0.10.35-r0.0
libgstvideo-0.10-0 - 0.10.35-r0.0
</gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
ncontrol_> recordings : 0
<ManualFancontrol_> All HDDs are Sleeping
<ManualFancontrol> setPWM to : 0
It's now Sat Apr 21 03:09:40 2012
[TIMER] activating state 1
[TIMER] prepare ok, waiting for begin
[timer.py] next activation: 1334970600 (in 19993 ms)
nr_read 72 nr_write 52
sum 124 prev_sum 124
hdd IDLE!
[IDLE] 13561.999954 300 True
<ManualFancontrol> checkStstus, fanoffmode : OFF, inStandby : True
<ManualFancontrol_> recordings : 0
It's now Sat Apr 21 03:10:00 2012
[TIMER] activating state 2
[TIMER] wakeup and zap
leave standby
leave standby
next real activation is Sat Apr 21 03:14:00 2012
[timer.py] next activation: 1334970700 (in 99925 ms)
playing 1:0:1:E31:16A8:FBFF:820000:0:0:0:
not pauseable.
RemovePopup, id = ZapError
allocate channel.. 16a8:fbff
opening frontend 0
[eDVBCAService] new channel 0x1d4d8b0!
(0)tune
RotorCmd 06, lastRotorCmd 02
set rotor timeout to 32 seconds
prepare_sat System 0 Freq 11880000 Pol 1 SR 27500000 INV 2 FEC 3 orbpos 130 system 0 modulation 1 pilot 2, rolloff 0
tuning to 1280 mhz
OURSTATE: tuning
allocate Channel: res 0
[eDVBCIInterfaces] addPMTHandler 1:0:1:E31:16A8:FBFF:820000:0:0:0:
allocate demux
resolve: resolve ${sysconfdir}/scan_tp_valid_check.py
resolve: -> /etc/scan_tp_valid_check.py
setLCDBrightness 127
<ManualFancontrol> Standby End
<ManualFancontrol> removeRecordEventCB
<ManualFancontrol> checkStatusLoopStop
<ManualFancontrol> checkStstus, fanoffmode : OFF, inStandby : False
<ManualFancontrol> getPWM : 0
<ManualFancontrol> setPWM to : 10
main thread is non-idle! display spinner!
[SEC] set static current limiting
set sequence pos 3
[SEC] setVoltage 1
[SEC] sleep 900ms
set sequence pos 9
[SEC] invalidate current rotorparams
[SEC] sendDiseqc: e0316b06
[SEC] sleep 1000ms
set sequence pos 3
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] setFrontend 0
setting frontend 0
[SEC] set timeout 128
[SEC] sleep 250ms
[SEC] rotor locked step 0 failed (not locked)
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
[SEC] locked step 0 ok
set sequence pos -3
[SEC] sleep 250ms
[SEC] locked step 1 ok (305419896 305419896)
set sequence pos -3
[SEC] sleep 250ms
[SEC] locked step 2 ok (305419896 305419896)
set sequence pos -3
[SEC] sleep 250ms
[SEC] locked step 3 ok (305419896 305419896)
set sequence pos -3
[SEC] sleep 250ms
[SEC] rotor locked step 4 failed (not locked)
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
set sequence pos -3
[SEC] sleep 250ms
[SEC] locked step 4 ok (305419896 305419896)
ok > 4 .. goto 3
set sequence pos 3
OURSTATE: ok
[eDVBCAService] channel 0x1d4d8b0 running
[eDVBLocalTimerHandler] channel 0x1d4d8b0 running
no version filtering
0014: 70 00 00 00 00 00
mask: fc 00 00 00 00 00
mode: 00 00 00 00 00 00
[eEPGCache] channel 0x1d4d8b0 running
stop release channel timer
[EPGC] next update in 2 sec
0012: 4e 0e 31 00 00 00
mask: ff ff ff 00 00 00
ok ... now we start!!
0000: 00 00 00 00 00 00
mask: ff 00 00 00 00 00
[SEC] update current rotorparams 97 0006 130
set sequence pos 4
[SEC] update current switch params
[SEC] sleep 500ms
+ 1/1 TID 00
done!
PATready
use pmtpid 0106 for service_id 0e31
0106: 02 0e 31 00 00 00
doing version filtering
0000: 00 00 00 01 00 00
mask: ff 00 00 3f 00 00
mode: 00 00 00 3e 00 00
+ 1/1 TID 02
done!
eventNewProgramInfo 0 0
have 1 video stream(s) (0a09), and 1 audio stream(s) (0a0a), and the pcr pid is 0a09, and the text pid is 0a0b
allocate demux
disable teletext subtitles
decoder state: play, vpid=2569, apid=2570
DMX_SET_PES_FILTER(0xa09) - pcr - ok
DEMUX_START - pcr - ok
DMX_SET_PES_FILTER(0xa0a) - audio - ok
DEMUX_START - audio - ok
AUDIO_SET_BYPASS(1) - ok
AUDIO_PAUSE - ok
AUDIO_PLAY - ok
Video Device: /dev/dvb/adapter0/video0
demux device: /dev/dvb/adapter0/demux0
VIDEO_SET_STREAMTYPE 0 - ok
DMX_SET_PES_FILTER(0xa09) - video - ok
DEMUX_START - video - ok
VIDEO_FREEZE - ok
VIDEO_PLAY - ok
DMX_SET_PES_FILTER(0xa0b) - ttx - ok
DEMUX_START - ttx - ok
VIDEO_SLOWMOTION(0) - ok
VIDEO_FAST_FORWARD(0) - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
not pauseable.
[AutoRes] service changed
[eDVBCAService] new service 1:0:1:E31:16A8:FBFF:820000:0:0:0:
[eDVBCAService] add demux 0 to slot 0 service 1:0:1:E31:16A8:FBFF:820000:0:0:0:
[eDVBCIInterfaces] gotPMT
demux 0 mask 01 prevhash 00000000
[eDVBCAService] send 82 bytes
9f 80 32 4e 03 0e 31 03 00 13 01 81 08 00 82 00 00 16 a8 fb ff 82 02 01 00 84 02 01 06 02 0a 09 00 13 01 09 04 09 19 e5 06 09 04 09 3b e5 09 09 04 09 cd e5 08 03 0a 0a 00 13 01 09 04 09 19 e5 06 09 04 09 3b e5 09 09 04 09 cd e5 08 06 0a 0b 00 00
0106: 02 0e 31 03 00 00
mask: ff ff ff 3f 00 00
[SEC] set dynamic current limiting
+- 1/2 TID 4e
[eDVBLocalTimerHandler] diff is -2
[eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
[eDVBLocalTimerHandler] update RTC
[eDVBLocalTimerHandler] time update to 03:10:12
[eDVBLocalTimerHandler] m_time_difference is -2
[eDVBLocalTimerHandler] set Linux Time
[EPGC] start cleanloop
++ 2/2 TID 4e
done!
[EPGC] stop cleanloop
[EPGC] 15320102 bytes for cache used
0012: 4e 0e 31 0f 00 00
VIDEO_GET_EVENT - ok
[AutoRes] got event evVideoSizeChanged
[AutoRes] determineContent
[EPGC] start caching events(1334970613)
[EPGC SKY] Valid Current: Tid 16a8 Nid fbff -> 0
[EPGC SKY] reading dictionary...
[EPGC SKY] reading channels from file
[EPGC SKY] found 568 channels
[EPGC SKY] reading themes from file
[EPGC SKY] found 224 themes
[EPGC SKY] start reading data...
BlackHoleapi: popshow,Found EPG data stream.
Updating cache in progress, don't change channel.
Reading Titles...
hdd IDLE!
[IDLE] 13590.0000439 300 True
sdt update done!
