BlackHole Vu+ Duo 1.3.8 Multiboot
You have test the same version you have in VTI image ???
Which version you tested ??
Im not using this plugin but i think we have problems with plugin version and skin coding
So pls info abt plugin version and skin you using in BH and Vti.
I have test with BlackShadow2 and the same plugin used in VTI image.
Hello!
Suomipoeka plugin version 0.96. I set it to your feed support (the green button) in BH. Plugin does not party and not from the image VTI.
Skin Blue Night2 - he just liked me:)
Thank you for your support and understanding
What is the advantage of installing MeoBoot on hdd? In my opinion it is not justified except for the quick installation, and for those, of course, that does not have a good usb stick to work with MeoBoot, but has the disadvantage of forcing the HDD to work whenever is started an image in multiboot installed in hdd. I'm wrong?
The advantage is the quick installation of images when there are not avaiable any USB stick compatible with Vu+ boxes. I have choosed to use HDD for that reason.
here the way to proceed for dummies
cd /media/hdd
mkdir MbootUpload
chmod 755 MbootUpload
cd /media/usb
rm MbootUpload
ln -s /media/hdd/MbootUpload MbootUpload
That is it
When i create a folder or symlink in /var, its gone every time after restart vu+.
Anyting to do about this?
Hi, I can also see a problem regarding recording on some channels on sat 28.2E. For example More 4+1. Seems ok but the filesize on disk is zero. You mentioned that there in an missing extra parameter for the channel. How do I confirm the error and how to solve it? I´ve had that problem on DEBH 1.33 also, but not on DM800 boxes only on Vu+duo. Any Ideas?
No one that have experienced the same "problem"?
Hello!
Test this one i have find on net
you have to copy ipk file in to /tmp
Install>> green button>>yellow>>Manual Install Ipk packges
Restart imege and test.
I have find also new version Suomipoeka V 1.0.0
I think working with BH images and skins.
