Black Hole Vu+ Zero 2.1.4
Hi Guys - i'm quite new to Vu+ and just bought the Zero model insted of the usual DMxxx. I've flashed the Zero with the image, but it never gets past the "starting gui" while booting. I've tried to reflash it, both with same img, and with a new download, but same result. I've tried to flash it with the original img, and that works just fine.... any ideas?
Regards
JSG
Flahed 2 Zeros last days, both with BH 2.1.4, without problems.
1. vuplus dir in fast32 device
2. connect, poweron untill led blinks
3. poweroff/poweron, few seconds you have to get configuration Wizard (tuner, network)
4. now system goes to channel list (empty) and default background (bh logo and starting gui), but decoder is online and works (push menu button, blue button etc..)
5. (now you have to load channel list, software (!!! can't say more !!!))... and decoder is perfectly working!
My first doubt for tomorrow that i ll recevie the box is if works AF9035 usb dtt. there is download menu for avermedia twinstar af9035?
thanks
its my first VU and im surprise for the performance of this box its wonderful it works smoothly and fast.
quality picture 10/10
speed 10/10
stability 10/10
by the moment it works perfecftly.
thanks vu team.
yes i confirm that only plugin the usb avermedia twinstar works perfectly its detected without do anything works fine very good and also i have two tuners i can watch one channel on tv and other in webstream perfect.
thanks team for image.
got my zero today.
am very impressed with it.
so i now own a solo2 and zero both are great boxes.
regards tm
One issue that i have is that when i push power off button on remote control after a time when i try to power on from button doesnt reply i cant boot the box.
i have to reboot from rear button in the box. anyone happen the same?
Hi, I have a vu+solo box. Tried to upgrade the box (directly from the box). This was succefuly done, but when the box should restart after the update nothing happens (the green light on the box is on but the tv is just black) any ideas what the problem could be?
Reflash from USB.
