BlackHole Vu+ Duo 1.3.8 Multiboot
Yes it is simply.
- Substitute this file in /etc
- Reboot and you will have all that you need ;)
My skills are limited about this, I am not sure if i do it right.
I unpack with 7-zip the var.tar.gz on my computer and get a folder named var.
Then i ftp the var folder to /etc. now i restart.
After restart i create a symlink in /etc/var
example
Symlink is Target: usr/kess Name kess
But i can not get it to work.
example
No you have to copy var.tar.gz in to /etc folder
and restart image.
hi Team
the new realease is ok (ver off 5.4) and the latest driver is ok (11-11-2010) but
if i install this driver in latest BH image (1.3.8) it s not work
please look this problem .
hi Team
It's not a bug: new drivers have introduced more features that requires more updates in the code of image and it's software elements.
Please be patient for a new BH release with latest updates.
please do not get stressed, just out yesterday, do not pretend to have it too yesterday. everything comes patience, and remember that sometimes we forget, this is a hobby for many of us. all reached
Test this one i have find on net
you have to copy ipk file in to /tmp
Install>> green button>>yellow>>Manual Install Ipk packges
Restart imege and test.
I have find also new version Suomipoeka V 1.0.0
I think working with BH images and skins.
I install it Enigma2-plugin-extensions-suomipoeka-vuplus_0.9.6-r2_all.ipk, to work properly. Thanks a lot for you.
You are successful put new drivers in BH 1.3.8 ?! How if few colleagues confirmed that it not working in BH 1.3.8 ?
My advice is not to put this drivers in BH 138 because, as Angelofsky wrote, "new drivers have introduced more features that requires more updates in the code of image and it's software elements".
So it is better to wait for a new BH release with latest updates.
If I replace new drivers, image does not up at all.
regards
acer2
If you read my previous post and the remark of Tamaki you are advised that these new drivers introduce more features and the manual update procedure is not suggested.
The risk is to reflash the BH 1.3.8 image from USB stick becaus the image with latest drivers don't boot reguarly.
Please be patient: we are working for the updated image.
Thanks @angelofsky1980, but I did it earlier before @tamaki post, and only post my experience. I reflashed original 5.4 image ,just to see how funkcion it. Now I will wait new BH one.
regards
acer2
So,from Your message I can see that we can expect updated version of BH image tonight or tomorow :D
