Black Hole Vu+ Uno 1.7.4 Parallel Universes
Hi everyone,
i got a problem with my fresh BH 1.7.4 install : there is no way to use time shifting... When i press "pause" button i got a message "PauseDirect is not possible". So i tried to use the yellow button but then i got the BH Audio panel. Is there a way to time shifting???
Thx.
Hi everyone,
i respond to my previous post cause i found the solution : the path to record time shifting was wrong. It is the first time that i need to change it manualy in order to make time shifting working. :eek:
Maybe this could help for others.
Bye.
What 's about EPG ? Is it working fine ?
In crossEPG no French Rytech, it is impossible to have this provider after a download.
In EPG Panel, for Rytrec-CSAT, if i do a download the Gui crashes and restarts.
I try with the channel "GuideTV", sometime it works, sometime EPG is in a bad order.
Regards.
Then you should update the providers in CrossEPG or look a little bit better ;)
Rytec France is available in the XMLTV providers and the XEPGDB providers.
Look in your crashlog what causes the crash.
grt.
Regards.
Please post your Crash log!
Nothing is this CrossEPG Menu. I try to download these providers but nothing at the end.
It was ok with tle last BlackHole Image.
Crash log in EPG Menu for Rytech-Csat (blue key and red key)
<?xml version="1.0" encoding="utf-8"?>
<opendreambox>
<enigma2>
<crashdate>Tue May 22 09:22:13 2012</crashdate>
<compiledate>May 6 2012</compiledate>
<contactemail>crashlog</contactemail>
<skin>skin.xml</skin>
<sourcedate>May 6 2012</sourcedate>
<branch>vuplus_experimental</branch>
<rev></rev>
<version></version>
</enigma2>
<image>
<kernelcmdline>bmem=232M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync</kernelcmdline>
<imageversion>
<![CDATA[
version=1000201205071315
comment=Vuplus
target=9
creator=OpenEmbedded <oe@vuplus.com>
url=http://www.vuplus.com/
catalog=http://www.vuplus.com/
</imageversion>
<imageissue>
<![CDATA[
Vuplus 2.2.0 + BlackHole 1.7.4.0 %h
</imageissue>
</image>
<software>
<enigma2software>
<![CDATA[
enigma2 - experimental-git20110922-r31
enigma2-defaultservices - 1.0-r5
enigma2-meta - experimental-git20110922-r31
enigma2-plugin-extensions-cutlisteditor - experimental-git20110922-r31
enigma2-plugin-extensions-dvdplayer - experimental-git20110922-r31
enigma2-plugin-extensions-graphmultiepg - experimental-git20110922-r31
enigma2-plugin-extensions-mediaplayer - experimental-git20110922-r31
enigma2-plugin-extensions-mediascanner - experimental-git20110922-r31
enigma2-plugin-extensions-mytube - experimental-git20110215-r4
enigma2-plugin-extensions-openwebif - 0.1+git334+0b4221a-r0.71
enigma2-plugin-extensions-oscamstatus - 0.42-r0
enigma2-plugin-extensions-pictureplayer - experimental-git20110922-r31
enigma2-plugin-extensions-streamtv - experimental-git20110922-r31
enigma2-plugin-extensions-vuplusevent - experimental-git20110922-r31
enigma2-plugin-systemplugins-3gmodemmanager - experimental-git20110922-r31
enigma2-plugin-systemplugins-autoresolution - experimental-git20110215-r4
enigma2-plugin-systemplugins-blindscan - experimental-git20110922-r31
enigma2-plugin-systemplugins-commoninterfaceassignment - experimental-git20110922-r31
enigma2-plugin-systemplugins-factorytest - experimental-git20110922-r31
enigma2-plugin-systemplugins-fpgaupgrade - experimental-git20110922-r31
enigma2-plugin-systemplugins-hdmicec - experimental-git20110922-r31
enigma2-plugin-systemplugins-hotplug - experimental-git20110922-r31
enigma2-plugin-systemplugins-manualfancontrol - experimental-git20110922-r31
enigma2-plugin-systemplugins-networkbrowser - experimental-git20110215-r4
enigma2-plugin-systemplugins-networkwizard - experimental-git20110922-r31
enigma2-plugin-systemplugins-positionersetup - experimental-git20110922-r31
enigma2-plugin-systemplugins-remotecontrolcode - experimental-git20110922-r31
enigma2-plugin-systemplugins-satfinder - experimental-git20110922-r31
enigma2-plugin-systemplugins-skinselector - experimental-git20110922-r31
enigma2-plugin-systemplugins-softwaremanager - experimental-git20110922-r31
enigma2-plugin-systemplugins-ui3dsetup - experimental-git20110922-r31
enigma2-plugin-systemplugins-uipositionsetup - experimental-git20110922-r31
enigma2-plugin-systemplugins-videoenhancement - experimental-git20110922-r31
enigma2-plugin-systemplugins-videomode - experimental-git20110922-r31
enigma2-plugin-systemplugins-videotune - experimental-git20110922-r31
enigma2-plugin-systemplugins-wirelessaccesspoint - experimental-git20110922-r31
enigma2-plugin-systemplugins-wirelesslansetup - experimental-git20110922-r31
enigma2-plugins-meta - experimental-git20110215-r4
enigma2-skins-meta - experimental-git20110128-r0
enigma2-streamproxy - 1.0cvs20101014-r0
task-vuplus-enigma2 - 1.0-r18
</enigma2software>
<dreamboxsoftware>
<![CDATA[
libdreamdvd0 - 0.10+git20110129-r0
</dreamboxsoftware>
<gstreamersoftware>
<![CDATA[
gst-plugin-alsa - 0.10.35-r0.0
gst-plugin-apetag - 0.10.30-r0.0
gst-plugin-app - 0.10.35-r0.0
gst-plugin-audioconvert - 0.10.35-r0.0
gst-plugin-audioparsers - 0.10.30-r0.0
gst-plugin-audioresample - 0.10.35-r0.0
gst-plugin-autodetect - 0.10.30-r0.0
gst-plugin-avi - 0.10.30-r0.0
gst-plugin-cdio - 0.10.18-r0.0
gst-plugin-cdxaparse - 0.10.22-r0.2
gst-plugin-decodebin - 0.10.35-r0.0
gst-plugin-decodebin2 - 0.10.35-r0.0
gst-plugin-dvbmediasink - 0.10+git20110210-r1
gst-plugin-dvdsub - 0.10.18-r0.0
gst-plugin-flac - 0.10.30-r0.0
gst-plugin-flv - 0.10.30-r0.0
gst-plugin-fragmented - 0.10.22-r0.2
gst-plugin-icydemux - 0.10.30-r0.0
gst-plugin-id3demux - 0.10.30-r0.0
gst-plugin-isomp4 - 0.10.30-r0.0
gst-plugin-mad - 0.10.18-r0.0
gst-plugin-matroska - 0.10.30-r0.0
gst-plugin-mpegaudioparse - 0.10.18-r0.0
gst-plugin-mpegdemux - 0.10.22-r0.2
gst-plugin-mpegstream - 0.10.18-r0.0
gst-plugin-ogg - 0.10.35-r0.0
gst-plugin-playbin - 0.10.35-r0.0
gst-plugin-rtmp - 0.10.22-r0.2
gst-plugin-rtp - 0.10.30-r0.0
gst-plugin-rtpmanager - 0.10.30-r0.0
gst-plugin-rtsp - 0.10.30-r0.0
gst-plugin-souphttpsrc - 0.10.30-r0.0
gst-plugin-subparse - 0.10.35-r0.0
gst-plugin-typefindfunctions - 0.10.35-r0.0
gst-plugin-udp - 0.10.30-r0.0
gst-plugin-vcdsrc - 0.10.22-r0.2
gst-plugin-vorbis - 0.10.35-r0.0
gst-plugin-wavparse - 0.10.30-r0.0
gstreamer - 0.10.35-r0
libgstapp-0.10-0 - 0.10.35-r0.0
libgstaudio-0.10-0 - 0.10.35-r0.0
libgstcdda-0.10-0 - 0.10.35-r0.0
libgstinterfaces-0.10-0 - 0.10.35-r0.0
libgstnetbuffer-0.10-0 - 0.10.35-r0.0
libgstpbutils-0.10-0 - 0.10.35-r0.0
libgstriff-0.10-0 - 0.10.35-r0.0
libgstrtp-0.10-0 - 0.10.35-r0.0
libgstrtsp-0.10-0 - 0.10.35-r0.0
libgstsdp-0.10-0 - 0.10.35-r0.0
libgsttag-0.10-0 - 0.10.35-r0.0
libgstvideo-0.10-0 - 0.10.35-r0.0
</gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
_read 867 nr_write 307
sum 1174 prev_sum 1174
hdd IDLE!
[IDLE] 44507.216043 60 True
nr_read 867 nr_write 307
hdd IDLE!
[IDLE] 44513.2160859 60 True
hdd IDLE!
[IDLE] 44519.2162609 60 True
hdd IDLE!
[IDLE] 44525.2160978 60 True
hdd IDLE!
[IDLE] 44531.2161009 60 True
hdd IDLE!
[IDLE] 44537.2162549 60 True
hdd IDLE!
[IDLE] 44543.2163219 60 True
hdd IDLE!
[IDLE] 44549.2162149 60 True
hdd IDLE!
[IDLE] 44555.2160809 60 True
[EPGC] start cleanloop
[EPGC] stop cleanloop
[EPGC] 8085234 bytes for cache used
hdd IDLE!
