Black Hole Vu+ Uno 1.7.8
ciao,ho aquistato un vu+uno posso installare tramite usb questa blek hole 1.7.8 sul dec vu+uno.adesso lui è vergine cioè ha il suo prg.originale.,mi aiutate? grazie buona serata a tutti.
Yes you can.
Update fpga first.
OT: this is an English section, please write in English.
Good morning friends. I have a number of questions ... in settings / system / zone, got to where I live portugal and get out and see the clock gives me an hour more than they give debertia, I went to the anterior and one that tells time with 10 minutes delay is the first time that I have that problem with your images, another thing is that [q Luing much like New Black Hole Weather worked well but after a time ja be watching TV and want to enter the system crash and restart the deco .. if you can help me I would appreciate ... greetings
Fixed problem of the DVB-USB drivers!!
At least WIN TV mini stick!
I tried a bit and it seems to work quite right, I will tell.
Thanks for your great image,
My image is BH 1.7.7 could i upgrade to 1.7.8 online (from online panel) ? and how ?
I'm using motor (positioner) if i upgrade to 1.7.8 how can i restore my Diseqc settings ?
1) online update for BH image series is not enabled.
2) you can save your tuner settings with some tools already included into Image and restore it to new flashed image.
Hello,
It is possible that BH team integrate/enable the "online update for BH image series".??
Evry time we should re-flashing the box with the new image and online update/upgrade it's more confortable.
Hello,
Sorry.
Coder has choosed to disable it.
I can't see it happening, unless Vu+ implement it into there offical images / git and even then, if the BH image coder decides he doesn't want to allow online updates, then it won't happen.
