Black Hole Xbmc beta 02
OK, I have found how to change default player.
You can edit the playercorefactory.xml in /usr/share/xbmc/system (with dcc).
Change E2Player witrh DVDPlayer at the end of file.
Restart XBMC.
It works but... player is too fast and no sound.
Is there anyone who know why?
another info (if someone is interested???)
when i play a movie with default xbmc player it is very fast but if i play it in accelerated mode (2x) it is more slower (i think really 2x normal speed).
is there someone interested to make xbmc player possible???
Does any know if NBC sports add-on is working in Xbmc beta?
everything works part from when there is a live EPL game the stream links are there but when you click on them a picture of the EPL log comes up saying broadcast to start shortly even the game already started I tested on Thursday it dose not work all links were workig fine on my laptop but not on my vu+ solo2 .
you need a usa ip to get the epl
but I can not test your findings until tomorrow, however the golf is playing fine and a few other links I tested on there
sporting stream working but no audio
script error when trying navi-x although I've not checked the log for either navi-x or sporting streams errors as yet
I know that like I said games are playing fine on my laptop but not on my vu+ even with using usa ip . full replays showcases spotlight golf channel live all working but not epl live games
have you tried to play live games and it worked ?
Using Enigma media player we must disable "Play the next song automatically" to avoid endless loop:
tried it your way and it still goes into a loop
Restart XBMC.
tried it your way..same../player too fast on music and too slow on movies and no sound on either
so much fun and so little time
also i need an simple iptv client to install everyone ive tried so far wont install properly ....
can anyone help there too
i think the problem is because in settings, in system/audio output, there nothing in audio output device. I supposed as it can't play sound, it can't synchronise video.
no I can not test your findings until tomorrow no epl on at mo was your findings b1 or b2?
I am not saying your not right I was just pointing out you need a usa ip
** has anyone found the context menu button on solo2 remote?
seems the issue with navi-x is the import of the skin
unsure why the audio is not playing in sporting stream but for the dev here is a log
http://www.mediafire.com/download/4uj43711am7cqax/xbmc.log
be a lot more help for the devs if you could post logs to your problems
foz
foz
About Navi-x conflict in skin import i have posted the fix here: http://www.vuplus-community.net/board/threads/navi-x-fix-for-beta2.20523/
About context menu and screenshots you can remap buttons editing this file:
Edit file /usr/share/xbmc/system/keymaps/keyboard.xml
Like for example i have mapped screenshots to mute button in this way :
<volume_mute>Screenshot</volume_mute>
  • Like
Reactions: foz
Regardless of some add-ons script errors I think the most important thing for vu to fix is internal player and sound. Some steams start to play using internal player (e.q. Some aac radio streams) but no sound at all. Mp3 steams open in enigma player but it is not so good. The same problem with videos. If started using internal player no sound and I think no hardware decoding, as hd plays to slow. But as a beta software it looks promising.
Dear all,
I'm trying to add iSTREAM and 1Channel but the download always is blocked around 80% in both of them, any solution please !!?? THX
In this xbmc beta version, in the openwebif interface there is no transcoding icon near the channel, only the streaming icon?
Can anyone post a guide on how to make this work??
1 channel is not downloading - it stops at 80% or hangs.
The tutorial posted is not exactly correct for this version.
A simple guide on whether to put it in flash or USB stick will make this much more accessible.
Me i installed the firmware, launched the plugin, installed Super Repo, tried 1 channel but not working.
Exactly same problem for me