[IDLE] 44561.2163148 60 True
hdd IDLE!
[IDLE] 44567.2163179 60 True
hdd IDLE!
[IDLE] 44573.2162828 60 True
hdd IDLE!
[IDLE] 44579.21612 60 True
hdd IDLE!
[IDLE] 44585.216234 60 True
hdd IDLE!
[IDLE] 44591.2160728 60 True
It's now Tue May 22 09:15:53 2012
[timer.py] next activation: 1337671054 (in 99999 ms)
It's now Tue May 22 09:15:54 2012
[timer.py] next activation: 1337671054 (in 99997 ms)
hdd IDLE!
[IDLE] 44597.2160919 60 True
hdd IDLE!
[IDLE] 44603.2160988 60 True
hdd IDLE!
[IDLE] 44609.216347 60 True
hdd IDLE!
[IDLE] 44615.2160969 60 True
hdd IDLE!
[IDLE] 44621.2161748 60 True
hdd IDLE!
[IDLE] 44627.2161639 60 True
hdd IDLE!
[IDLE] 44633.21628 60 True
hdd IDLE!
[IDLE] 44639.2162309 60 True
hdd IDLE!
[IDLE] 44645.2162838 60 True
hdd IDLE!
[IDLE] 44651.2162018 60 True
hdd IDLE!
[IDLE] 44657.2161069 60 True
action -> OkCancelActions ok
playing 1:0:1:2009:430:1:C00000:0:0:0:
[eDVBCAService] free slot 0 demux 0 for service 1:0:19:2275:438:1:C00000:0:0:0:
[eDVBCAService] free service 1:0:19:2275:438:1:C00000:0:0:0:
decoder state: play, vpid=-1, apid=-1
DEMUX_STOP - pcr - ok
DEMUX_STOP - video - ok
VIDEO_STOP - ok
AUDIO_STOP - ok
DEMUX_STOP - audio - ok
AUDIO_CONTINUE - ok
start release channel timer
not pauseable.
RemovePopup, id = ZapError
[eDVBCAService] remove channel 0x72b065c0
[eDVBLocalTimerHandler] remove channel 0x72b065c0
[eEPGCache] remove channel 0x72b065c0
allocate channel.. 0430:0001
[eDVBCAService] new channel 0x72b065c0!
(0)tune
RotorCmd ffffffff, lastRotorCmd ffffffff
prepare_sat System 0 Freq 11856000 Pol 1 SR 27500000 INV 2 FEC 3 orbpos 192 system 0 modulation 1 pilot 2, rolloff 0
tuning to 1256 mhz
OURSTATE: tuning
allocate Channel: res 0
[eDVBCIInterfaces] addPMTHandler 1:0:1:2009:430:1:C00000:0:0:0:
allocate demux
resolve: resolve ${sysconfdir}/scan_tp_valid_check.py
resolve: -> /etc/scan_tp_valid_check.py
[SEC] set static current limiting
set sequence pos 3
set sequence pos 3
[SEC] update current switch params
[SEC] startTuneTimeout 5000
[SEC] setFrontend 1
setting frontend 0
[SEC] sleep 500ms
(0)fe event: status 0, inversion on, m_tuning 1
BlackHoleapi: popclose,
(0)fe event: status 1f, inversion off, m_tuning 2
OURSTATE: ok
[eDVBCAService] channel 0x72b065c0 running
[eDVBLocalTimerHandler] channel 0x72b065c0 running
no version filtering
0014: 70 00 00 00 00 00
mask: fc 00 00 00 00 00
mode: 00 00 00 00 00 00
[eEPGCache] channel 0x72b065c0 running
stop release channel timer
[EPGC] next update in 2 sec
0012: 4e 20 09 00 00 00
mask: ff ff ff 00 00 00
ok ... now we start!!
0000: 00 00 00 00 00 00
mask: ff 00 00 00 00 00
eventNewProgramInfo 0 0
have 1 video stream(s) (00a0), and 1 audio stream(s) (0050), and the pcr pid is 00a0, and the text pid is 0020
allocate demux
disable teletext subtitles
decoder state: play, vpid=160, apid=80
DMX_SET_PES_FILTER(0xa0) - pcr - ok
DEMUX_START - pcr - ok
DMX_SET_PES_FILTER(0x50) - audio - ok
DEMUX_START - audio - ok
AUDIO_SET_BYPASS(1) - ok
AUDIO_PAUSE - ok
AUDIO_PLAY - ok
Video Device: /dev/dvb/adapter0/video0
demux device: /dev/dvb/adapter0/demux0
VIDEO_SET_STREAMTYPE 0 - ok
DMX_SET_PES_FILTER(0xa0) - video - ok
DEMUX_START - video - ok
VIDEO_FREEZE - ok
VIDEO_PLAY - ok
DMX_SET_PES_FILTER(0x20) - ttx - ok
DEMUX_START - ttx - ok
VIDEO_SLOWMOTION(0) - ok
VIDEO_FAST_FORWARD(0) - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
not pauseable.
[AutoRes] service changed
[SEC] set dynamic current limiting
[eDVBLocalTimerHandler] diff is 1
[eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
[eDVBLocalTimerHandler] update RTC
[eDVBLocalTimerHandler] time update to 09:17:02
[eDVBLocalTimerHandler] m_time_difference is 1
[eDVBLocalTimerHandler] set Linux Time
+ 1/1 TID 00
done!
PATready
use pmtpid 0500 for service_id 2009
0500: 02 20 09 00 00 00
doing version filtering
0000: 00 00 00 03 00 00
mask: ff 00 00 3f 00 00
mode: 00 00 00 3e 00 00
+- 1/2 TID 4e
+ 1/1 TID 02
done!
have 1 video stream(s) (00a0), and 4 audio stream(s) (0050, 0051, 0052, 004f), and the pcr pid is 00a0, and the text pid is 0020
[eDVBCAService] new service 1:0:1:2009:430:1:C00000:0:0:0:
[eDVBCAService] add demux 0 to slot 0 service 1:0:1:2009:430:1:C00000:0:0:0:
[eDVBCIInterfaces] gotPMT
demux 0 mask 01 prevhash 00000000
[eDVBCAService] send 480 bytes
9f 80 32 82 01 da 03 20 09 29 00 94 01 81 08 00 c0 00 00 04 30 00 01 82 02 01 00 84 02 05 00 09 07 18 11 f5 86 02 33 15 09 07 18 11 f5 88 02 33 17 09 0f 05 00 f9 71 10 01 01 13 01 20 14 03 02 26 10 09 0f 05 00 f9 72 10 01 01 13 01 20 14 03 04 0f 40 09 0f 05 00 f9 73 10 01 01 13 01 20 14 03 03 29 40 09 0f 05 00 f9 76 10 01 01 13 01 20 14 03 03 28 30 09 0f 05 00 f9 6f 10 01 01 13 01 20 14 03 04 33 30 09 0f 05 00 f9 75 10 01 01 13 01 20 14 03 03 0b 00 09 07 18 63 f5 8b 02 33 42 02 00 a0 00 32 01 09 2f 01 00 f5 89 a8 25 ff 00 00 00 00 00 40 00 06 2c b6 f5 88 33 17 ff 00 08 08 00 00 00 00 2a 2c b6 f5 86 33 15 ff 00 00 0c 00 00 00 00 06 2c b6 04 00 50 00 32 01 09 2f 01 00 f5 89 a8 25 ff 00 00 00 00 00 40 00 06 2c b6 f5 88 33 17 ff 00 08 08 00 00 00 00 2a 2c b6 f5 86 33 15 ff 00 00 0c 00 00 00 00 06 2c b6 04 00 51 00 32 01 09 2f 01 00 f5 89 a8 25 ff 00 00 00 00 00 40 00 06 2c b6 f5 88 33 17 ff 00 08 08 00 00 00 00 2a 2c b6 f5 86 33 15 ff 00 00 0c 00 00 00 00 06 2c b6 06 00 20 00 00 06 00 52 00 32 01 09 2f 01 00 f5 89 a8 25 ff 00 00 00 00 00 40 00 06 2c b6 f5 88 33 17 ff 00 08 08 00 00 00 00 2a 2c b6 f5 86 33 15 ff 00 00 0c 00 00 00 00 06 2c b6 c0 00 d0 00 00 c0 00 86 00 00 c1 00 cd 00 00 c1 00 e3 00 00 c1 04 e5 00 00 c1 02 32 00 00 c1 04 e7 00 00 03 00 4f 00 32 01 09 2f 01 00 f5 89 a8 25 ff 00 00 00 00 00 40 00 06 2c b6 f5 88 33 17 ff 00 08 08 00 00 00 00 2a 2c b6 f5 86 33 15 ff 00 00 0c 00 00 00 00 06 2c b6 c0 02 fe 00 00
0500: 02 20 09 29 00 00
mask: ff ff ff 3f 00 00
[AutoRes] determineContent
sdt update done!
++ 2/2 TID 4e
done!
0012: 4e 20 09 37 00 00
[EPGC] start caching events(1337671024)
VIDEO_GET_EVENT - ok
[AutoRes] got event evVideoSizeChanged
hdd IDLE!
[IDLE] 44664.2161889 60 True
action -> InfobarExtensions extensions
unknown action InfobarExtensions/extensions! typo in keymap?
