Black Hole Vu+ Uno 2.0.2 Rev. D
Green screen of death looping after online update during GUI boot (2.0.2c to 2.0.2d)
the same here,the update produce a green screen.
after flashing the complete BH 2.0.2 Rev D everything works fine.
What is wrong??? But it`s only at Uno
Hi
same green screen problem here after online update from 2.0.2c to d on VU Uno. Now trying to update with USB , i will see if trouble persists. No problem at all on VU Duo for same update
regards
Same issue.
After online update UNO boots but never starts.
Shiro Commands work fine but i made a fresh flash from USB.
This is a low free memory issue for UNO ?
If so i suggest the BH team to optimize online update firstly to check/clean memory then proceed to update.
This is another great "Stable" Image.
:thanks: BH TEAM.
Hello,
I've made a clean install, it works fine :)
But there is one old tiny problem.
Some times I found strange chars in the display.
It has nothing to do with the channel list.
Other image (VTI 5.1) with same channel list, doesn't show this problem.
An other (newer) problem is, that my external eSATA connected WD Blue Caviar 512 GB doesn't go to sleep mode.
Older releases of Black Hole don't have this problem.
And I have one question.
The image size of Black Hole is big.
Can this be a problem for online updates of the image?
Cu, kosmopolit17
Cu, kosmopolit17
Likely to be,
if the flash image is filled to the top.
But I never had.
Of course it is possible to clean up image
with addons unistall Panel
and with the new panel Black Hole Speed ​​Up.
What is the working situation with the image
is quite good to see in the System Info panel,
before update.
I've never seen.
It is possible you're using another language
or skin/lcd skin ???.