BlackHoleapi: popsettext,Found EPG data stream.
Reading Titles...
Found 8975 titles
[EPGC SKY] start 0x31 0xa0
[EPGC] abort non avail schedule reading
[EPGC] abort non avail schedule other reading
[EPGC] abort non avail viasat reading
[EPGC] nownext finished(1334970620)
Reading Titles...
Found 17949 titles
[EPGC SKY] start 0x32 0xa0
Reading Titles...
Found 26849 titles
[EPGC SKY] start 0x33 0xa0
Reading Titles...
Found 35738 titles
[EPGC SKY] start 0x34 0xa0
no ancillary data in audio stream... abort radiotext pes parser
Reading Titles...
Found 43863 titles
[EPGC SKY] start 0x35 0xa0
hdd IDLE!
[IDLE] 13619.9999869 300 True
It's now Sat Apr 21 03:11:04 2012
[timer.py] next activation: 1334970764 (in 99998 ms)
[EPGC] 15322815 bytes for cache used
hdd IDLE!
[IDLE] 13650.000051 300 True
It's now Sat Apr 21 03:11:37 2012
[timer.py] next activation: 1334970798 (in 99997 ms)
hdd IDLE!
[IDLE] 13679.9999731 300 True
[EPGC] 15322779 bytes for cache used
hdd IDLE!
[IDLE] 13709.999959 300 True
It's now Sat Apr 21 03:12:44 2012
[timer.py] next activation: 1334970864 (in 99997 ms)
hdd IDLE!
[IDLE] 13739.999979 300 True
hdd IDLE!
[IDLE] 13769.999979 300 True
It's now Sat Apr 21 03:13:18 2012
[timer.py] next activation: 1334970840 (in 41998 ms)
hdd IDLE!
[IDLE] 13799.9999609 300 True
It's now Sat Apr 21 03:14:00 2012
[TIMER] activating state 3
[TIMER] stop recording
ProcessRepeated
localrepeatedbegindate: Sat Apr 21 03:10:00 2012
localbegin: Sat Apr 21 03:10:00 2012
localend: Sat Apr 21 03:14:00 2012
localnow: Sat Apr 21 03:14:01 2012
Day: 0
Day: 1
Day: 2
Day: 3
Day: 4
Day: 5
Day: 6
localbegin after addOneDay: Sun Apr 22 03:10:00 2012
localend after addOneDay: Sun Apr 22 03:14:00 2012
ProcessRepeated result
[TIMER] record time changed, start prepare is now: Sun Apr 22 03:09:40 2012
ProcessRepeated
localbegin: Sun Apr 22 03:10:00 2012
localend: Sun Apr 22 03:14:00 2012
Day: 0
Day: 1
Day: 2
Day: 3
Day: 4
Day: 5
Day: 6
ProcessRepeated
Day: 0
Day: 1
Day: 2
Day: 3
Day: 4
Day: 5
Day: 6
ProcessRepeated
Day: 0
Day: 1
Day: 2
Day: 3
Day: 4
Day: 5
Day: 6
next real activation is Sun Apr 22 03:09:40 2012
[timer.py] next activation: 1334970940 (in 99950 ms)
[timer.py] next activation: 1334970940 (in 99949 ms)
[timer.py] next activation: 1334970940 (in 99947 ms)
[EPGC] 15322715 bytes for cache used
hdd IDLE!
[IDLE] 13829.9999471 300 True
It's now Sat Apr 21 03:14:24 2012
[timer.py] next activation: 1334970964 (in 99998 ms)
hdd IDLE!
[IDLE] 13860.000098 300 True
[EPGC] 15318918 bytes for cache used
hdd IDLE!
[IDLE] 13890.0001631 300 True
It's now Sat Apr 21 03:15:40 2012
[timer.py] next activation: 1334971040 (in 99998 ms)
hdd IDLE!
[IDLE] 13919.99999 300 True
It's now Sat Apr 21 03:16:04 2012
[timer.py] next activation: 1334971064 (in 99999 ms)
hdd IDLE!
[IDLE] 13949.999985 300 True
hdd IDLE!
[IDLE] 13979.9999459 300 True
[EPGC] 15318868 bytes for cache used
hdd IDLE!
[IDLE] 14010.000083 300 True
It's now Sat Apr 21 03:17:20 2012
[timer.py] next activation: 1334971140 (in 99997 ms)
It's now Sat Apr 21 03:17:44 2012
[timer.py] next activation: 1334971164 (in 99998 ms)
hdd IDLE!
[IDLE] 14039.9999549 300 True
hdd IDLE!
[IDLE] 14069.9999499 300 True
hdd IDLE!
[IDLE] 14099.9999509 300 True
It's now Sat Apr 21 03:19:00 2012
[timer.py] next activation: 1334971240 (in 99997 ms)
hdd IDLE!
[IDLE] 14129.9999568 300 True
It's now Sat Apr 21 03:19:24 2012
[timer.py] next activation: 1334971264 (in 99998 ms)
hdd IDLE!
[IDLE] 14159.999954 300 True
BlackHoleapi: extepg,Rytec_UPC_DIRECT,http://www.vuplus-community.net/rytec/magyar/epg.dat.gz
[EPGC] 37637 events read from /autofs/sdb1//epg.dat
[EPGC] store epg to realpath '/autofs/sdb1/epg.dat'
[EPGC] 158305 events written to /autofs/sdb1//epg.dat
BlackHoleapi: extepg,Rytec-SKYUK,http://www.vuplus-community.net/rytec/uk/epg.dat.gz
[EPGC] 155881 events read from /autofs/sdb1//epg.dat
[EPGC] 198428 events written to /autofs/sdb1//epg.dat
PC: 0047fde4
00000000 fffffffe 00000001 74ff00dd
00001522 00000001 00000001 00000001
00000001 00000000 00000001 00000001
00000001 000000e5 74ff00dd 76debca8
005c74b4 6f322718 0088a934 00000000
0003071c 7fbeff44 7fbeff48 7fbeff50
00000000 76d076b8 00000001 00000000
76df4960 7fbefef0 71afa7ac 0047fddc
As a final action, i will try to dump a bit of code.
I just hope that this won't crash.