[EPGC] abort non avail schedule reading
[EPGC] abort non avail schedule other reading
[EPGC] abort non avail viasat reading
[EPGC] abort non avail mhw reading
[EPGC] nownext finished(1337671031)
[EPGC] stop caching events(1337671031)
[EPGC] next update in 60 min
hdd IDLE!
[IDLE] 44670.2160809 60 True
action -> WizardActions down
action -> DirectionActions downUp
unknown action DirectionActions/downUp! typo in keymap?
hdd IDLE!
[IDLE] 44676.2160959 60 True
action -> WizardActions ok
allocating new converter!
reused converter!
reused converter!
no ancillary data in audio stream... abort radiotext pes parser
hdd IDLE!
[IDLE] 44682.2161009 60 True
action -> InputActions right
action -> InputActions left
hdd IDLE!
[IDLE] 44688.2160828 60 True
It's now Tue May 22 09:17:35 2012
[timer.py] next activation: 1337671155 (in 99998 ms)
[timer.py] next activation: 1337671155 (in 99996 ms)
hdd IDLE!
[IDLE] 44694.2160819 60 True
hdd IDLE!
[IDLE] 44700.2160978 60 True
hdd IDLE!
[IDLE] 44706.2160969 60 True
action -> OkCancelActions cancel
hdd IDLE!
[IDLE] 44712.2762969 60 True
hdd IDLE!
[IDLE] 44718.2161019 60 True
[EPGC] 8088671 bytes for cache used
hdd IDLE!
[IDLE] 44724.2160778 60 True
action -> InfobarSubserviceSelectionActions DeliteGpshow
reused converter!
reused converter!
reused converter!
reused converter!
hdd IDLE!
[IDLE] 44730.6576278 60 True
action -> WizardActions back
hdd IDLE!
[IDLE] 44736.216079 60 True
hdd IDLE!
[IDLE] 44742.2160928 60 True
hdd IDLE!
[IDLE] 44748.216095 60 True
action -> InfobarChannelSelection openServiceList
reused converter!
reused converter!
reused converter!
reused converter!
hdd IDLE!
[IDLE] 44754.2160769 60 True
hdd IDLE!
[IDLE] 44760.2160769 60 True
hdd IDLE!
[IDLE] 44766.2160728 60 True
action -> InfobarExtensions BhRedpshow
unknown action InfobarExtensions/BhRedpshow! typo in keymap?
hdd IDLE!
[IDLE] 44772.2161019 60 True
hdd IDLE!
[IDLE] 44778.2161989 60 True
hdd IDLE!
[IDLE] 44784.2161038 60 True
hdd IDLE!
[IDLE] 44790.2161088 60 True
It's now Tue May 22 09:19:15 2012
[timer.py] next activation: 1337671255 (in 99999 ms)
[timer.py] next activation: 1337671255 (in 99997 ms)
hdd IDLE!
[IDLE] 44796.2160778 60 True
hdd IDLE!
[IDLE] 44802.2160978 60 True
hdd IDLE!
[IDLE] 44808.2523239 60 True
hdd IDLE!
[IDLE] 44814.216079 60 True
hdd IDLE!
[IDLE] 44820.2160828 60 True
hdd IDLE!
[IDLE] 44826.216094 60 True
hdd IDLE!
[IDLE] 44832.216105 60 True
hdd IDLE!
[IDLE] 44838.2160869 60 True
[EPGC] 8082332 bytes for cache used
hdd IDLE!
[IDLE] 44844.2161009 60 True
hdd IDLE!
[IDLE] 44850.216079 60 True
hdd IDLE!
[IDLE] 44856.2160919 60 True
hdd IDLE!
[IDLE] 44862.2160819 60 True
hdd IDLE!
[IDLE] 44868.2160819 60 True
hdd IDLE!
[IDLE] 44874.216094 60 True
hdd IDLE!
[IDLE] 44880.216089 60 True
hdd IDLE!
[IDLE] 44886.2161 60 True
hdd IDLE!
[IDLE] 44892.2160769 60 True
It's now Tue May 22 09:20:55 2012
[timer.py] next activation: 1337671355 (in 99998 ms)
[timer.py] next activation: 1337671355 (in 99997 ms)
hdd IDLE!
[IDLE] 44898.2161069 60 True
[EPGC] 8082276 bytes for cache used
action -> InfobarExtensions DeliteBpshow
reused converter!
reused converter!
reused converter!
reused converter!
action -> ColorActions red
reused converter!
reused converter!
reused converter!
hdd IDLE!
[IDLE] 44904.274349 60 True
hdd IDLE!
[IDLE] 44910.2160988 60 True
reused converter!
reused converter!
reused converter!
action -> ColorActions yellow
main thread is non-idle! display spinner!
[EPGC] 244664 events read from /media/usb/epg.dat
[EPGC] store epg to realpath '/media/usb/epg.dat'
[EPGC] 165923 events written to /media/usb/epg.dat
PC: 0047fde4
00000000 fffffffe 00000001 72d1cf2c
03000006 00000001 00000001 00000001
00000001 00000000 00000001 00000001
00000001 00000005 72d1cf2c 77513ca8
005c74b4 75a488b8 007b1f24 00000000
00028823 7fc26d0c 7fc26d10 7fc26d18
00000000 7742f6b8 00000001 00000000
7751c960 7fc26cb8 7368ef9c 0047fddc
As a final action, i will try to dump a bit of code.
I just hope that this won't crash.
0047fde4: 01 00 87 90 02 00 e5 24 50 18 11 0c 21 38 20 02 3c 19 11 0c 21 20 00 02 18 00 a6 8f 21 80 40 00 (end)
</enigma2crashlog>
<pythonMD5sum>
<![CDATA[
ab2eef0ec82f8afbd8e5f6ed5128f02c /usr/lib/enigma2/python/Components/Keyboard.py
39f5958bd070caf59f8a4a7c9fab15cc /usr/lib/enigma2/python/Components/EpgList.py
4b27f5f16806fde8c7e6b0528082319f /usr/lib/enigma2/python/Components/Scanner.py
7be136b6d1eaa13aaa08832390bd53ca /usr/lib/enigma2/python/Components/Ipkg.py
fda2884a50d71cf31c89a54de97be5a2 /usr/lib/enigma2/python/Components/ResourceManager.py
ed446633b70188c44fcd2d4866044bbe /usr/lib/enigma2/python/Components/VideoWindow.py
cbc39aa5935ab3119f74e97329d4fef7 /usr/lib/enigma2/python/Components/SetupDevices.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/components.py
5889f4cb2010a42a5d03706dca477b0a /usr/lib/enigma2/python/Components/Renderer/Picon.py
c947108f65672842ac96be1bf179690f /usr/lib/enigma2/python/Components/Renderer/Pixmap.py
f43a627a5e8fb9b7a4a5ca67db7bb42a /usr/lib/enigma2/python/Components/Renderer/Progress.py
7dcaf7bebd1b96408b3b13f90a61d512 /usr/lib/enigma2/python/Components/Renderer/PositionGauge.py
aa1249c9a1ce56691a227df891da902b /usr/lib/enigma2/python/Components/Renderer/FrontpanelLed.py
7779d00ec0633251a4b83020ef55551a /usr/lib/enigma2/python/Components/Renderer/Label.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Renderer/__init__.py
1d37518d1e9e86746b3167f8aaed0945 /usr/lib/enigma2/python/Components/Renderer/Renderer.py
6395adaf7ec9bd78244c6f24baf7489f /usr/lib/enigma2/python/Components/Renderer/Listbox.py
fdc2c0963d41b40e55dcbb2bc34caeaa /usr/lib/enigma2/python/Components/Renderer/ChannelNumber.py
83384daaed9da756f7866d192d26b4b2 /usr/lib/enigma2/python/Components/Renderer/Canvas.py
307cbe1c7396024115dbf83e5b77ef53 /usr/lib/enigma2/python/Components/Renderer/Pig.py
ae4183381040270c96baa391d91fb26b /usr/lib/enigma2/python/Components/Renderer/Bhclock.py
7b0aa9b18eb25016e3b5b3f250281731 /usr/lib/enigma2/python/Components/Renderer/FixedLabel.py
c8379b1825bf04d51a8d0b2ca12d9f5c /usr/lib/enigma2/python/Components/Harddisk.py
295d6b590f174c8dd08a36d330a92352 /usr/lib/enigma2/python/Components/AVSwitch.py
b0e458255e15f1a8aec85f6288ef085d /usr/lib/enigma2/python/Components/Button.py
1c4cac0789e596a771af1c7d358f2f84 /usr/lib/enigma2/python/Components/Console.py
4a5d006fa9b187e5008608b1b89bbff0 /usr/lib/enigma2/python/Components/ActionMap.py
c49b29929b4e4162394dc2f7a8c772f8 /usr/lib/enigma2/python/Components/ScrollLabel.py
464c8a0e511dc879697d1a0d9766ef3c /usr/lib/enigma2/python/Components/Pixmap.py
bd1cad92310c93542e71ebbbce2798f7 /usr/lib/enigma2/python/Components/ServiceScan.py
6feeba1843947ec6baaeef017ad68230 /usr/lib/enigma2/python/Components/HTMLComponent.py
1f4cca2ae97c0322cc9e23acfca76276 /usr/lib/enigma2/python/Components/InputDevice.py
0750ee83cdf4bf9192a0f3d7b12218d1 /usr/lib/enigma2/python/Components/TimerList.py
58fee00295729a2adb7033bf68371de7 /usr/lib/enigma2/python/Components/Converter/ProgressToText.py
da60ed1a4fde0806990486a01bd727e9 /usr/lib/enigma2/python/Components/Converter/ClockToText.py
450c953359065349aac382f76b21fdae /usr/lib/enigma2/python/Components/Converter/Poll.py
c34a0a1a3f90265b36cbf8336ea7b7c1 /usr/lib/enigma2/python/Components/Converter/ConditionalShowHide.py
a6ecc808c0328a437c61eb2ade05bea6 /usr/lib/enigma2/python/Components/Converter/ServiceTime.py
15bea5fc9dbe47aac657be4a34439961 /usr/lib/enigma2/python/Components/Converter/Streaming.py
4078e76e1346d8f2a5e874efd2b904ac /usr/lib/enigma2/python/Components/Converter/RdsInfo.py
38362c2c04914861eb86b7a7d69afa4b /usr/lib/enigma2/python/Components/Converter/ServiceName.py
28dde32d3346086a1ec64dc3ee1627f9 /usr/lib/enigma2/python/Components/Converter/FrontendInfo.py
e90e83fd0a8fc7b634792ecd2a6edbda /usr/lib/enigma2/python/Components/Converter/StaticMultiList.py
17956139931985e8f54cb633cc1af8e4 /usr/lib/enigma2/python/Components/Converter/EventTime.py
87e4bbae4ce58464d0c7ca9319726cd7 /usr/lib/enigma2/python/Components/Converter/MovieInfo.py
ac89bc29566c391499126b1a6f4500f6 /usr/lib/enigma2/python/Components/Converter/EventName.py
3176888cde9c0efeed9ae52282e73dec /usr/lib/enigma2/python/Components/Converter/TemplatedMultiContent.py
87c95b795e765d0651b875064d114541 /usr/lib/enigma2/python/Components/Converter/ServicePosition.py
58b6e06f16433368d76847d3aba80372 /usr/lib/enigma2/python/Components/Converter/ValueToPixmap.py
dc9a4c4fc79c6e128e0179fc30d19895 /usr/lib/enigma2/python/Components/Converter/StringListSelection.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Converter/__init__.py
