Black Hole Xbmc beta 02
PVR IPTV Simple Client installation finish with errors then it's disable...
When you want to Enable again you get the error on attached pic....
Plz check !!
1 Channel installation is hanging because of an error in the KODI - its looking for a youtube plugin 5.0.1 which is not the right query.
Also EXITING XBMC freezes the box and needs to be switched off.
Most of the plugins are hanging - some work but a lot don't.
S
Thank you very much for your work.
Is it possible to use a Russian keyboard layout in the virtual keyboard for the search?
Everything working perfectly now EVEN the EXIT - it seems it badly needed the YOUTUBE plugin - 1 Channel is back online and ICEFILMS works very well.
Well done.
Well done.
yeh...so does Genesis.....great
I was wondering if its possible to download and save movies as in Tsmedia.
I tried google(ing) for Xbmc and OpenGL.
I don't normally play games with my PC etc.
Can someone kindly explain the types and usefulness of the Xbmc and OpenGL animations.
Thanks.
HI, Thank you team for such great image.
Has anyone tried to install other skins than what in repo?
i.e MyMetrix? does it work for you?
thanks
M.
Hallo
Navi X 0.4.0 is working with sound.
Navi X 3.8.2 is not working (script error)
Popcornflix is working
Viewster is working
So far stable and no problems.
Hi Guys Happy New Year to every one
can you please help me how to map xbmc to my internal hdd please
i know i need to copy the xbmc in /media/hdd but i cant find xbmc folder
THnks
depends...
SYBU on ios and Yatse on droid are great app's for controlling Xbmc via tablets or phones
Logitech k400 keyboard is very good keyboard with built in mouse
although I have not tested any of the above as yet on my solo2 they work well with other Xbmc devices ive tested
but the apps are free from your os app store
you will need to set them up but very simple instructions are included
sorry not at home to test before posting this thought you may want to try asap
foz
THATS great love it perfect :D
Plz fixing issue Respond of Remote control
specially "exit" button Sometimes not respond, especially when repeating.
Also buttons switch channels sometimes be fast and sometimes do not respond especially when repeating.
with XBMC:
1. When iplay a movie from hdd it works OK. When i change the audio stream to the second one the image freeze. I switched back the audio stream the image is still freeze.
2. Playing movie from a NAS server it does NOT work. Image freeze to the previous one.
with and without XBMC running:
3. Webif does NOT work at all ( on both 8001 and 8002 ports).
Did someone encountered similar issues ? Can someone give more info ?
Hi all i just install this image and greek subtitles at videos dont work...
I was using UTF-8 encoding at 2.1.3 and greek subs worked fine.
I can do something now to fix with the this image?