0047fde4: 01 00 87 90 02 00 e5 24 50 18 11 0c 21 38 20 02 3c 19 11 0c 21 20 00 02 18 00 a6 8f 21 80 40 00 (end)
[EPGC] 22973249 bytes for cache used
</enigma2crashlog>
<pythonMD5sum>
<![CDATA[
ab2eef0ec82f8afbd8e5f6ed5128f02c /usr/lib/enigma2/python/Components/Keyboard.py
39f5958bd070caf59f8a4a7c9fab15cc /usr/lib/enigma2/python/Components/EpgList.py
4b27f5f16806fde8c7e6b0528082319f /usr/lib/enigma2/python/Components/Scanner.py
7be136b6d1eaa13aaa08832390bd53ca /usr/lib/enigma2/python/Components/Ipkg.py
fda2884a50d71cf31c89a54de97be5a2 /usr/lib/enigma2/python/Components/ResourceManager.py
ed446633b70188c44fcd2d4866044bbe /usr/lib/enigma2/python/Components/VideoWindow.py
cbc39aa5935ab3119f74e97329d4fef7 /usr/lib/enigma2/python/Components/SetupDevices.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/components.py
5889f4cb2010a42a5d03706dca477b0a /usr/lib/enigma2/python/Components/Renderer/Picon.py
c947108f65672842ac96be1bf179690f /usr/lib/enigma2/python/Components/Renderer/Pixmap.py
f43a627a5e8fb9b7a4a5ca67db7bb42a /usr/lib/enigma2/python/Components/Renderer/Progress.py
7dcaf7bebd1b96408b3b13f90a61d512 /usr/lib/enigma2/python/Components/Renderer/PositionGauge.py
aa1249c9a1ce56691a227df891da902b /usr/lib/enigma2/python/Components/Renderer/FrontpanelLed.py
7779d00ec0633251a4b83020ef55551a /usr/lib/enigma2/python/Components/Renderer/Label.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Renderer/__init__.py
1d37518d1e9e86746b3167f8aaed0945 /usr/lib/enigma2/python/Components/Renderer/Renderer.py
6395adaf7ec9bd78244c6f24baf7489f /usr/lib/enigma2/python/Components/Renderer/Listbox.py
fdc2c0963d41b40e55dcbb2bc34caeaa /usr/lib/enigma2/python/Components/Renderer/ChannelNumber.py
83384daaed9da756f7866d192d26b4b2 /usr/lib/enigma2/python/Components/Renderer/Canvas.py
307cbe1c7396024115dbf83e5b77ef53 /usr/lib/enigma2/python/Components/Renderer/Pig.py
ae4183381040270c96baa391d91fb26b /usr/lib/enigma2/python/Components/Renderer/Bhclock.py
7b0aa9b18eb25016e3b5b3f250281731 /usr/lib/enigma2/python/Components/Renderer/FixedLabel.py
c8379b1825bf04d51a8d0b2ca12d9f5c /usr/lib/enigma2/python/Components/Harddisk.py
295d6b590f174c8dd08a36d330a92352 /usr/lib/enigma2/python/Components/AVSwitch.py
b0e458255e15f1a8aec85f6288ef085d /usr/lib/enigma2/python/Components/Button.py
1c4cac0789e596a771af1c7d358f2f84 /usr/lib/enigma2/python/Components/Console.py
4a5d006fa9b187e5008608b1b89bbff0 /usr/lib/enigma2/python/Components/ActionMap.py
c49b29929b4e4162394dc2f7a8c772f8 /usr/lib/enigma2/python/Components/ScrollLabel.py
464c8a0e511dc879697d1a0d9766ef3c /usr/lib/enigma2/python/Components/Pixmap.py
bd1cad92310c93542e71ebbbce2798f7 /usr/lib/enigma2/python/Components/ServiceScan.py
6feeba1843947ec6baaeef017ad68230 /usr/lib/enigma2/python/Components/HTMLComponent.py
1f4cca2ae97c0322cc9e23acfca76276 /usr/lib/enigma2/python/Components/InputDevice.py
0750ee83cdf4bf9192a0f3d7b12218d1 /usr/lib/enigma2/python/Components/TimerList.py
58fee00295729a2adb7033bf68371de7 /usr/lib/enigma2/python/Components/Converter/ProgressToText.py
da60ed1a4fde0806990486a01bd727e9 /usr/lib/enigma2/python/Components/Converter/ClockToText.py
450c953359065349aac382f76b21fdae /usr/lib/enigma2/python/Components/Converter/Poll.py
c34a0a1a3f90265b36cbf8336ea7b7c1 /usr/lib/enigma2/python/Components/Converter/ConditionalShowHide.py
a6ecc808c0328a437c61eb2ade05bea6 /usr/lib/enigma2/python/Components/Converter/ServiceTime.py
15bea5fc9dbe47aac657be4a34439961 /usr/lib/enigma2/python/Components/Converter/Streaming.py
4078e76e1346d8f2a5e874efd2b904ac /usr/lib/enigma2/python/Components/Converter/RdsInfo.py
38362c2c04914861eb86b7a7d69afa4b /usr/lib/enigma2/python/Components/Converter/ServiceName.py
28dde32d3346086a1ec64dc3ee1627f9 /usr/lib/enigma2/python/Components/Converter/FrontendInfo.py
e90e83fd0a8fc7b634792ecd2a6edbda /usr/lib/enigma2/python/Components/Converter/StaticMultiList.py
17956139931985e8f54cb633cc1af8e4 /usr/lib/enigma2/python/Components/Converter/EventTime.py
87e4bbae4ce58464d0c7ca9319726cd7 /usr/lib/enigma2/python/Components/Converter/MovieInfo.py
ac89bc29566c391499126b1a6f4500f6 /usr/lib/enigma2/python/Components/Converter/EventName.py
3176888cde9c0efeed9ae52282e73dec /usr/lib/enigma2/python/Components/Converter/TemplatedMultiContent.py
87c95b795e765d0651b875064d114541 /usr/lib/enigma2/python/Components/Converter/ServicePosition.py
58b6e06f16433368d76847d3aba80372 /usr/lib/enigma2/python/Components/Converter/ValueToPixmap.py
dc9a4c4fc79c6e128e0179fc30d19895 /usr/lib/enigma2/python/Components/Converter/StringListSelection.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Converter/__init__.py
2c2d157ea7d28a4a43f20b6408ac0394 /usr/lib/enigma2/python/Components/Converter/TunerInfo.py
2f5e9df85dd9c531dcf62a3aab5ecfe1 /usr/lib/enigma2/python/Components/Converter/Combine.py
5d971edffdd2cd735683bb4c9093ef35 /usr/lib/enigma2/python/Components/Converter/ConfigEntryTest.py
088bd12c66a5fe4c2b87678e274fc13a /usr/lib/enigma2/python/Components/Converter/MenuEntryCompare.py
a7de7fb276c23533cff437f8c978a4af /usr/lib/enigma2/python/Components/Converter/StringList.py
b13c107d6ad058ba60856abcb94cb0c2 /usr/lib/enigma2/python/Components/Converter/BhAnalogic.py
af3845fb48965e926fd51a7439c85ee6 /usr/lib/enigma2/python/Components/Converter/Converter.py
4b8d476929f2c17190baf9d38fa70afc /usr/lib/enigma2/python/Components/Converter/SensorToText.py
73a07616a11fe77a022194d58b0940e7 /usr/lib/enigma2/python/Components/Converter/ValueRange.py
4c78fa5f5bf79d7fffe80a9a568043c0 /usr/lib/enigma2/python/Components/Converter/RemainingToText.py
919b568ec0ddeddd7798d2641e444c9e /usr/lib/enigma2/python/Components/Converter/StaticText.py
42b16b575d76c0e130ff3f007497d354 /usr/lib/enigma2/python/Components/Converter/ValueBitTest.py
212ed83b27cd52d0e697c09820e4fca3 /usr/lib/enigma2/python/Components/Converter/ServiceInfo.py
740cfba1ec935bde6fcf238d13cf103c /usr/lib/enigma2/python/Components/TimerSanityCheck.py
8bcf68f46c11af120dcfc5e51ee0e720 /usr/lib/enigma2/python/Components/Playlist.py
630323f4905e84479b1ba21efdc799bd /usr/lib/enigma2/python/Components/PluginComponent.py
6d4f8f7e30285110a59c0e30c62640fd /usr/lib/enigma2/python/Components/PerServiceDisplay.py
c498dfaa263d90bd6f75430b02ab7ee4 /usr/lib/enigma2/python/Components/MenuList.py
0660039b7b6e30b0f2274b222ead3741 /usr/lib/enigma2/python/Components/ConditionalWidget.py
9f0161d7c0504b6ef817767d2bed97d5 /usr/lib/enigma2/python/Components/Label.py
8a0fe43501d2ad168ea15b4b4f147b84 /usr/lib/enigma2/python/Components/ServicePosition.py
489d7215689628eec1890d5a943ff252 /usr/lib/enigma2/python/Components/Network.py
1bd1c3e110097a9e5e15b7a7ccd225ee /usr/lib/enigma2/python/Components/GUIComponent.py
4da8c35225b2dd62dacf3ad8099d9706 /usr/lib/enigma2/python/Components/PluginList.py
b0869deccb48eb53982607aef33c3978 /usr/lib/enigma2/python/Components/Gauge.py
0e01a1e3e304e69f8d1b89a8ef22cd31 /usr/lib/enigma2/python/Components/About.py
aef22114ab5ec5233d363994f8c87b6f /usr/lib/enigma2/python/Components/SystemInfo.py
d232dc74bc439432f3308bab607ad3ad /usr/lib/enigma2/python/Components/ServiceList.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/__init__.py
12c6615981e9b43e60c328fbc6fccffa /usr/lib/enigma2/python/Components/TunerInfo.py
