Black Hole Vu+ Uno v. 2.0.4
Morning! I have tried so many times to update and I'm either missing something or I do not know what! Currently running BH 1.7.9 and want to update to 2.0.4, tried 10 FAT32/FAT usb sticks, \vuplus\uno\ directory as mentioned, front/rear ports, no hdd connected, but nothing. I don't get the prompt on the stp display to start update, it simply boots normally. Sorry for the - perhaps noob - question but I have searched and couldn't figure out what I am doing wrong here. Box is genuine VU+ uno, not a clone of course. Is there an intermediate update that needs to be done? Many thanks
No intermediate uptdates needs.
Try with another lowsized USB stick and remove ALL other USB devices connected
Hi
I have problems when downloading images to download, the download speed is too low, you can help Link if possible thanks :thanks:
When the box powers up if you check LCD says press Ch- and it will start reading from USB ;-)
Tried with 16, 8, 4 and 2GB, that's the lowest I have. The decoder seems to read the usb stick, because after I connected it back to the PC I had a new empty directory \usr\lib\opkg\info on it. However, nothing seems to work. The update is within \vuplus\uno , I do not have any other USB device connected and I do not see the ch - message, decoder just boots normally
Edit: Finally got it to read the usb, tried an ancient kingston 128MB that I had for xbox and it worked straight away. Weird as all of my other usb are also kingston..
Nobody can reply because nobody can know what are your preferences and box usage.
If it is so difficoult for you to setup the box you can stay with old version.
Maybe it is most important that you start to learn howto setup your box by yourself.
HI Shiro.
I use a Vu+uno.It is used for U.K. family viewing.Just normal,everyday usage.I have had these systems since the early days when you had to programme them via your remote(whenever a service 'went down').
Flashing the image is easy enough aswell as basic setup but,when it comes to putting the 'important' stuff back on for reconnection,that's when I run into problem's.
HI Shiro.
Respect Board rules.
As said by Shiro, it's time to learn how to manage your powerful box.
iPhone 5 & Tapatalk forever :)
what a ugly skin !!! i came back to "touchHD" wich is one of the best, of course, after "Army transparencyHD" ...
