Black Hole Vu+ Uno v. 2.0.4
Hello BH Team,
Thank you so much for your continuous great work.
I have UNO and have installed the latest image 2.0.4 but I didn't see the "LCD4linux" page.
Where from can I get it, with many thanks in advance
hi every body , I tried to install from usb flash to my uno after restart the red lamp kept on , no ch_ message on the front lcd ,do I have to wait for long ??or something wrong !
I have a strange error, i often get no sound. Great picture, perfect signal but no sound. When i switch of the vu+ uno with the remote control and on again it comes back. Image is the black hole vu+ uno v.2.0.4.
You should explain better, in which conditions you lose sound (watching, recording,...) and on which audio output (HDMI, SCART, Analog, SPDIF)
This error occurs when i am zapping with my favorites and i found a channel to watch. Vu dirextly connected to the television with hdmi. Sounds stays away untik i put off the vu with the remote control and then turn it on. Occurs only now with the 2.0.4.
Are you using HDMI-CEC? Try to disable it. And try set to default language all Autolanguage settings (provider language).
Hello i have checked the preferred language and found preferd stored on device. Set this option off. The hdmi cec was disabeld. Found the option on my tv SIMPLINK. This was on set it to off. Hope it will be solved. Its not a big problem, its just annoying.
Keep us informed.
Thank you.