2c2d157ea7d28a4a43f20b6408ac0394 /usr/lib/enigma2/python/Components/Converter/TunerInfo.py
2f5e9df85dd9c531dcf62a3aab5ecfe1 /usr/lib/enigma2/python/Components/Converter/Combine.py
5d971edffdd2cd735683bb4c9093ef35 /usr/lib/enigma2/python/Components/Converter/ConfigEntryTest.py
088bd12c66a5fe4c2b87678e274fc13a /usr/lib/enigma2/python/Components/Converter/MenuEntryCompare.py
a7de7fb276c23533cff437f8c978a4af /usr/lib/enigma2/python/Components/Converter/StringList.py
b13c107d6ad058ba60856abcb94cb0c2 /usr/lib/enigma2/python/Components/Converter/BhAnalogic.py
af3845fb48965e926fd51a7439c85ee6 /usr/lib/enigma2/python/Components/Converter/Converter.py
4b8d476929f2c17190baf9d38fa70afc /usr/lib/enigma2/python/Components/Converter/SensorToText.py
73a07616a11fe77a022194d58b0940e7 /usr/lib/enigma2/python/Components/Converter/ValueRange.py
4c78fa5f5bf79d7fffe80a9a568043c0 /usr/lib/enigma2/python/Components/Converter/RemainingToText.py
919b568ec0ddeddd7798d2641e444c9e /usr/lib/enigma2/python/Components/Converter/StaticText.py
42b16b575d76c0e130ff3f007497d354 /usr/lib/enigma2/python/Components/Converter/ValueBitTest.py
212ed83b27cd52d0e697c09820e4fca3 /usr/lib/enigma2/python/Components/Converter/ServiceInfo.py
740cfba1ec935bde6fcf238d13cf103c /usr/lib/enigma2/python/Components/TimerSanityCheck.py
8bcf68f46c11af120dcfc5e51ee0e720 /usr/lib/enigma2/python/Components/Playlist.py
630323f4905e84479b1ba21efdc799bd /usr/lib/enigma2/python/Components/PluginComponent.py
6d4f8f7e30285110a59c0e30c62640fd /usr/lib/enigma2/python/Components/PerServiceDisplay.py
c498dfaa263d90bd6f75430b02ab7ee4 /usr/lib/enigma2/python/Components/MenuList.py
0660039b7b6e30b0f2274b222ead3741 /usr/lib/enigma2/python/Components/ConditionalWidget.py
9f0161d7c0504b6ef817767d2bed97d5 /usr/lib/enigma2/python/Components/Label.py
8a0fe43501d2ad168ea15b4b4f147b84 /usr/lib/enigma2/python/Components/ServicePosition.py
489d7215689628eec1890d5a943ff252 /usr/lib/enigma2/python/Components/Network.py
1bd1c3e110097a9e5e15b7a7ccd225ee /usr/lib/enigma2/python/Components/GUIComponent.py
4da8c35225b2dd62dacf3ad8099d9706 /usr/lib/enigma2/python/Components/PluginList.py
b0869deccb48eb53982607aef33c3978 /usr/lib/enigma2/python/Components/Gauge.py
0e01a1e3e304e69f8d1b89a8ef22cd31 /usr/lib/enigma2/python/Components/About.py
aef22114ab5ec5233d363994f8c87b6f /usr/lib/enigma2/python/Components/SystemInfo.py
d232dc74bc439432f3308bab607ad3ad /usr/lib/enigma2/python/Components/ServiceList.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/__init__.py
12c6615981e9b43e60c328fbc6fccffa /usr/lib/enigma2/python/Components/TunerInfo.py
2e48b88dedea0fba6d98d45e9327c74c /usr/lib/enigma2/python/Components/FileList.py
3684fc75e398c2a2046c627a81ef2158 /usr/lib/enigma2/python/Components/ConfigList.py
ee73da21a06410074bb749968c680955 /usr/lib/enigma2/python/Components/TuneTest.py
621d97b5ee0ac80cd3438111c04fb248 /usr/lib/enigma2/python/Components/HdmiCec.py
4fdc9ae13b1284850d6f4153d44213cf /usr/lib/enigma2/python/Components/ProgressBar.py
3b5dc0f7bf90523b8401499ae1c7aaec /usr/lib/enigma2/python/Components/VariableText.py
4bb6712fcb467e24fbe9f4aec3ca4f0a /usr/lib/enigma2/python/Components/FIFOList.py
a08636829f357ad582d52b123921b7ac /usr/lib/enigma2/python/Components/Lcd.py
293601b503ad89e0ebe9bc8ef85c9dd8 /usr/lib/enigma2/python/Components/MultiContent.py
3b2edd9b322ed121c8f2e88cf76fa11f /usr/lib/enigma2/python/Components/RecordingConfig.py
3bf2c3379296e6d363ef68553dbdaf80 /usr/lib/enigma2/python/Components/GUISkin.py
4bb39ca2744867c41ff9d4230599e144 /usr/lib/enigma2/python/Components/Input.py
0d707152124791c90b82fbc6e844918d /usr/lib/enigma2/python/Components/HTMLSkin.py
878322c744ce79649d47b8e599c01cdf /usr/lib/enigma2/python/Components/HelpMenuList.py
11000ec9591b9e5a9f5bed4037d2c91f /usr/lib/enigma2/python/Components/VolumeBar.py
fdd79c3bfa2aae2a5d0b6fe8951ce439 /usr/lib/enigma2/python/Components/Sensors.py
c9da57a45f2d4465e16b51dd994bc79e /usr/lib/enigma2/python/Components/DiskInfo.py
2e5c620136817ebddfa7b3331244113b /usr/lib/enigma2/python/Components/Task.py
b174c451a88f2af6795edf5336869a1d /usr/lib/enigma2/python/Components/UsageConfig.py
347cefa17014ec18aa905407bcd658b9 /usr/lib/enigma2/python/Components/ParentalControl.py
7d06bd081dd0e10b7019d8ac58708949 /usr/lib/enigma2/python/Components/Element.py
4e8cb8eab18839f731ce14062e3c54d6 /usr/lib/enigma2/python/Components/MediaPlayer.py
bc97eb5963b13419cfe4f1d9dc4a7c6f /usr/lib/enigma2/python/Components/DreamInfoHandler.py
455a470bf796884de3cf5886fbbdbdb8 /usr/lib/enigma2/python/Components/FanControl.py
be3e16f7afa1dca9e6a8804b6fd09bbe /usr/lib/enigma2/python/Components/SelectionList.py
6b97ff9a5291eb296cfcefc28ceaceef /usr/lib/enigma2/python/Components/VariableValue.py
9f73b7497ad108747f09bb672255f99f /usr/lib/enigma2/python/Components/ChoiceList.py
90d3d2dc3166c98afa087506e7974385 /usr/lib/enigma2/python/Components/MovieList.py
5fd0b525668837e2dfa5fe18c57d555d /usr/lib/enigma2/python/Components/config.py
f2edeec29b502db62369e2283816ead4 /usr/lib/enigma2/python/Components/Sources/Event.py
7c307f1c09f73fbd61de82c2e2544d3d /usr/lib/enigma2/python/Components/Sources/EventInfo.py
b2b638612aa61f66e5c729d969dc96b6 /usr/lib/enigma2/python/Components/Sources/RdsDecoder.py
47312dcaaea9e981b3e22b2363898485 /usr/lib/enigma2/python/Components/Sources/FrontendInfo.py
11bd6ef9d574ab79c97d9f5160cabece /usr/lib/enigma2/python/Components/Sources/CanvasSource.py
c2929a5e2de2d1b3a94e2c38cd7274c5 /usr/lib/enigma2/python/Components/Sources/Progress.py
78c43ab613a6166cf5858eb963ba62bd /usr/lib/enigma2/python/Components/Sources/Config.py
1da1958b336de06b874c9facb97d8e3e /usr/lib/enigma2/python/Components/Sources/ServiceEvent.py
5723d19be11ccbffd48502ade1010767 /usr/lib/enigma2/python/Components/Sources/List.py
6a85468d2ac38a7f37dbc5f73415ca8f /usr/lib/enigma2/python/Components/Sources/ServiceList.py
647e2f65fb79b2fae4a1c2ce5007b656 /usr/lib/enigma2/python/Components/Sources/CurrentService.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Sources/__init__.py
f68dc995f78cfc88e26483ea787746ab /usr/lib/enigma2/python/Components/Sources/TunerInfo.py
c6f7285e3f449c301dab92d92cfb1fce /usr/lib/enigma2/python/Components/Sources/FrontendStatus.py
ab296b833f2d34f06b5ac2a16c782df3 /usr/lib/enigma2/python/Components/Sources/Source.py
ce001a44e6f7098624a6df98c1c5761b /usr/lib/enigma2/python/Components/Sources/Boolean.py
3059a135ceb0c3fca0867698f21fc2b7 /usr/lib/enigma2/python/Components/Sources/StreamService.py
d421be00754d02d85df804e4faea908f /usr/lib/enigma2/python/Components/Sources/RecordState.py
b8b12180202bc1ca61007fd6b7ec7009 /usr/lib/enigma2/python/Components/Sources/StaticText.py
44460c27e2763fb358898dc34907c140 /usr/lib/enigma2/python/Components/Sources/Clock.py
56c35c1b2af81757e84913b3eb816e6e /usr/lib/enigma2/python/Components/Sources/Sensor.py
db075a06a00091ac91dfdaae6fc66e37 /usr/lib/enigma2/python/Components/language_cache.py
73fb7af94ab02923d0e8365be10a96a4 /usr/lib/enigma2/python/Components/ParentalControlList.py
5ca34b71f3b1f9f09d32a4a150498935 /usr/lib/enigma2/python/Components/Timezones.py
776023a14682d64e78dec7b3816a70fa /usr/lib/enigma2/python/Components/NimManager.py
62c655bbacc907e84cd14c4dc9972546 /usr/lib/enigma2/python/Components/BlinkingPixmap.py
ae9baee8c742036b23345f88e775a15f /usr/lib/enigma2/python/Components/Slider.py
b2fe45714c4a542dc0aea365aabd3bb1 /usr/lib/enigma2/python/Components/ServiceEventTracker.py
7f3b46d858f45c88bcadef484c575ae0 /usr/lib/enigma2/python/Components/VolumeControl.py
8a566189add219ba26e3204f2eb21164 /usr/lib/enigma2/python/Components/Language.py
2c1bd3117309881fef653c59d6d3b858 /usr/lib/enigma2/python/Components/RFmod.py
e8bead18b4228a4a687db72a02bf4642 /usr/lib/enigma2/python/enigma.py
cfac1258e71864b1ce1e0874fd70d854 /usr/lib/enigma2/python/Screens/LocationBox.py
b5bc1d71a6b661898d46e07c8152d592 /usr/lib/enigma2/python/Screens/Ipkg.py
6b68c3e2070a4cadf05548549a43c785 /usr/lib/enigma2/python/Screens/Globals.py
586378f913a22adf52d797d07007e082 /usr/lib/enigma2/python/Screens/MovieSelection.py
fce834ae8afec7499040564ca0fbc769 /usr/lib/enigma2/python/Screens/ChoiceBox.py
7310e742a9964659cfd356327cbb69ca /usr/lib/enigma2/python/Screens/VirtualKeyBoard.py
524fa9ce443eae4668e581cb996f7364 /usr/lib/enigma2/python/Screens/Console.py
fce7b5b85c883771f96287006d192a6a /usr/lib/enigma2/python/Screens/InfoBarGenerics.py
ca0361953b30f5fc919c4b77abfca0fb /usr/lib/enigma2/python/Screens/TextBox.py
