Black Hole Vu+ Uno 2.0.3 Hyperspace
Hi guys. Thx for the image. Want to upgrade my Uno after a year, still have 1.7.2 BH inside. Have two questions:
- can I do direct upgrade with keeping my settings / favorites, plugins, skins etc? (Note says personal backup of previous image wont work)
- is there a need to upgrade firmware first? What version is needed?
Thank you.
1) you must reconfigure your box after flash or follow the Shiro post in the Howto section to backup and restore your settings prior to upgrade to BH 2.0.3
2) I suggest to upgrade FPGA before start upgrade process. Using the FPGA Plugin you install Always the latest version
after upgrading to 2.0.3, my device can't connect to internet!
i can access to my box via filezilla,
all my settings are tested and confirmed through network test
How do you get the channel to be displayed on the box??
All i get on box display is the last thing i looked at like main menu, audio, etc, etc
Guys, since I upgraded to 2.03 - I cannot scan 11,411/H transponder on Hotbird 13E. No channels are found. This was working correctly on 1.7.2. When I try Satfinder and that transponder I got lock and signal 85/79, all good. The scan doesnt work.
I recently installed this picture but I see he has a pretty nasty bug when the receiver restarts or stops back on wireles current settings are canceled and must be made ​​of nou.poate fix this bug!?
or maybe I'm wrong somewhere?
Mine is working well. Only sometimes (installing plugins or changing something in box by FTP) needs to be restarted two times to make WLAN work. I didn't find why until now.
Try to do the same thing.
I did and restart several times but still can not save the settings remain the wireles and repeated stops only when the receiver is reset back to wireles settings or better, use device, otherwise the password is off and the rest is saved!
