Black Hole Vu+ Zero 2.1.4
Hi Guys,
Just got my new vu+ zero today and looks like a fantastic piece of kit!
Only thing is it just won't flash with the BH 2.1.4 Image from this sticky!
Im using a usb drive 32gb and also used a 16gb usb and formatted both of the sticks and loaded on the vuplus folder and then I plug that into the box and then power the box on and all it will do it power up to the vu+ original image
The usb drives both have lights and both flash since they have lights on them so dont understand what the issue could be??
Can someone please help ? : (
Hi Guys,
Try old usb 2/4gb i think on this usb will be work update.
Buenas,
Tengo la vu solo, he intentado poner la tp link wn727 n con la version v4 en la bh 2.1.4, pero no la reconoce,alguiem sabe la solucion?
gracias y saludos
Black Hole 2.1.4​
What is new in Black Hole 2.1.4:​
All models: Full HD Skin ready.
The 1920x1080 framebuffer support recently introduced in Vu+ drivers has made it possible to use full hd skins. But many parts of the enigma2 gui are hardcoded with fixed fonts and itemheight.
This causes fonts at 1920x1080 resolution to appear far too small. All these gui parts have been re-coded in Bh 2.1.4 to support larger fonts and itemheight in case of full hd skins (thx to Matrix10)
Solo and Duo only:
The 1920x1080 framebuffer support has required extra Ram usage. For this reason the old Solo and Duo models do not have enough free ram to run the curent images with these new features.
In Black Hole 2.1.4 we have included ram compression (zram) that increases performance by avoiding paging to disk and using a compressed block device in RAM instead, inside which the paging takes place until it is necessary to use the swap space on a hard drive or usb stick. Since using ZRAM is an alternative way to provide swapping on RAM, zram allows Linux to make more use of RAM when swapping/paging is required.
misc:
  • drivers: 20141126(solose, zero)
    - Fix booting problem(solose)
    - Support LED brightness control in idle mode(solose)
    - Support LED brightness control in normal/idle(zero)
    - (Brightness can be controlled in Menu -> Setup -> System -> Display Setup)
  • New Skin MX-Black
  • Meoboot update: Fixed the issue of non working usb drivers in images in multiboot.
  • About screen: Add drivers version, kernel version and Cpu info.
  • Bh Full Backup update.
  • OpenWebInterface update.
  • WirelessLanSetup: add quote to wpa_passphrase for password.
  • Black Hole Swap panel: Allow to create swap files upto 2 GB.
  • Black Hole Swap panel: Update descriptions (Thx to Ev0).
  • Solo2: fix ethernet problem in some Gigabit switches.
  • Solo/Duo: implement Zram
  • Librtmp update.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Vielen
I can see is the first thread that this image does not include Livestreamer. Can someone pls confirm? and how do I get livestreamer in it.
Regards
Updating my previous post .
In the image blackhole2.1.4 for V+solo and duo its mentioned ( Added to feed: livestreamer, livestreamersrv ).
And not for Vu+zero how can I add this livestreamer, livestreamersrv for Vu+zero.
Regards
can someone halp with openairplay on vu+ zero. I installed version 1.0 on my BH 2.1.7 and airplay is discoverable on my mac devices but cannot steam content to my TV.
Black Hole 2.1.4​
Solo and Duo only:
misc:
  • New Skin MX-Black
  • Librtmp update.
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
thanks for this