9e74b7dc6b09beedc90c65e6d1c9a4f0 /usr/lib/enigma2/python/Screens/ServiceScan.py
5c836403cce8a029cdec5afa8538eb3c /usr/lib/enigma2/python/Screens/PiPSetup.py
4c7cdc559cb51a0281d41d4a3da63592 /usr/lib/enigma2/python/Screens/StartWizard.py
10cd614b1406b23db42fe1089e68f02d /usr/lib/enigma2/python/Screens/AudioSelection.py
262b973b6346f1669ad83e2c67400a09 /usr/lib/enigma2/python/Screens/PVRState.py
3c44a1bb0a6687a3e8c4decd65b9fa43 /usr/lib/enigma2/python/Screens/MinuteInput.py
21b0cca3002cf88fa8868bce113ab96c /usr/lib/enigma2/python/Screens/SessionGlobals.py
e7bc2feca9f12a9169bc74c79d034e65 /usr/lib/enigma2/python/Screens/TimerSelection.py
616e4f5f8d67699c3564ac495ea4e091 /usr/lib/enigma2/python/Screens/ClockDisplay.py
7a421281bce9b3cf7eff19fa38846588 /usr/lib/enigma2/python/Screens/Ci.py
0483593598ac40874d9835af4f481f4f /usr/lib/enigma2/python/Screens/PluginBrowser.py
2fbb9c8d85a3144ac01a5d09e5219a6e /usr/lib/enigma2/python/Screens/TutorialWizard.py
fafa8e1cdfb5c7994ec52f7a627e58bd /usr/lib/enigma2/python/Screens/HelpMenu.py
1d812b4508da64c54eaf3aafe30eb1c5 /usr/lib/enigma2/python/Screens/Rc.py
b0b2b95a755c5d9d15975fe028821f3e /usr/lib/enigma2/python/Screens/EventView.py
545ea24d09a21ebd6b017f21fb5fa057 /usr/lib/enigma2/python/Screens/About.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Screens/__init__.py
74dcf98e11a972d249ce5fd011b97cb8 /usr/lib/enigma2/python/Screens/SimpleSummary.py
15b19e6f30826c97c7fdfe0b35ad71c2 /usr/lib/enigma2/python/Screens/UnhandledKey.py
0b3c4ccb4532013a5732b25844bb0a6e /usr/lib/enigma2/python/Screens/Standby.py
dbad3ce42566c9367d69ebd84b992d04 /usr/lib/enigma2/python/Screens/LanguageSelection.py
d501bc67ff36572c521ab3bd01da6cca /usr/lib/enigma2/python/Screens/WizardLanguage.py
9fd6f2768180b538d3f35ce3e8cebcab /usr/lib/enigma2/python/Screens/SubtitleDisplay.py
e5a84350b94e7e7c27dc57fcd00dff1c /usr/lib/enigma2/python/Screens/TimerEntry.py
b9a77756078c56818cc88be575a4c4b2 /usr/lib/enigma2/python/Screens/ChannelSelection.py
2026309d4bb26a778822e85541918335 /usr/lib/enigma2/python/Screens/Volume.py
372ed995725f003f56e3f231e0b3636c /usr/lib/enigma2/python/Screens/HarddiskSetup.py
c5c0ac1908fd39967894d1044d32520f /usr/lib/enigma2/python/Screens/RecordPaths.py
8b6a8d2bd01d6f5e7f16dd47ace0d781 /usr/lib/enigma2/python/Screens/Subtitles.py
2c371a88055a052e82401b97646771e5 /usr/lib/enigma2/python/Screens/Mute.py
847c257750e4fe93757b8b617d23afe6 /usr/lib/enigma2/python/Screens/Wizard.py
910794de58e03cb7a9e68b5b15900fd5 /usr/lib/enigma2/python/Screens/InputBox.py
bccc795a82aab24bd114c264706fedeb /usr/lib/enigma2/python/Screens/TaskView.py
494d95e3c66df7ead1bf1adb38f7d2b1 /usr/lib/enigma2/python/Screens/Scart.py
f09c91475b4d47bac3112605a1d520e1 /usr/lib/enigma2/python/Screens/InputDeviceSetup.py
db2cc254ebc1a2806ad768c670bbd22b /usr/lib/enigma2/python/Screens/MessageBox.py
e59f49df2e8ff48a45fc865e24e63308 /usr/lib/enigma2/python/Screens/PictureInPicture.py
675e86c36c61c9174237b27b2d39aea1 /usr/lib/enigma2/python/Screens/Screen.py
97df74fc6b9b85c68624ef71e18177a1 /usr/lib/enigma2/python/Screens/SubservicesQuickzap.py
1caf3058700bdc87bc00c54f2a85eceb /usr/lib/enigma2/python/Screens/NumericalTextInputHelpDialog.py
cc48e2abc02be6319485ae5987791ebf /usr/lib/enigma2/python/Screens/Menu.py
a1887da61746d8c7b190c1f9a6f79a5e /usr/lib/enigma2/python/Screens/Dish.py
f49c2918da9b1870bac153faa8717f91 /usr/lib/enigma2/python/Screens/TimeDateInput.py
a6c418ca660943e42fa2b2c72b8c2f7e /usr/lib/enigma2/python/Screens/FactoryReset.py
ea3df01e230dfb0e76fe1f6b8755b247 /usr/lib/enigma2/python/Screens/TimerEdit.py
d8ab85121817e311e336d530942f4e0c /usr/lib/enigma2/python/Screens/FixedMenu.py
30ace57c455e7f9755a5d1738671ba62 /usr/lib/enigma2/python/Screens/ConfigMenu.py
a25013df9955e2429f2370543d4c721c /usr/lib/enigma2/python/Screens/SleepTimerEdit.py
4b4246ba0ca9bf6b3f9ea8cf788dc7aa /usr/lib/enigma2/python/Screens/ServiceStopScreen.py
03a45a3ec6fa65949569006c7f268909 /usr/lib/enigma2/python/Screens/Setup.py
5c995a40de39886c79d9fe3c3d45d7f7 /usr/lib/enigma2/python/Screens/RdsDisplay.py
36e0fcf670092264a9f0aaed484ae119 /usr/lib/enigma2/python/Screens/ScanSetup.py
2690da67e19ff3dc9c5bf2e9674c3353 /usr/lib/enigma2/python/Screens/ParentalControlSetup.py
aeab2785c1ada02f25a641d0d6e763f9 /usr/lib/enigma2/python/Screens/Satconfig.py
5190df554072e88200859f8c99096837 /usr/lib/enigma2/python/Screens/ServiceInfo.py
0dc303d78afb926cb8ff44c1537a85ba /usr/lib/enigma2/python/Screens/InfoBar.py
202a551180e1dfdcf4e7ae135d8de685 /usr/lib/enigma2/python/Screens/EpgSelection.py
32afe8c8ca5e3bb865af86a296951d12 /usr/lib/enigma2/python/Screens/DefaultWizard.py
979558d2dc1244af7c10b5bcb8c8bb76 /usr/lib/enigma2/python/Screens/NetworkSetup.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Blackhole/__init__.py
9d0761269aedda651639c75a21f15702 /usr/lib/enigma2/python/skin.py
0b4897696936a4c0799525c7f1e73166 /usr/lib/enigma2/python/timer.py
eb9426c13bfa9868aacb87f050a8c40e /usr/lib/enigma2/python/ServiceReference.py
27d752afe9f1f12d9732f09b6122ce3b /usr/lib/enigma2/python/mytest.py
c8cb7ffe121f512968813014bcabf0cd /usr/lib/enigma2/python/e2reactor.py
0ff6b1d31b6b25a6b7745658f179b22f /usr/lib/enigma2/python/RecordTimer.py
47611e868aaa72c9c0ca79c4810dbe97 /usr/lib/enigma2/python/Tools/Transponder.py
dbbb881f6c856e4cab017f518ba4a68a /usr/lib/enigma2/python/Tools/CList.py
8c8b3e4062f8e5e9c72cceac90320a2f /usr/lib/enigma2/python/Tools/Profile.py
fec44e3c680135b636adcbc71044cab4 /usr/lib/enigma2/python/Tools/Event.py
2bb2eab34660b5fcdf0b30f9bd1e8f44 /usr/lib/enigma2/python/Tools/Notifications.py
a0639de72e3006e1001f4bf549017bb9 /usr/lib/enigma2/python/Tools/Directories.py
fc8e1e93a7429fba50acb0261f7f5268 /usr/lib/enigma2/python/Tools/RedirectOutput.py
5e58ee8495c6b18b588e7c5b6069fa4c /usr/lib/enigma2/python/Tools/Downloader.py
cbe6d03d0dd9d165c8ec776c5c9adcce /usr/lib/enigma2/python/Tools/ASCIItranslit.py
a2218e726395499f00c72c393da3ba2c /usr/lib/enigma2/python/Tools/LoadPixmap.py
e3356c99fc63880d7cbe4495a03adb68 /usr/lib/enigma2/python/Tools/__init__.py
d9d83467815003e745113b9a16a1473d /usr/lib/enigma2/python/Tools/DreamboxHardware.py
b3422d679770a129342e52f6ca2978ad /usr/lib/enigma2/python/Tools/NumericalTextInput.py
a428aeab8edfef7d2dc4025084898ac4 /usr/lib/enigma2/python/Tools/HardwareInfo.py
b4011bd490319162c0bb7ab1fe0816f9 /usr/lib/enigma2/python/Tools/BoundFunction.py
c542bb10e8db238b1bd7cf3e2ca06aa9 /usr/lib/enigma2/python/Tools/XMLTools.py
9cb37012dc10aab1d5a6f0128093e9de /usr/lib/enigma2/python/Tools/KeyBindings.py
b59a24f3c4925c36ab2b5c20a47d70cd /usr/lib/enigma2/python/Tools/ISO639.py
09af65390e201fdc839573e5a5bc43f6 /usr/lib/enigma2/python/Tools/FuzzyDate.py
d364549956b3cfabe13d9b6b561232df /usr/lib/enigma2/python/Tools/Import.py
c96070e276dd1207f742dbb835016b02 /usr/lib/enigma2/python/Navigation.py
46cf5439c0702ae3d52adf1e0df028af /usr/lib/enigma2/python/NavigationInstance.py
2847ae9cd6ce7ef306501d30d1b675d3 /usr/lib/enigma2/python/SleepTimer.py
9ff38d1fbf23999885065144d273019f /usr/lib/enigma2/python/keyids.py
41d347a6305f5523347e1d4e7b5e9989 /usr/lib/enigma2/python/GlobalActions.py
3ca804f1c54bd4faaa654ebbe1c07795 /usr/lib/enigma2/python/keymapparser.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/DemoPlugins/__init__.py
c8ccccf312cc9a35d1f786f965d57b0b /usr/lib/enigma2/python/Plugins/Plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/CutListEditor/__init__.py
150f218b4461c255a04f694ad68dc75a /usr/lib/enigma2/python/Plugins/Extensions/CutListEditor/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/Tuxtxt/__init__.py
fd9ff9eca1e4c86996e811b95f8eb0e4 /usr/lib/enigma2/python/Plugins/Extensions/Tuxtxt/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/DreamExplorer/__init__.py
144cc0c1f2345343ac7d8759d00dc0cf /usr/lib/enigma2/python/Plugins/Extensions/DreamExplorer/vInputBox.py
529d1a62be69c034fe05c90d9086c5b9 /usr/lib/enigma2/python/Plugins/Extensions/DreamExplorer/plugin.py
93855bc58e6f4298fd407732034096cb /usr/lib/enigma2/python/Plugins/Extensions/DreamExplorer/myNumericalTextInput.py
b94433459b5fbb24ad59be4c203a4686 /usr/lib/enigma2/python/Plugins/Extensions/DreamExplorer/myFileList.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/ChangeRootPassword/__init__.py
cd9d100d6e96b008df9d69e7f7f5528f /usr/lib/enigma2/python/Plugins/Extensions/ChangeRootPassword/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/MediaScanner/__init__.py