2e48b88dedea0fba6d98d45e9327c74c /usr/lib/enigma2/python/Components/FileList.py
3684fc75e398c2a2046c627a81ef2158 /usr/lib/enigma2/python/Components/ConfigList.py
ee73da21a06410074bb749968c680955 /usr/lib/enigma2/python/Components/TuneTest.py
621d97b5ee0ac80cd3438111c04fb248 /usr/lib/enigma2/python/Components/HdmiCec.py
4fdc9ae13b1284850d6f4153d44213cf /usr/lib/enigma2/python/Components/ProgressBar.py
3b5dc0f7bf90523b8401499ae1c7aaec /usr/lib/enigma2/python/Components/VariableText.py
4bb6712fcb467e24fbe9f4aec3ca4f0a /usr/lib/enigma2/python/Components/FIFOList.py
a08636829f357ad582d52b123921b7ac /usr/lib/enigma2/python/Components/Lcd.py
293601b503ad89e0ebe9bc8ef85c9dd8 /usr/lib/enigma2/python/Components/MultiContent.py
3b2edd9b322ed121c8f2e88cf76fa11f /usr/lib/enigma2/python/Components/RecordingConfig.py
3bf2c3379296e6d363ef68553dbdaf80 /usr/lib/enigma2/python/Components/GUISkin.py
4bb39ca2744867c41ff9d4230599e144 /usr/lib/enigma2/python/Components/Input.py
0d707152124791c90b82fbc6e844918d /usr/lib/enigma2/python/Components/HTMLSkin.py
878322c744ce79649d47b8e599c01cdf /usr/lib/enigma2/python/Components/HelpMenuList.py
11000ec9591b9e5a9f5bed4037d2c91f /usr/lib/enigma2/python/Components/VolumeBar.py
fdd79c3bfa2aae2a5d0b6fe8951ce439 /usr/lib/enigma2/python/Components/Sensors.py
c9da57a45f2d4465e16b51dd994bc79e /usr/lib/enigma2/python/Components/DiskInfo.py
2e5c620136817ebddfa7b3331244113b /usr/lib/enigma2/python/Components/Task.py
b174c451a88f2af6795edf5336869a1d /usr/lib/enigma2/python/Components/UsageConfig.py
347cefa17014ec18aa905407bcd658b9 /usr/lib/enigma2/python/Components/ParentalControl.py
7d06bd081dd0e10b7019d8ac58708949 /usr/lib/enigma2/python/Components/Element.py
4e8cb8eab18839f731ce14062e3c54d6 /usr/lib/enigma2/python/Components/MediaPlayer.py
bc97eb5963b13419cfe4f1d9dc4a7c6f /usr/lib/enigma2/python/Components/DreamInfoHandler.py
455a470bf796884de3cf5886fbbdbdb8 /usr/lib/enigma2/python/Components/FanControl.py
be3e16f7afa1dca9e6a8804b6fd09bbe /usr/lib/enigma2/python/Components/SelectionList.py
6b97ff9a5291eb296cfcefc28ceaceef /usr/lib/enigma2/python/Components/VariableValue.py
9f73b7497ad108747f09bb672255f99f /usr/lib/enigma2/python/Components/ChoiceList.py
90d3d2dc3166c98afa087506e7974385 /usr/lib/enigma2/python/Components/MovieList.py
5fd0b525668837e2dfa5fe18c57d555d /usr/lib/enigma2/python/Components/config.py
f2edeec29b502db62369e2283816ead4 /usr/lib/enigma2/python/Components/Sources/Event.py
7c307f1c09f73fbd61de82c2e2544d3d /usr/lib/enigma2/python/Components/Sources/EventInfo.py
b2b638612aa61f66e5c729d969dc96b6 /usr/lib/enigma2/python/Components/Sources/RdsDecoder.py
47312dcaaea9e981b3e22b2363898485 /usr/lib/enigma2/python/Components/Sources/FrontendInfo.py
11bd6ef9d574ab79c97d9f5160cabece /usr/lib/enigma2/python/Components/Sources/CanvasSource.py
c2929a5e2de2d1b3a94e2c38cd7274c5 /usr/lib/enigma2/python/Components/Sources/Progress.py
78c43ab613a6166cf5858eb963ba62bd /usr/lib/enigma2/python/Components/Sources/Config.py
1da1958b336de06b874c9facb97d8e3e /usr/lib/enigma2/python/Components/Sources/ServiceEvent.py
5723d19be11ccbffd48502ade1010767 /usr/lib/enigma2/python/Components/Sources/List.py
6a85468d2ac38a7f37dbc5f73415ca8f /usr/lib/enigma2/python/Components/Sources/ServiceList.py
647e2f65fb79b2fae4a1c2ce5007b656 /usr/lib/enigma2/python/Components/Sources/CurrentService.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Sources/__init__.py
f68dc995f78cfc88e26483ea787746ab /usr/lib/enigma2/python/Components/Sources/TunerInfo.py
c6f7285e3f449c301dab92d92cfb1fce /usr/lib/enigma2/python/Components/Sources/FrontendStatus.py
ab296b833f2d34f06b5ac2a16c782df3 /usr/lib/enigma2/python/Components/Sources/Source.py
ce001a44e6f7098624a6df98c1c5761b /usr/lib/enigma2/python/Components/Sources/Boolean.py
3059a135ceb0c3fca0867698f21fc2b7 /usr/lib/enigma2/python/Components/Sources/StreamService.py
d421be00754d02d85df804e4faea908f /usr/lib/enigma2/python/Components/Sources/RecordState.py
b8b12180202bc1ca61007fd6b7ec7009 /usr/lib/enigma2/python/Components/Sources/StaticText.py
44460c27e2763fb358898dc34907c140 /usr/lib/enigma2/python/Components/Sources/Clock.py
56c35c1b2af81757e84913b3eb816e6e /usr/lib/enigma2/python/Components/Sources/Sensor.py
db075a06a00091ac91dfdaae6fc66e37 /usr/lib/enigma2/python/Components/language_cache.py
73fb7af94ab02923d0e8365be10a96a4 /usr/lib/enigma2/python/Components/ParentalControlList.py
5ca34b71f3b1f9f09d32a4a150498935 /usr/lib/enigma2/python/Components/Timezones.py
776023a14682d64e78dec7b3816a70fa /usr/lib/enigma2/python/Components/NimManager.py
62c655bbacc907e84cd14c4dc9972546 /usr/lib/enigma2/python/Components/BlinkingPixmap.py
ae9baee8c742036b23345f88e775a15f /usr/lib/enigma2/python/Components/Slider.py
b2fe45714c4a542dc0aea365aabd3bb1 /usr/lib/enigma2/python/Components/ServiceEventTracker.py
7f3b46d858f45c88bcadef484c575ae0 /usr/lib/enigma2/python/Components/VolumeControl.py
8a566189add219ba26e3204f2eb21164 /usr/lib/enigma2/python/Components/Language.py
2c1bd3117309881fef653c59d6d3b858 /usr/lib/enigma2/python/Components/RFmod.py
e8bead18b4228a4a687db72a02bf4642 /usr/lib/enigma2/python/enigma.py
cfac1258e71864b1ce1e0874fd70d854 /usr/lib/enigma2/python/Screens/LocationBox.py
b5bc1d71a6b661898d46e07c8152d592 /usr/lib/enigma2/python/Screens/Ipkg.py
6b68c3e2070a4cadf05548549a43c785 /usr/lib/enigma2/python/Screens/Globals.py
586378f913a22adf52d797d07007e082 /usr/lib/enigma2/python/Screens/MovieSelection.py
fce834ae8afec7499040564ca0fbc769 /usr/lib/enigma2/python/Screens/ChoiceBox.py
7310e742a9964659cfd356327cbb69ca /usr/lib/enigma2/python/Screens/VirtualKeyBoard.py
524fa9ce443eae4668e581cb996f7364 /usr/lib/enigma2/python/Screens/Console.py
fce7b5b85c883771f96287006d192a6a /usr/lib/enigma2/python/Screens/InfoBarGenerics.py
ca0361953b30f5fc919c4b77abfca0fb /usr/lib/enigma2/python/Screens/TextBox.py
9e74b7dc6b09beedc90c65e6d1c9a4f0 /usr/lib/enigma2/python/Screens/ServiceScan.py
5c836403cce8a029cdec5afa8538eb3c /usr/lib/enigma2/python/Screens/PiPSetup.py
4c7cdc559cb51a0281d41d4a3da63592 /usr/lib/enigma2/python/Screens/StartWizard.py
10cd614b1406b23db42fe1089e68f02d /usr/lib/enigma2/python/Screens/AudioSelection.py
262b973b6346f1669ad83e2c67400a09 /usr/lib/enigma2/python/Screens/PVRState.py
3c44a1bb0a6687a3e8c4decd65b9fa43 /usr/lib/enigma2/python/Screens/MinuteInput.py
21b0cca3002cf88fa8868bce113ab96c /usr/lib/enigma2/python/Screens/SessionGlobals.py
e7bc2feca9f12a9169bc74c79d034e65 /usr/lib/enigma2/python/Screens/TimerSelection.py
616e4f5f8d67699c3564ac495ea4e091 /usr/lib/enigma2/python/Screens/ClockDisplay.py
7a421281bce9b3cf7eff19fa38846588 /usr/lib/enigma2/python/Screens/Ci.py
0483593598ac40874d9835af4f481f4f /usr/lib/enigma2/python/Screens/PluginBrowser.py
2fbb9c8d85a3144ac01a5d09e5219a6e /usr/lib/enigma2/python/Screens/TutorialWizard.py
fafa8e1cdfb5c7994ec52f7a627e58bd /usr/lib/enigma2/python/Screens/HelpMenu.py
1d812b4508da64c54eaf3aafe30eb1c5 /usr/lib/enigma2/python/Screens/Rc.py
b0b2b95a755c5d9d15975fe028821f3e /usr/lib/enigma2/python/Screens/EventView.py
545ea24d09a21ebd6b017f21fb5fa057 /usr/lib/enigma2/python/Screens/About.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Screens/__init__.py
74dcf98e11a972d249ce5fd011b97cb8 /usr/lib/enigma2/python/Screens/SimpleSummary.py
15b19e6f30826c97c7fdfe0b35ad71c2 /usr/lib/enigma2/python/Screens/UnhandledKey.py
