Black Hole Vu+ Uno 2.0.5 galaxy
Excellent work BH, thanks for HDD & other improvements, but still need to improve system time always going back to 2009 or some other date after reboot.
Excellent support for the hearing impaired, as well as the undisputed performance of BH.
Many thanks to the team
ok, sorry for the question again, is it possiblle to do upgrade over usb from 2.02 to 2.05 to keep old settings... and how...
thanks...
for me is this difficult with evry upgrade again do setting from the begining... thanks
Hello,
Could you make all plugins in "Speed UP" desabled by gefault ??
So, user will enable only the needed plugins.
==> i keep only "MeoBOT" and "AutoSHUTDOWN"
hello,
When i change "TimeZONE" by "WebIF', it's not changed in my box, like other parametrs, could you investigate.
Hello,
I have desabled "BhFullBackup" and "BhPersonalBackup" in "Black Hole Speed up", but "Backup Menu" remain in tne "Main menu" with no sub-menu.
Could you investigate and remove Buckup menu when desabled.
Each scenario is a compromise.
What suits you , would not suit another.
I think the coder made ​​a good choice.
He has enabled what is part of the base image, and it is not difficult for flash and memory.
A disabled what takes flash and memory, and does not use a lot of users .
Hello,
Could you make a single menu "Audio/Video settings" including:
- A/V Settings
- Video enhancement settings
- Video Fine-Tuning
==> The menu will be lighter and less bulky
Hello,
- A/V Settings
- Video Fine-Tuning
I think this whot is now is best to all people becouse no have smoll or big number menu.
One people like big number menu other very smoll.
I think is inpossible made all menu configured by user.
Your answer is not clear. could you give more explanation. thanks