2ae0e1640ea4267540f2922afab4eb5b /usr/lib/enigma2/python/Plugins/Extensions/MediaScanner/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhFullBackup/__init__.py
3c59eea31228b5c60ae3e8660eabe09b /usr/lib/enigma2/python/Plugins/Extensions/OscamStatus/OscamStatusSetup.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OscamStatus/__init__.py
cff1b544787ac5631debe80c48396b86 /usr/lib/enigma2/python/Plugins/Extensions/OscamStatus/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/StreamTV/__init__.py
998a5676ebeac09714e3c03ffbec97a3 /usr/lib/enigma2/python/Plugins/Extensions/StreamTV/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/__init__.py
7bf99b4b797254f0536fbd08fef66f6f /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/settings.py
d67f186f0a9ba8aba7955bb6598c6d2f /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhPersonalBackup/__init__.py
953c1e21d433a3140a6ba6c2b93cf472 /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/GraphMultiEpg.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/__init__.py
e495f59341b9d41c810732b50b001dc1 /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/__init__.py
9a25db3270b3d07b2ace5e8507c5e490 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/httpserver.py
d6595051d66380d7fec55d0e7e0d2c2b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/stream.py
73159b21f5ac4548264e3584f6984160 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/volume.py
cebe63ee1fd945c8b8c9751eb9528759 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/services.py
7a1bd9220f6af26791b1ec5ac97c8b9c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/stream.py
a07579b1dc301e864165c54f28bbfe47 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/audiotrack.py
871ea5cb0e1bd584fbd83db7368e91e4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/control.py
35ab4e7a5f4d07dd928d963b2ba445c2 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/message.py
e23fce04e5d7fc99edccdf50eeb8770f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/movies.py
17e3c05bc3d0e2580dd496e698ff7ba9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/servicelist.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/__init__.py
9aa95c4894e783655f1736a4a8b1237a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/locations.py
52e18ddc7f485ec85ee180aea36ff629 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/info.py
e871f74a874316754c3a6f987ba77dff /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/grab.py
9040a7b9b5eea9e63550f4b7223a336d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/mediaplayer.py
80e63d0ce9778bf200182aa571a0ff49 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/plugins.py
afe4778db5673aeffbb7835ab1c8ed1a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/config.py
38102758c1cdd1b8f0d6a9d34de0592d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/timers.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/__init__.py
523263a2e5300bbba5b8a6be13d83925 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/file.py
1ef8ff7cbe36303a6d8fd2edb476f8e0 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/external.py
33fced14513d6746391c0f0b858e042e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/removelocation.py
813e42f80184874b25ff2fde5996a009 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgsearchrss.py
9109eb9bf509682f0eb64a4c21b3a8a7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielisthtml.py
4b571276a64b3ca609bdd4b514335afc /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerchange.py
28cabed53953ac77cac837e5ee472dd8 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getcurrlocation.py
89419095326f8708040b884ac679547d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/tvbrowser.py
91f2eb7968127c1afa5e238e120201c0 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayeradd.py
7e49661db87b04104a173dc6c7f1442f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerwrite.py
fa84343132e2dfb7519ba9a44528fca9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getservices.py
c7bf688503f6ad982f801dbc189b3659 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerdelete.py
fd106cc7c3a8ada7f2a58a9d78fad2a7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getpid.py
38881fa50a2c753a6c247712d4d0145f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgnext.py
18416101f39cd713e6da91b0cd3a5cb1 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayercmd.py
5f867795024e60773a8878eca58b8a08 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/messageanswer.py
af81895004638c905dc207b6919146db /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgsearch.py
02d94f6aad1a2dba3192052443df3e0d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/parentcontrollist.py
8b93bed38f0eb13f0513d5df7885b9fc /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/restarttwisted.py
81130815da60923dacf0e50ae7e503a5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayercurrent.py
1b3d8be346fcbec6b1d597a08b8ee148 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielistm3u.py
4558ade8e06e9179230e01e0d45b8726 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerremove.py
ada67091c5b9e6c441280986836591e4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerlistwrite.py
a07a7ed200d57265cb16c3016a94fbf0 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgservice.py
8c454a989c66355a8ac5d2e86c905604 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/currenttime.py
bc0c8e38b2c9be539cfdf03d1db506cc /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getcurrent.py
ea35fd25e0a2d6f2ee8b6229c6ee6068 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/message.py
ed4cedb519c9a782bb3aa7366d6e95a5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/gettags.py
ec92e36c7f7b6b5f9cb2b252a3f4df73 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/subservices.py
e80b4d915937faf08f3d2f285c008f50 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/servicesm3u.py
3d2fb3dd6fbae1494db383d904abf4d7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timeradd.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/__init__.py
3f4b4a6e66e268d3c334a1b078f316c3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerlist.py
c15ec03120c2d3ad9aa19ca0f222faa7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/moviedelete.py
c90dc591a7c6ce0d03e47a882f068a29 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getallservices.py
f21ddb4990167d628be847a9bc58e256 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgservicenow.py
a3a27c870ca4f29041255cd4977471b0 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/streamsubservices.py
82b6187a71760cc70654ea57471cccee /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgnow.py
897fb14991948a3a900e48fdeab1f111 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/signal.py
0a39fef3e8512d8cfb1df764f080d2a7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielist.py
22a7853ca60893f95663d244b2ff2af3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/recordnow.py
6ba07e5467a904b5e77a55a7e013a4d1 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/servicelistreload.py
45d12e9a8675979ed6c58eafe8f7c2a8 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgsimilar.py
19efc5cfa19a1119ef95292dc30de706 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/about.py
5cdb5c7c5ef3dbd24c49b7ac1de55ef9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/deviceinfo.py
0169f7e445f8ad102b190267c475de76 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerload.py
eb7cb03dc3ef2d609fd55f453c4b3649 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/serviceplayable.py
0721ac05c5868b5e75210bbba235f85b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/pluginlistread.py
7b7be8e421f32dfa51ddfdd9c578db40 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgbouquet.py
7a1ca3633c48d4ff597aa8815ed397aa /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timercleanup.py
7a4bdd4fcc186b3ba098f24514423597 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timeraddbyeventid.py
3b98482dd55caa87116eac49757f04f5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movietags.py
ec8eb8f7f89cc529db7bdc7af84ebd42 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getaudiotracks.py
c7d93e13d369d43cbc0e51d1dce4cf55 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/vol.py
c74b4d591893761cb6038612f6017646 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/powerstate.py
1d6bdd699516dfbecd7c99175a4642b0 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/addlocation.py