0b3c4ccb4532013a5732b25844bb0a6e /usr/lib/enigma2/python/Screens/Standby.py
dbad3ce42566c9367d69ebd84b992d04 /usr/lib/enigma2/python/Screens/LanguageSelection.py
d501bc67ff36572c521ab3bd01da6cca /usr/lib/enigma2/python/Screens/WizardLanguage.py
9fd6f2768180b538d3f35ce3e8cebcab /usr/lib/enigma2/python/Screens/SubtitleDisplay.py
e5a84350b94e7e7c27dc57fcd00dff1c /usr/lib/enigma2/python/Screens/TimerEntry.py
b9a77756078c56818cc88be575a4c4b2 /usr/lib/enigma2/python/Screens/ChannelSelection.py
2026309d4bb26a778822e85541918335 /usr/lib/enigma2/python/Screens/Volume.py
372ed995725f003f56e3f231e0b3636c /usr/lib/enigma2/python/Screens/HarddiskSetup.py
c5c0ac1908fd39967894d1044d32520f /usr/lib/enigma2/python/Screens/RecordPaths.py
8b6a8d2bd01d6f5e7f16dd47ace0d781 /usr/lib/enigma2/python/Screens/Subtitles.py
2c371a88055a052e82401b97646771e5 /usr/lib/enigma2/python/Screens/Mute.py
847c257750e4fe93757b8b617d23afe6 /usr/lib/enigma2/python/Screens/Wizard.py
910794de58e03cb7a9e68b5b15900fd5 /usr/lib/enigma2/python/Screens/InputBox.py
bccc795a82aab24bd114c264706fedeb /usr/lib/enigma2/python/Screens/TaskView.py
494d95e3c66df7ead1bf1adb38f7d2b1 /usr/lib/enigma2/python/Screens/Scart.py
f09c91475b4d47bac3112605a1d520e1 /usr/lib/enigma2/python/Screens/InputDeviceSetup.py
db2cc254ebc1a2806ad768c670bbd22b /usr/lib/enigma2/python/Screens/MessageBox.py
e59f49df2e8ff48a45fc865e24e63308 /usr/lib/enigma2/python/Screens/PictureInPicture.py
675e86c36c61c9174237b27b2d39aea1 /usr/lib/enigma2/python/Screens/Screen.py
97df74fc6b9b85c68624ef71e18177a1 /usr/lib/enigma2/python/Screens/SubservicesQuickzap.py
1caf3058700bdc87bc00c54f2a85eceb /usr/lib/enigma2/python/Screens/NumericalTextInputHelpDialog.py
cc48e2abc02be6319485ae5987791ebf /usr/lib/enigma2/python/Screens/Menu.py
a1887da61746d8c7b190c1f9a6f79a5e /usr/lib/enigma2/python/Screens/Dish.py
f49c2918da9b1870bac153faa8717f91 /usr/lib/enigma2/python/Screens/TimeDateInput.py
a6c418ca660943e42fa2b2c72b8c2f7e /usr/lib/enigma2/python/Screens/FactoryReset.py
ea3df01e230dfb0e76fe1f6b8755b247 /usr/lib/enigma2/python/Screens/TimerEdit.py
d8ab85121817e311e336d530942f4e0c /usr/lib/enigma2/python/Screens/FixedMenu.py
30ace57c455e7f9755a5d1738671ba62 /usr/lib/enigma2/python/Screens/ConfigMenu.py
a25013df9955e2429f2370543d4c721c /usr/lib/enigma2/python/Screens/SleepTimerEdit.py
4b4246ba0ca9bf6b3f9ea8cf788dc7aa /usr/lib/enigma2/python/Screens/ServiceStopScreen.py
03a45a3ec6fa65949569006c7f268909 /usr/lib/enigma2/python/Screens/Setup.py
5c995a40de39886c79d9fe3c3d45d7f7 /usr/lib/enigma2/python/Screens/RdsDisplay.py
36e0fcf670092264a9f0aaed484ae119 /usr/lib/enigma2/python/Screens/ScanSetup.py
2690da67e19ff3dc9c5bf2e9674c3353 /usr/lib/enigma2/python/Screens/ParentalControlSetup.py
aeab2785c1ada02f25a641d0d6e763f9 /usr/lib/enigma2/python/Screens/Satconfig.py
5190df554072e88200859f8c99096837 /usr/lib/enigma2/python/Screens/ServiceInfo.py
fc6897e9902bf59033e0c239da0a7d5f /usr/lib/enigma2/python/Screens/InfoBar.py
202a551180e1dfdcf4e7ae135d8de685 /usr/lib/enigma2/python/Screens/EpgSelection.py
32afe8c8ca5e3bb865af86a296951d12 /usr/lib/enigma2/python/Screens/DefaultWizard.py
979558d2dc1244af7c10b5bcb8c8bb76 /usr/lib/enigma2/python/Screens/NetworkSetup.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Blackhole/__init__.py
9d0761269aedda651639c75a21f15702 /usr/lib/enigma2/python/skin.py
0b4897696936a4c0799525c7f1e73166 /usr/lib/enigma2/python/timer.py
eb9426c13bfa9868aacb87f050a8c40e /usr/lib/enigma2/python/ServiceReference.py
27d752afe9f1f12d9732f09b6122ce3b /usr/lib/enigma2/python/mytest.py
c8cb7ffe121f512968813014bcabf0cd /usr/lib/enigma2/python/e2reactor.py
0ff6b1d31b6b25a6b7745658f179b22f /usr/lib/enigma2/python/RecordTimer.py
47611e868aaa72c9c0ca79c4810dbe97 /usr/lib/enigma2/python/Tools/Transponder.py
dbbb881f6c856e4cab017f518ba4a68a /usr/lib/enigma2/python/Tools/CList.py
8c8b3e4062f8e5e9c72cceac90320a2f /usr/lib/enigma2/python/Tools/Profile.py
fec44e3c680135b636adcbc71044cab4 /usr/lib/enigma2/python/Tools/Event.py
2bb2eab34660b5fcdf0b30f9bd1e8f44 /usr/lib/enigma2/python/Tools/Notifications.py
a0639de72e3006e1001f4bf549017bb9 /usr/lib/enigma2/python/Tools/Directories.py
fc8e1e93a7429fba50acb0261f7f5268 /usr/lib/enigma2/python/Tools/RedirectOutput.py
5e58ee8495c6b18b588e7c5b6069fa4c /usr/lib/enigma2/python/Tools/Downloader.py
cbe6d03d0dd9d165c8ec776c5c9adcce /usr/lib/enigma2/python/Tools/ASCIItranslit.py
a2218e726395499f00c72c393da3ba2c /usr/lib/enigma2/python/Tools/LoadPixmap.py
e3356c99fc63880d7cbe4495a03adb68 /usr/lib/enigma2/python/Tools/__init__.py
d9d83467815003e745113b9a16a1473d /usr/lib/enigma2/python/Tools/DreamboxHardware.py
b3422d679770a129342e52f6ca2978ad /usr/lib/enigma2/python/Tools/NumericalTextInput.py
a428aeab8edfef7d2dc4025084898ac4 /usr/lib/enigma2/python/Tools/HardwareInfo.py
b4011bd490319162c0bb7ab1fe0816f9 /usr/lib/enigma2/python/Tools/BoundFunction.py
c542bb10e8db238b1bd7cf3e2ca06aa9 /usr/lib/enigma2/python/Tools/XMLTools.py
9cb37012dc10aab1d5a6f0128093e9de /usr/lib/enigma2/python/Tools/KeyBindings.py
b59a24f3c4925c36ab2b5c20a47d70cd /usr/lib/enigma2/python/Tools/ISO639.py
09af65390e201fdc839573e5a5bc43f6 /usr/lib/enigma2/python/Tools/FuzzyDate.py
d364549956b3cfabe13d9b6b561232df /usr/lib/enigma2/python/Tools/Import.py
c96070e276dd1207f742dbb835016b02 /usr/lib/enigma2/python/Navigation.py
46cf5439c0702ae3d52adf1e0df028af /usr/lib/enigma2/python/NavigationInstance.py
2847ae9cd6ce7ef306501d30d1b675d3 /usr/lib/enigma2/python/SleepTimer.py
9ff38d1fbf23999885065144d273019f /usr/lib/enigma2/python/keyids.py
41d347a6305f5523347e1d4e7b5e9989 /usr/lib/enigma2/python/GlobalActions.py
3ca804f1c54bd4faaa654ebbe1c07795 /usr/lib/enigma2/python/keymapparser.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/DemoPlugins/__init__.py
c8ccccf312cc9a35d1f786f965d57b0b /usr/lib/enigma2/python/Plugins/Plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/CutListEditor/__init__.py
150f218b4461c255a04f694ad68dc75a /usr/lib/enigma2/python/Plugins/Extensions/CutListEditor/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/Tuxtxt/__init__.py
fd9ff9eca1e4c86996e811b95f8eb0e4 /usr/lib/enigma2/python/Plugins/Extensions/Tuxtxt/plugin.py
7e6ac492d7c340de570c705180c65f10 /usr/lib/enigma2/python/Plugins/Extensions/SHOUTcast/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/MediaScanner/__init__.py
2ae0e1640ea4267540f2922afab4eb5b /usr/lib/enigma2/python/Plugins/Extensions/MediaScanner/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhFullBackup/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/Pauli/__init__.py
34c021e4b8813fc6d303dbd84356a90e /usr/lib/enigma2/python/Plugins/Extensions/Pauli/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/__init__.py
7bf99b4b797254f0536fbd08fef66f6f /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/settings.py
d67f186f0a9ba8aba7955bb6598c6d2f /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhPersonalBackup/__init__.py
953c1e21d433a3140a6ba6c2b93cf472 /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/GraphMultiEpg.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/__init__.py
e495f59341b9d41c810732b50b001dc1 /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/__init__.py
9a25db3270b3d07b2ace5e8507c5e490 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/httpserver.py
