Black Hole Vu+ Uno v.2.0.6
Report this issue to Vu+ (www.vuplus.com).
BH 2.0.5 works
BH 2.0.6 update with my settings does not work
New installation BH 2.0.6 (without my settings) does not work
vuplus-image-vuuno-20120203014857 works
I paused the question vuplus. but I think it will make me stand on BH 2.0.6.
Do you still think it is the solution?
This is the second case see!
Hi , i flashed 2.0.6 on my uno , it has a cable tunner and did the usual proceders but the uno with this image doesn´t grab any channels when scanning not even by putting a list with ftp. So went back to 2.0.5 and did channel scaning and its fine.
Thanks
In any case, thank you for your work
Thanks for this new image
But i have the same bug on weather plugin. When i select a new town enigma2 crashes.
I don't use an old config.
Regards
Regards
Post the crashlog please. Usually the problem is related to your internet connection. Please verify carefully IP, GW and DNS settings.
BH 2.0.5 works
You mention an "vuplus-image-vuuno" dated 2012 .... it's too old and it's make nosense.
thx a lot for new image...
but I get an error when I estract package from the zip.. (downloaded more time)
help me...
BH 2.0.6 is based on latest source code released by Vu+.
I think your tuner doesen't work also with latest image released by Vu+
the last image of Vu + does not work
Version 2013-09-16-vuplus_experimental
Image: Experimental 2013-09-19
Version frontprcessor
Tuners detect
tuner A: Vuplus DVB-C NIM(CXD1978)(DVB-C)
I have make FPGA update to 4.5 http://archive.vuplus.com/download/fpga/vuuno/
http://www.vuplus-community.net/board/threads/vu-uno-firmware-upgrade.2955/
http://vuplus.com/pressNewsContent.htm?idx=47&pagenum=3
Many thanks!
upnp renderer working, that's cool ! waiting now for bluray iso player and why not 3d but i don't know if the chipset inside my uno can do as rtd 1186 chipset can ?
@lorenzo64
Can someone please test the blindscan on their Uno with this image.
I get green screen crash on 2.05. Is this fixed or an ongoing issue or is it just my box ?
