Black Hole Vu+ Uno 1.7.8
hi
after deep standby,i loose everything: Mounts,Meoboot images,EPG..
Why is that?
Probably because the device where you stored your stuff (usb key or hard disk) is not detected during the boot sequence. For example if your hard disk is "lazy", mean take a long time to wake up, it will not be detected early enough, then the mount point is lost : the same if you unplug then replug.
I dont think its about Devices, because on 1.7.7 with same configuration, i didnt had Problems...
Meoboot, Epg, Backups are on USB stick, not HDD..
Strange, I did try on my uno and all work fine...
Could you tell us what you have in /etc/fstab and in /autofs when you wake up from deep standby ? and the same after you re-mount the device
The same here
no problem with UNO and USB mount.
1) online update for BH image series is not enabled.
2) you can save your tuner settings with some tools already included into Image and restore it to new flashed image.
Thanks for your answer, because this is so important for me , to restore tuner settings like positioner i have to use Menu->Blackhole personal backup ?
Ci sono problemi su 1.7.8, per quanto riguarda la visione di "youtube". Appare una pagina verde, la clessidra si mette in movimento e dopo un pò di tempo torna il programma che si stava guardando...
Yes, you should use "Personal Backup" to move your settings (and much more things!) from one BH image to another BH image :)
DVB drivers do not work well on the device wintv mini stick.
take long to change channels, be pixelated and last about 10 seconds starts to look good, especially HD channels
in version 1.7.2 worked fine.
All other things works great