d6595051d66380d7fec55d0e7e0d2c2b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/stream.py
73159b21f5ac4548264e3584f6984160 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/volume.py
bbe4eae7f0b32f9ad9c2db7118b883cf /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/services.py
7a1bd9220f6af26791b1ec5ac97c8b9c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/stream.py
a07579b1dc301e864165c54f28bbfe47 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/audiotrack.py
871ea5cb0e1bd584fbd83db7368e91e4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/control.py
35ab4e7a5f4d07dd928d963b2ba445c2 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/message.py
e23fce04e5d7fc99edccdf50eeb8770f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/movies.py
17e3c05bc3d0e2580dd496e698ff7ba9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/servicelist.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/__init__.py
9aa95c4894e783655f1736a4a8b1237a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/locations.py
52e18ddc7f485ec85ee180aea36ff629 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/info.py
e871f74a874316754c3a6f987ba77dff /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/grab.py
9040a7b9b5eea9e63550f4b7223a336d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/mediaplayer.py
80e63d0ce9778bf200182aa571a0ff49 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/plugins.py
afe4778db5673aeffbb7835ab1c8ed1a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/config.py
38102758c1cdd1b8f0d6a9d34de0592d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/timers.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/__init__.py
523263a2e5300bbba5b8a6be13d83925 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/file.py
b7d5d420140c0253db26b82938e974c1 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/external.py
07e35519dad0bd1bbf4d29ed40900ff7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/removelocation.py
46c0847939b90bb500658063f4e965a4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgsearchrss.py
792a10542f2e603ad2254b320ff4e717 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielisthtml.py
3effe3e305a2ec43124a764ddd10189e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerchange.py
e6dd3755070186f3e3e4c1243116b30a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getcurrlocation.py
056161a691a6cee62c6b11ec326605f5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/tvbrowser.py
869caf0b0b6f5cb9411115e512f8d6b3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayeradd.py
1c44830838ebca15bd447a5631b43594 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerwrite.py
9583c7250fbb8ab9cb607a1d1dd24d22 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getservices.py
3f45a2390f11f03cec588b2272f1fdb0 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerdelete.py
e5447d4866683ff5462b6111fa5b3523 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getpid.py
0ccb9e56e485c69c527a12bfd7ba7d86 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgnext.py
e1919bfaee20ee9e4f423da1b8a877c1 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayercmd.py
67cbc3a7a32ab62ee69cbb9d07399b91 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/messageanswer.py
94ab928aeb33af1f0fb846266eb30717 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgsearch.py
4508424ca660050fdc2402e12c65af37 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/parentcontrollist.py
6117f9306f797f083a6081632ee17751 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/restarttwisted.py
510c772ce848e38e2860214123eba447 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayercurrent.py
5071feb0b57c3f820807e35fb6f71532 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielistm3u.py
b05e837a37c82451a73cfa7a456825cc /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerremove.py
4c2e3c6134acfcc1c5fc871cdefd6a7d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerlistwrite.py
87bc339e276e1d942ffc4e712d5e3ad6 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgservice.py
517982ba91ea1c639724f311192217aa /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/currenttime.py
4e4b22beb74da102c5e84596a7840eba /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getcurrent.py
bbc00a2609e25d4861dae76d7624c0ea /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/message.py
d1c50c078e23a33cc87f289f850ecee0 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/gettags.py
699b2c20a6f931a05a66bf92cd98b9a4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/subservices.py
9f78bd6f52b05d258924494b3a88888d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/servicesm3u.py
ca5b3aea6bd17c20c381736dfbc1ca1f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timeradd.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/__init__.py
9efd90faa6fe857cb6da7cd8a592a109 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerlist.py
e16e25e86298b557a550376138c60a01 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/moviedelete.py
afde65d5221535e3857f1d304b7cf981 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getallservices.py
00d17ea149a03e9283a868b1dbef92ee /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgservicenow.py
ed78e51bc0293c6b16da568ad667166d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/streamsubservices.py
ea8fc549f527b285a49a1f37d4733c91 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgnow.py
1e8f8d757efe172e51dbfc0dd2212bdf /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/signal.py
fd59b94c3d3c74d70606b49c7d5b0626 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielist.py
416ed21c6a6ff6f006303c0a5d35dfda /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/recordnow.py
364d7fb39da8d86fbf42eab882bbdd48 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/servicelistreload.py
f80d419a431d847d695aa5c813882a97 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgsimilar.py
995c1f6f8188fe3f6cafe103e05dfde7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/about.py
6f7e3c07b2405c854d5da8351972693e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/deviceinfo.py
783e6f686ce9b54a82b3c45412363af6 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerload.py
5c02451b1dac62efeef74c9e57b08720 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/serviceplayable.py
a72e40f2580ccac965e459d0a64d5c36 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/pluginlistread.py
7af68c2c25804195abf411c0c998775b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgbouquet.py
db4a533a5ac7b1d319f98d49fe5a971b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timercleanup.py
efb5fa2051f48b56d480b9548a3146d5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timeraddbyeventid.py
94a982973498badfe41f1c76842a2834 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movietags.py
d99de400fec91cd8b7d68b8393ab5555 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getaudiotracks.py
658361727de0888d1dc67951e47c89cb /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/vol.py
60dc78337e6628af0b46c2b69c5a3041 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/powerstate.py
5121651fb1688bd749174ace23baf422 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/addlocation.py
