BlackHole Vu+ Duo 1.3.9 Multiboot
And there is no way to fix it. It is a pity, because it is one thing that most overused, especially the weekend. A greeting and thank you very much.
You can try to use Menu button within the media player .
There are more opportunities.
Example in Media Player > Menu button>>Edit settings>>Save last directory on exit.............yes
Tanx again big team.I have one problem with DD amir subtitle. After i installed it and reboot it worked fine but sometimes box goes to green screen again and again.
Salam.
Tested Vu Images as VTI, VIX and similar and work fine, but Barry allen is unstable in Vu so i like Meboot.
Do you mean you had BlackHole Vu+ Duo 1.3.9 Multiboot in internal flash memory and VTI, VIX in external usb stick using Barryallen. If this is true can you please tell me which version of barryallen you used. I tried Barryallen 5.1.44 but BlackHole Vu+ Duo 1.3.9 Multiboot did not
accept it.
Awaiting your reply.
Thanks
@unisat
You don't need barry allen for install vti and vix as multiboot in Blackhole 1.3.9.
Blackhole 1.3.9 already have multiboot function built in.
Hello, meoboot does not function properly!!
On the USB installed image no HD channel's find. (VTI,VIX,BlackHole1.3.8,...)
In v 1.3.8 no Problem's.
@unisat
Am aware that Blackhole 1.3.9 already have multiboot function built in. Am interested in BA.
The "problem" is the new Enigma2 structure and new VuPlus drivers who have gained the usage of standard DVB-API.
Use in Multiboot an image based on v5.4 original CVS and you can see HD channels in multiboot.
Tested personally yesterday evening :)
Hi,
Stream not work to computer with VLC Player or other player with BlackHole 1.3.9 and Orj 5.4 images. :(
Please...
Regards...
According to my tests, it is important for the file fast transfer and installation images
on USB
that after installing on the USB MeoBoot you make a complete
restart image. (turn box off/on )
The same goes for each new installation.
I have test install from older images PLI,VTi,Vix
all install OK .I have not test this images .
Would you please clarify for me the following:
1/ for faster file transfer and images installation when is the best time to complete
restart image. (turn box off/on ). Is it after installing Meoboot plugin on /media/usb, or after
installing the image in Meoboot Which is done automattically by Vu+.
2/ You mention that you have installed PLI successfully on Meoboot. Would you please specify which PLI image you used. I tried to install OpenPLi-beta-vuduo-20101115 images but kept on getting Green screens. The image installs well. Then when one installs the sats and channels and tries tozap channels it goes green screen.
Best regards
when i played a film on hdd
.mpg
after 1 minute vu + restarting !!!!!!!!!!!!
what is problem?
i havnt this problem in another images similar to dreamelite or vti ..
accept it.
Thanks
Salam
It works perfectly with Barryallen 5.1.17