dea52b2133eb7f461aaf1f364a98aecb /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielistrss.py
5e6adc6329ea99d1a135d01a47d3f40e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getlocations.py
ee2ec070d2400a58a590054c9c579dcb /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/servicelistplayable.py
1705abd52b395da4d7ccc903e9d17e02 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgmulti.py
644831bf8aa39b8010d2682e4f0c6c3c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/remotecontrol.py
fc37b7b09c1fa906f183d0e9c6f62dbb /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/sleeptimer.py
4a937b0240096f262c5f335af27408ed /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerplay.py
dbaa0081c005785c87b974c654c52090 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgnownext.py
d867fc5e0f9ef0e8f6265f73c11a6aff /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerlist.py
8df56488fa71314c7ff24b902f011047 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgservicenext.py
91f47274c34cedbba59165cf3ecd25a9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/zap.py
a853f4ce8d8e2e7fda99b022fefeaa85 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/selectaudiotrack.py
926aa3318622b36d5294fcaa00c1bb09 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/channels.py
72d9a76c6f0b50031a22303e6a5d813a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/satellites.py
973e616ece89e137e122b14392f9148f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/eventdescription.py
168290389e1467d256a5fce79c9cd738 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/workinprogress.py
a2079b048befdc87cd4fbf0b84019ff3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/screenshot.py
675d7b00556feaea736cc8c79186cc83 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/providers.py
56ea61e59c2849b2d54fa5b8b0a5fd36 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/message.py
45c0dc939389138cc8e4e3b6adc0fc09 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/movies.py
24e8d74a31362604aba9a96cbc7b44ca /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/radio.py
ef44613c3e985e2d67e9a482027b51f4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/current.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/__init__.py
c79de6353bb226eb2f417b86003e5bd6 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/bouquets.py
e9889f0ff2ffcd5967c6ab8ef9f27f00 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/tv.py
1960bf8e6ae12b0e4ef9611daea3f5e0 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/about.py
6cda246221a60b64e502e2505396ee7a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/epgpop.py
776b951044e81d0a4fbabaf62b97e71b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/powerstate.py
8be0894abd865c1443b4d36ce0b56084 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/config.py
82159340e209e145e27478bf848c3743 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/boxinfo.py
edf774e4f23f714aebf1765df988f8a6 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/timers.py
4591a3ff0d4397b77407577e26552578 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/index.py
ae14209dd78cfe891d11ad61053f58cd /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/main.py
7d771711cdd3242c543ed3a065b83034 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/channels.py
676d40ed967edeb73b309d2eac43a798 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/index.py
809a151e82d9c9405a75ca13798a243c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/screenshot.py
a53949eb41d18faedb666f4d71c8dbbd /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/control.py
d7cb6fc88b94d99dc85abaf9b60c271e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/satfinder.py
d3c2cac7f2d57eb0e05dfd00b54fcc94 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/movies.py
43a90332d8b2b7482cfa3140dc51db62 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/bouquets.py
ae5127123b923c1accdae9bb6bb22bdf /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/about.py
ecfd1763e3a1ebe235b4ada4280ab052 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/channelinfo.py
ac87729e534aaced6a1d925356a5e791 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/timerlist.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/__init__.py
987a06b656e226b74be9e171a2a4cea2 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/ajax.py
cbc91347d1f5812c0f46051e516bacbc /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/ipkg.py
55bc36cb737dc0267f6e6bd2c6d697fa /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/api.py
4a5feda743918ca55fb033e408013e42 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/mobile.py
e3d12eabcde3c4ccdb87296341de7ed3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/web.py
8b7b6cc02ee3a8e6af622c361aa54b97 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/base.py
d03b8420bc6eabad19bbd921d3b48964 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/root.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/__init__.py
a10b27098a4d9ba8c1f827ee90a3609b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhEpgBackup/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/External/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/__init__.py
f66e93ef0623fc4838c3757df3159ebb /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/Toplevel.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/PicturePlayer/__init__.py
b72c7859893a76cafdfc32c65e1df0fb /usr/lib/enigma2/python/Plugins/Extensions/PicturePlayer/plugin.py
3f2553ad4f45959f17f2afdb617d8f45 /usr/lib/enigma2/python/Plugins/Extensions/MyTube/MyTubeSearch.py
c221d4bc9938619b19d98ce788e271f2 /usr/lib/enigma2/python/Plugins/Extensions/MyTube/MyTubeService.py
10e24c344b41265a6b7c75375757beca /usr/lib/enigma2/python/Plugins/Extensions/MyTube/__init__.py
a7872e255e6937e7121275943dae7ae3 /usr/lib/enigma2/python/Plugins/Extensions/MyTube/ThreadQueue.py
7c658f6b7edc9421bc8b09eae7ff8338 /usr/lib/enigma2/python/Plugins/Extensions/MyTube/plugin.py
377585531a915f167fd63413e6a09647 /usr/lib/enigma2/python/Plugins/Extensions/MeoBoot/ex_init.py
ab0a07e9fec70ae0abb9a1f539509a2b /usr/lib/enigma2/python/Plugins/Extensions/MeoBoot/__init__.py
347821af16abdec23873cff6941e8aeb /usr/lib/enigma2/python/Plugins/Extensions/VuplusEvent/vuplusauthenticity.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/VuplusEvent/__init__.py
a6e639c399ab1d0726f5dd7f197b91d8 /usr/lib/enigma2/python/Plugins/Extensions/VuplusEvent/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/Extensions/DVDPlayer/__init__.py
90e9e7de5a3a6937798701490c2c6c21 /usr/lib/enigma2/python/Plugins/Extensions/DVDPlayer/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/CommonInterfaceAssignment/__init__.py
a246ce4f2ff625bbecc9f64437f6197a /usr/lib/enigma2/python/Plugins/SystemPlugins/CommonInterfaceAssignment/plugin.py
2fac60170cdd3cc068dc058f582f3cb7 /usr/lib/enigma2/python/Plugins/SystemPlugins/FactoryTest/sctest.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/FactoryTest/__init__.py
fc770f90120448baa93f1b6f98962e08 /usr/lib/enigma2/python/Plugins/SystemPlugins/FactoryTest/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Satfinder/__init__.py
61f98a769c5ded0c8a64451697891120 /usr/lib/enigma2/python/Plugins/SystemPlugins/Satfinder/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/FPGAUpgrade/__init__.py
d6cbf11e182ddc88b99db8b02ee55e97 /usr/lib/enigma2/python/Plugins/SystemPlugins/FPGAUpgrade/plugin.py
5cd63078da8d66aa7081d64b74692f40 /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/SoftwareTools.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/__init__.py
b7c161d59170e825a894dec1d8b8c951 /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/ImageWizard.py
71bd9b4109a39ef3f2487eeefa42d0eb /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/plugin.py
d1e4f463eeb0272a2f86f40c3a77a7aa /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/BackupRestore.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/PositionerSetup/__init__.py
1440586470e4335ea4e9838d1c785379 /usr/lib/enigma2/python/Plugins/SystemPlugins/PositionerSetup/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Blindscan/__init__.py
6d8798cd51461ff8ce58bba0459cbe27 /usr/lib/enigma2/python/Plugins/SystemPlugins/Blindscan/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/BlackHoleApi/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Hotplug/__init__.py
d8f9b54aeb4984c2c49cb649196d3b30 /usr/lib/enigma2/python/Plugins/SystemPlugins/Hotplug/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/__init__.py