a3dc445562b6245bcba7d32151f1079d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielistrss.py
536385a4d2df20e326ee7a8b01360c69 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getlocations.py
5169ebbaab1d83ad7a5c665041f669f7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/servicelistplayable.py
8012c3bd44e2ea6b10a96cf9f7b5ea4c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgmulti.py
f92f2ab1a1f30447d3f16422ca4df07c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/remotecontrol.py
318cf06f0406add243f4d3472df85cfb /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/sleeptimer.py
ad25bef72fcfd80f32ad330e5f3937fa /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerplay.py
d0903ad4813a2aee0a7d025d83b6556f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerlist.py
c847ab082841eaf16686f5a38a539af3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgservicenext.py
31cbf78282c44f9e0477a279753ba891 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/zap.py
2116c76d395136cbdd558da2ff4fc2a1 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/selectaudiotrack.py
a54dec530c673359acaa43bdcaaf634b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/channels.py
1c372a2d31b76fbb5821406294807140 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/satellites.py
3d3394faca63708613b7fff59380194e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/eventdescription.py
d400a1197fb667088867f19e74065451 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/workinprogress.py
260b8ac98e277bf9e7616d9ebddf21d5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/screenshot.py
eb1f7331afa4ffe402b29644aa5fb42c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/providers.py
af17916c5416a6969d7bf081afe311af /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/message.py
810023820cf1c45d19293fbb7924f744 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/movies.py
50a1870183d2547420b6e6c804c3727b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/radio.py
07f46c84c0d71f9582843ad6ecdf3261 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/current.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/__init__.py
5e5907bd755059c72f5feaa93db1e081 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/bouquets.py
21424c5952859908de81a05ad0bf84e3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/tv.py
301197426e3c268df3f0a5191bec7bd8 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/about.py
ef70761449c21c345e46ae69d0cfca7c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/epgpop.py
d121b0ebdebeb7d968adbb6bdf13b8a7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/powerstate.py
8403c011b999a45693bdd9b2f468bdbd /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/config.py
5d167f52dec1c82e6a94e764018ad286 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/boxinfo.py
fe9275cd9a35eef90de2f66e3df81f40 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/timers.py
0b7926a6332b30a35d1f02deb0f57bd8 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/index.py
5484d8b8d4bfb9d60780a9c890e98116 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/main.py
e6f26fabef6473412d1df5894bb895cf /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/channels.py
bf46c561b719099bdedbcc55b42c0bbe /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/index.py
a7d17aec654adeb6f3ee733ce399e248 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/screenshot.py
c8b591ba759223fc1a796ca5e41edee9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/control.py
01a2ec28e90d9e2280c81c2df9381937 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/satfinder.py
f3524c0438b0fbddfa9c4a6d22951b5d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/movies.py
337a262928b44e312db0cc0482165e11 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/bouquets.py
e96c9456ba59b5224821cce68eece708 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/about.py
5791f84d0b16b36e20ecfa40babc784e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/channelinfo.py
6e446d31c32d8d3d5ba45e77736efa5c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/timerlist.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/__init__.py
987a06b656e226b74be9e171a2a4cea2 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/ajax.py
cbc91347d1f5812c0f46051e516bacbc /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/ipkg.py
55bc36cb737dc0267f6e6bd2c6d697fa /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/api.py
4a5feda743918ca55fb033e408013e42 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/mobile.py
48a8ce127a29f41fe7e8da210437a5ec /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/web.py
8b7b6cc02ee3a8e6af622c361aa54b97 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/base.py
d03b8420bc6eabad19bbd921d3b48964 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/root.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/__init__.py
a10b27098a4d9ba8c1f827ee90a3609b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhEpgBackup/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/External/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/__init__.py
f66e93ef0623fc4838c3757df3159ebb /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/Toplevel.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/PicturePlayer/__init__.py
b72c7859893a76cafdfc32c65e1df0fb /usr/lib/enigma2/python/Plugins/Extensions/PicturePlayer/plugin.py
3f2553ad4f45959f17f2afdb617d8f45 /usr/lib/enigma2/python/Plugins/Extensions/MyTube/MyTubeSearch.py
c221d4bc9938619b19d98ce788e271f2 /usr/lib/enigma2/python/Plugins/Extensions/MyTube/MyTubeService.py
10e24c344b41265a6b7c75375757beca /usr/lib/enigma2/python/Plugins/Extensions/MyTube/__init__.py
a7872e255e6937e7121275943dae7ae3 /usr/lib/enigma2/python/Plugins/Extensions/MyTube/ThreadQueue.py
7c658f6b7edc9421bc8b09eae7ff8338 /usr/lib/enigma2/python/Plugins/Extensions/MyTube/plugin.py
377585531a915f167fd63413e6a09647 /usr/lib/enigma2/python/Plugins/Extensions/MeoBoot/ex_init.py
ab0a07e9fec70ae0abb9a1f539509a2b /usr/lib/enigma2/python/Plugins/Extensions/MeoBoot/__init__.py
347821af16abdec23873cff6941e8aeb /usr/lib/enigma2/python/Plugins/Extensions/VuplusEvent/vuplusauthenticity.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/VuplusEvent/__init__.py
a6e639c399ab1d0726f5dd7f197b91d8 /usr/lib/enigma2/python/Plugins/Extensions/VuplusEvent/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/Extensions/DVDPlayer/__init__.py
90e9e7de5a3a6937798701490c2c6c21 /usr/lib/enigma2/python/Plugins/Extensions/DVDPlayer/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BitrateViewer/__init__.py
e838d428b229c1ea40838a65a14a853c /usr/lib/enigma2/python/Plugins/Extensions/BitrateViewer/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/CommonInterfaceAssignment/__init__.py
a246ce4f2ff625bbecc9f64437f6197a /usr/lib/enigma2/python/Plugins/SystemPlugins/CommonInterfaceAssignment/plugin.py
2fac60170cdd3cc068dc058f582f3cb7 /usr/lib/enigma2/python/Plugins/SystemPlugins/FactoryTest/sctest.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/FactoryTest/__init__.py
fc770f90120448baa93f1b6f98962e08 /usr/lib/enigma2/python/Plugins/SystemPlugins/FactoryTest/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Satfinder/__init__.py
