Black Hole Vu+ Uno 1.7.4 Parallel Universes
Hi
Just flashed image and new to blackhole normally use vix.
Can anyone help with the following question
1. When I go to manage extensions is says 27 updates available. When I update now . It says installed upgraded 0.
2. How to setup EPG /crossepg
When I go to crossepg and setup 28.2 open tv and then download now it takes 10 mins to read,parsing summaries. I am storeing this on hdd. Is this normal ?
Also what is the difference between crossepg and setting up the EPG by pressing blue button then red and then picking sky uk ??
Thanks for a great image
1) there are updates from official vuplus feeds. BH doesen't need them and you should not apply them.
2) I use integrated BH EPG (Blue button -> Red Button).
For friends ubuntu / Linux users:
Use a single USB pendrive with two partitions, one for the universes and the other for picon (I have not tested MEOBOOT)
Ubuntu -> Disk Manager -> create two partitions on the pendrive in ext3 (on my 8GB pendrive I've created a 6 and one of 2) by assigning the label 1 to the first partition and 2 to the second partition.
On Vuplus (one in this case) from blue panel -> device manager -> Mountpoints (show only the first partition /dev/sdb1) -> mount it as / universe
On ubuntu with an FTP manager, I use FileZilla, connect to vuplus and go to /dev/disk/by-label checking that there are two folders in this case 1 and 2, like the two partitions. Then go to /etc and edit fstab so positioned on the file (on filezilla right click --> view/edit) and add the following line at the bottom: /dev/disk/by-label/2 /media/usb auto defaults 0 0
Save. So when you restart the decoder mount the second partition.
Copy the folder picon, with filezilla, in /media/usb.
And that's it!
thanks. can I mount my external HDD for universes and recording at the same time?
You could create two partitions and try it.
But I think it's not a good solution becouse when you use a parallel universe the hdd has to be always switched on.
Hi
1- Someone could help me select just the EPG for CanalPlus Astra on my HDD
2-Can i use the HDD for meoboot and EPG ???
Thx
Hi
Thx
R1- Try Canal+ GUIA ( Provider Digital+) or Canal+ (Provider CYFRA+)!
R2- Not Recommended!
@ Theva1
Either you plug a second usb stick and then you mount it as /media/usb
Either you apply the method described in post #105 ( 2 partitions)
Then Blue button , red button , red button --> save EPG on /media/usb
Then back to EPG settings
In the list choose CSAT and press yellow button to download.
Enjoy !
