Black Hole Vu+ Uno 2.1.7
What mean this crash
  File "/usr/lib/enigma2/python/Navigation.py", line 43, in dispatchEvent
    x(i)
  File "/usr/lib/enigma2/python/Components/PerServiceDisplay.py", line 17, in event
    func[1](ev)
  File "/usr/lib/enigma2/python/Components/Sources/CurrentService.py", line 23, in serviceEvent
    self.changed((self.CHANGED_SPECIFIC, event))
  File "/usr/lib/enigma2/python/Components/Element.py", line 86, in changed
    self.downstream_elements.changed(*args, **kwargs)
  File "/usr/lib/enigma2/python/Tools/CList.py", line 7, in __call__
    x(*args, **kwargs)
    x(*args, **kwargs)
  File "/usr/lib/enigma2/python/Components/Renderer/Label.py", line 21, in changed
    self.text = self.source.text
  File "/usr/lib/enigma2/python/Components/VariableText.py", line 12, in setText
    self.instance.setText(self.message or "")
TypeError: in method 'eLabel_setText', argument 2 of type 'std::string const &'
(PyObject_CallObject(<bound method Navigation.dispatchEvent of <Navigation.Navigation instance at 0x12c3968>>,(0,)) failed)
getResolvedKey
Probably into a plugin, a system element has been invoked with wrong arguments.
    x(i)
    func[1](ev)
    x(*args, **kwargs)
    x(*args, **kwargs)
getResolvedKey
When i try to send list of channel to my vu by DreamSet 2.4.8
2.17 is the best for uno with 3.0.1 the flash is full and DHCP CANNOT be a permanent one if you dont add 8.8.8.8 as the primary server so back to 2.17. Sorry I hope you read this and see what maybe is possible in future
a FLASH in use of 98 % means in practice as what ?
That 98% of flash is in use lol. Anyway not much you can install on as it is not much space left so you could get crashes. Uninstall unused addons before you put new ones
Hope you get what I mean
Sent from my D5803 using Tapatalk
Check your installed plugins, but i think it's not the case, and with an ftp tool, check your /home/root folder ... some crash's of plugins installed, records, etc ... if you haven't setted the responsible pugin (s) as it must be can fill up your "flash memory", although without crashlog, no one can help you! :sad:
Nunigaia how much flash is free after fresh new install of latest image without addons?!