cfb9986cbbe4b74beaf0c1413f79bd19 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepglib.py
33e59bb91c77a56393b89d14bf4432f4 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_converter.py
5fbe402f3c67003c92c2b2f96861bf26 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_downloader.py
fad20b74cb80966a0985b23807372f2e /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_about.py
ab25a10ca1c6276dedd44a32802070ba /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_loader.py
2dcad2a8ed9782badaecbfd127441f29 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_main.py
4153403ed295cdd099ba056109e40ce7 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_locale.py
438360c99adf10d37bb2bb1aba2c06d0 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_xepgdb_update.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/__init__.py
a4579a396c439a2449dd9f0bff3df85f /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_auto.py
74457affa498021694ec972e3659f564 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_menu.py
1106bfab8a8ac81bbdfdc42525c42a26 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_ordering.py
13245153d2e1301eabb55634bb60732f /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_setup.py
c1debda1e760193f7e9a9c655b2c0f4b /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_info.py
ce2502ef4098977d59e2272f89c94664 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_providers.py
808b4ae437dd44abeceeff4fcb9892af /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/version.py
0571a881aed68645a3c8224b0f514c8f /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_rytec_update.py
4548e0dbbf15553d959498e7f81f7a4c /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_importer.py
0e72a14f8d25f355de48d645539790de /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/plugin.py
b70bb2961078b2dc8156f46281c0ff97 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/VideoEnhancement.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/__init__.py
556423529be882b7c105365bca27b25b /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/plugin.py
ca946826f2c188e52ea3c4262b60a2c7 /usr/lib/enigma2/python/Plugins/SystemPlugins/ManualFancontrol/InstandbyOn.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/ManualFancontrol/__init__.py
6a2c14392013d85591a83394e9172ad2 /usr/lib/enigma2/python/Plugins/SystemPlugins/ManualFancontrol/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/UIPositionSetup/__init__.py
f1e3281b7350cb7298f7cd60cfa58a3b /usr/lib/enigma2/python/Plugins/SystemPlugins/UIPositionSetup/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/__init__.py
8c0928a5e47d19cc605ec7fbb03199e8 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/NetworkWizard.py
a2008372ff89c62d07cb31e6a9de091f /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/3GModemManager/__init__.py
b511212d0ebefb280cd74b15fee964fa /usr/lib/enigma2/python/Plugins/SystemPlugins/3GModemManager/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessAccessPoint/__init__.py
c1fd410e35d45e498cbd50573e09a7e2 /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessAccessPoint/wirelessap.py
97b6f22218584c143d24fafa2b52ba1c /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessAccessPoint/plugin.py
2db4069db43044a52e20a46811b64164 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountEdit.py
44cca1ed648f0d92ba14d531d477c7db /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/AutoMount.py
6a352b0bfe8173ec89e5ce895b01eb6d /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountView.py
286db9f715fa9c074016e0132750128e /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/NetworkBrowser.py
7010636521d6a0183f317e43ace396e2 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/__init__.py
340b79e10fdf7e759e103704b12fa2a9 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountManager.py
19b45c6ada80382a72629591ba86580a /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/UserDialog.py
da2d19e7d6c97c2f645bd34ce7fa7ff8 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/plugin.py
2fd13d35fa6df0843208e85cfcf3bef7 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/UserManager.py
9f565e180deab436b5175874ee919ca6 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/VideoFinetune.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/__init__.py
6307b4f8a6952cfd3532bc8bed7cb817 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/RemoteControlCode/__init__.py
a989a3ffb767b37965df6af2ae43a996 /usr/lib/enigma2/python/Plugins/SystemPlugins/RemoteControlCode/plugin.py
1b7a6f60792410a7d6f101a9dd537ac1 /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/VideoHardware.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/__init__.py
d2d2d6d90b128e0f8221dd862d934081 /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/plugin.py
c954129f81aef46f117be2b995d919ba /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/VideoWizard.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/UI3DSetup/__init__.py
ec38cd4c1ba2fc739706822cb248ec04 /usr/lib/enigma2/python/Plugins/SystemPlugins/UI3DSetup/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/SkinSelector/__init__.py
867018726f190427b7a3e2060dd67396 /usr/lib/enigma2/python/Plugins/SystemPlugins/SkinSelector/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoResolution/__init__.py
31f058e8405b2b292ab9c0ed042ad783 /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoResolution/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessLanSetup/__init__.py
7238522f2de52a0a097c762d2063735d /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessLanSetup/plugin.py
ecaa88f7fa0bf610a5a26cf545dcd3aa /usr/lib/enigma2/python/Plugins/SystemPlugins/HDMICEC/__init__.py
510365721a50d368d37aee98930c7453 /usr/lib/enigma2/python/Plugins/SystemPlugins/HDMICEC/plugin.py
943167eb90dc3145e1b9f61dbd098c3b /usr/lib/enigma2/python/tools.py
</pythonMD5sum>
</crashlogs>
</opendreambox>
Rytec France is available in the XMLTV providers and the XEPGDB providers.
Nothing is this CrossEPG Menu. I try to download these providers but nothing at the end.
It was ok with tle last BlackHole Image.
Crash log in EPG Menu for Rytech-Csat (blue key and red key)
Where do U save the EPG, and what do U use the HDD for?
I try to save EPG on HDD or on USB but it doesn't work.
--I use USB(where I save picons,,,etc) and no CrossEPG (I have due and it causes a crash for me)!
--Normal BH open& Rytec are OK!
--Make both saving paths to USB:-
@Blue>Red>Global Settings > Path to save Epg File>>>>>> /media/usb/epg.dat!
And
@ Menu>BH Epg Backup>Setup(green)>Path to save Epg File>>>>>> /media/usb!
Choose YES for Enable Automatic Epg Backup!
Have Fun w/BH!
@Theva1 : Thanks, it works fine (some changes in this new image)
@a911 : Thanks, it works fine also on usb with EPG Backup ON (on USB)
Another question : What is the difference between CrossEPG and normal EPG (key blue and red) ?
Regards.
Regards.
CrossEPG is a plugin that download epg data in several file formats!
OpenTV Epg is a built in epg download within the BH image!
Hi
I get a green screen when using crossepg for time to time but have reverted to black hole EPG. Some of the channels only download now and next but 90 percent work is there a way to fix this. I using 28.2 sat
@blackhole coders. I wondering is the following possible in a future release. I use this plugin "Auto Bouquet plugin for commando 14.5" it grabs 28.2E bouquets direct from stream and converts to user local bouquets so I never to rescan or update bouquets .... I know it's neutrino plugin and not enigma 2.
Just a thought great image :)
Hello everyone. First of all i would like to thank the team for this wonderful image.....secondly i installed the image on my new VU...i used DM800 before so VU is not a stranger to me. However i cannot seem to find video enhancement (system) plugin under menu -> setup-> system. It seems to be installed with the image.
I tried uninstall and re-install via BH addons manager but no luck....any ideas....? I saw on the forum that someone also had the same problem on 1.7.3 but there was no different solution suggested than uninstall and then re-install.
Try this way, it may work,
Long blue>Software Management >Advance Option>Pocket management...WAIT for update....and reload from there "Video enhancement"
OR
Menu>setup>Software Management>Advance Option>Pocket management...WAIT for update....and reload from there "Video enhancement"