61f98a769c5ded0c8a64451697891120 /usr/lib/enigma2/python/Plugins/SystemPlugins/Satfinder/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/FPGAUpgrade/__init__.py
d6cbf11e182ddc88b99db8b02ee55e97 /usr/lib/enigma2/python/Plugins/SystemPlugins/FPGAUpgrade/plugin.py
5cd63078da8d66aa7081d64b74692f40 /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/SoftwareTools.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/__init__.py
b7c161d59170e825a894dec1d8b8c951 /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/ImageWizard.py
71bd9b4109a39ef3f2487eeefa42d0eb /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/plugin.py
d1e4f463eeb0272a2f86f40c3a77a7aa /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/BackupRestore.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/PositionerSetup/__init__.py
1440586470e4335ea4e9838d1c785379 /usr/lib/enigma2/python/Plugins/SystemPlugins/PositionerSetup/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Blindscan/__init__.py
6d8798cd51461ff8ce58bba0459cbe27 /usr/lib/enigma2/python/Plugins/SystemPlugins/Blindscan/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/BlackHoleApi/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Hotplug/__init__.py
d8f9b54aeb4984c2c49cb649196d3b30 /usr/lib/enigma2/python/Plugins/SystemPlugins/Hotplug/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/__init__.py
cfb9986cbbe4b74beaf0c1413f79bd19 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepglib.py
33e59bb91c77a56393b89d14bf4432f4 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_converter.py
5fbe402f3c67003c92c2b2f96861bf26 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_downloader.py
fad20b74cb80966a0985b23807372f2e /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_about.py
ab25a10ca1c6276dedd44a32802070ba /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_loader.py
2dcad2a8ed9782badaecbfd127441f29 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_main.py
4153403ed295cdd099ba056109e40ce7 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_locale.py
438360c99adf10d37bb2bb1aba2c06d0 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_xepgdb_update.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/__init__.py
a4579a396c439a2449dd9f0bff3df85f /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_auto.py
74457affa498021694ec972e3659f564 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_menu.py
1106bfab8a8ac81bbdfdc42525c42a26 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_ordering.py
13245153d2e1301eabb55634bb60732f /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_setup.py
c1debda1e760193f7e9a9c655b2c0f4b /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_info.py
ce2502ef4098977d59e2272f89c94664 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_providers.py
808b4ae437dd44abeceeff4fcb9892af /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/version.py
0571a881aed68645a3c8224b0f514c8f /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_rytec_update.py
4548e0dbbf15553d959498e7f81f7a4c /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_importer.py
0e72a14f8d25f355de48d645539790de /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/plugin.py
b70bb2961078b2dc8156f46281c0ff97 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/VideoEnhancement.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/__init__.py
556423529be882b7c105365bca27b25b /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/plugin.py
ca946826f2c188e52ea3c4262b60a2c7 /usr/lib/enigma2/python/Plugins/SystemPlugins/ManualFancontrol/InstandbyOn.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/ManualFancontrol/__init__.py
6a2c14392013d85591a83394e9172ad2 /usr/lib/enigma2/python/Plugins/SystemPlugins/ManualFancontrol/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/UIPositionSetup/__init__.py
f1e3281b7350cb7298f7cd60cfa58a3b /usr/lib/enigma2/python/Plugins/SystemPlugins/UIPositionSetup/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/__init__.py
8c0928a5e47d19cc605ec7fbb03199e8 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/NetworkWizard.py
a2008372ff89c62d07cb31e6a9de091f /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/plugin.py
2db4069db43044a52e20a46811b64164 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountEdit.py
44cca1ed648f0d92ba14d531d477c7db /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/AutoMount.py
6a352b0bfe8173ec89e5ce895b01eb6d /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountView.py
286db9f715fa9c074016e0132750128e /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/NetworkBrowser.py
7010636521d6a0183f317e43ace396e2 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/__init__.py
340b79e10fdf7e759e103704b12fa2a9 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountManager.py
19b45c6ada80382a72629591ba86580a /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/UserDialog.py
da2d19e7d6c97c2f645bd34ce7fa7ff8 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/plugin.py
2fd13d35fa6df0843208e85cfcf3bef7 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/UserManager.py
9f565e180deab436b5175874ee919ca6 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/VideoFinetune.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/__init__.py
6307b4f8a6952cfd3532bc8bed7cb817 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/RemoteControlCode/__init__.py
a989a3ffb767b37965df6af2ae43a996 /usr/lib/enigma2/python/Plugins/SystemPlugins/RemoteControlCode/plugin.py
1b7a6f60792410a7d6f101a9dd537ac1 /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/VideoHardware.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/__init__.py
d2d2d6d90b128e0f8221dd862d934081 /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/plugin.py
c954129f81aef46f117be2b995d919ba /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/VideoWizard.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/UI3DSetup/__init__.py
ec38cd4c1ba2fc739706822cb248ec04 /usr/lib/enigma2/python/Plugins/SystemPlugins/UI3DSetup/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/SkinSelector/__init__.py
1584d91b9c0e5c3cd70b8f3a9e655e04 /usr/lib/enigma2/python/Plugins/SystemPlugins/SkinSelector/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoResolution/__init__.py
31f058e8405b2b292ab9c0ed042ad783 /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoResolution/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessLanSetup/__init__.py
830034304c7e866b2671ef55e2b67273 /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessLanSetup/plugin.py
ecaa88f7fa0bf610a5a26cf545dcd3aa /usr/lib/enigma2/python/Plugins/SystemPlugins/HDMICEC/__init__.py
510365721a50d368d37aee98930c7453 /usr/lib/enigma2/python/Plugins/SystemPlugins/HDMICEC/plugin.py
943167eb90dc3145e1b9f61dbd098c3b /usr/lib/enigma2/python/tools.py
</pythonMD5sum>
</crashlogs>
</opendreambox>
Friends, i got crash even without the HDD conected. First the picture freezes, and the sound rolling more 5 seconds then it stops too. and i cant find the logical reason when its hapening, its randomly. maybe this is wrong unit, i cant show the log file, i dont know where it is now without HDD, tell me where it ism and i will show.
