BlackHole Vu+ Duo 1.4.1 Multiboot
lorenzo64
BlackHole Vu+ Duo v. 1.4.1 Multiboot
ATTENZIONE A CAUSA DEI NUOVI DRIVER QUESTA IMMAGINE NON PUO' ESSERE INSTALLATA IN MULTIBOOT, DEVE ESSERE INSTALLATA IN FLASH
Specifiche:
Nuovi Drivers: 20101203
Nuovo Kernel BHApi patched 1.4.1
Nuovo Skin: Army Gradient
Aggiunto in System Info indicatore utilizzo della flash
Aggiunto nel Menù principale Blackhole EPG backup
Incluso DVD Player
Incluso MyTube
FIle changed to remove old DE references:
Delitecmd -> Blackholecmd
DelCamConf -> BhCamConf
CurrentDelCamName -> CurrentBhCamName
StartDelCam -> StartBhCam
Delextramod -> Bhextramod
delitemount -> Bhmount
.Deliteautoswap -> .Bhautoswap
/tmp/Deliteapi.socket -> /tmp/Bhapi.socket
Delclock -> Bhclock
DeliteAnalogic -> BhAnalogic
Kernel changes:
BlackHole-api.patch -> update version to 1.4.1
Kernel config additions for better drivers compatibility
CONFIG_IEEE80211=m
# CONFIG_IEEE80211_DEBUG is not set
CONFIG_IEEE80211_CRYPT_WEP=m
CONFIG_IEEE80211_CRYPT_CCMP=m
CONFIG_IEEE80211_CRYPT_TKIP=m
CONFIG_IEEE80211_SOFTMAC=m
# CONFIG_IEEE80211_SOFTMAC_DEBUG is not set
CONFIG_WIRELESS_EXT=y
CONFIG_CRYPTO=y
CONFIG_CRYPTO_HMAC=y
CONFIG_CRYPTO_NULL=m
CONFIG_CRYPTO_MD4=m
CONFIG_CRYPTO_MD5=m
CONFIG_CRYPTO_SHA1=m
CONFIG_CRYPTO_SHA256=m
CONFIG_CRYPTO_SHA512=m
CONFIG_CRYPTO_WP512=m
CONFIG_CRYPTO_TGR192=m
CONFIG_CRYPTO_DES=m
CONFIG_CRYPTO_BLOWFISH=m
CONFIG_CRYPTO_TWOFISH=m
CONFIG_CRYPTO_SERPENT=m
CONFIG_CRYPTO_AES=m
CONFIG_CRYPTO_CAST5=m
CONFIG_CRYPTO_CAST6=m
CONFIG_CRYPTO_TEA=m
CONFIG_CRYPTO_ARC4=m
CONFIG_CRYPTO_KHAZAD=m
CONFIG_CRYPTO_ANUBIS=m
CONFIG_CRYPTO_DEFLATE=m
CONFIG_CRYPTO_MICHAEL_MIC=m
CONFIG_CRYPTO_CRC32C=m
CONFIG_CRYPTO_TEST=m
CONFIG_CRC_CCITT=m
CONFIG_CRC16=m
CONFIG_CRC32=y
CONFIG_LIBCRC32C=m
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_PLIST=y
ATTENZIONE:
QUESTA IMMAGINE HA UN KERNEL PROPRIETARIO E NON PUO' ESSERE INSTALLATA IN MULTIBOOT SU IMMAGINI PRECEDENTI. QUESTA IMMAGINE VA INSTALLATA IN FLASH
Vi ricordiamo che la serie di immagini Black Hole dispongono del miglior sistema epg:
- Openepg integrato
- Nuovo sistema di epg.dat esterno.
Questa ultima caratteristica da la possibilità ai vari forum o comunità di crearsi i propri anchivi epg.dat e di caricarli in uno spazio web. I membri delle comunità potranno poi scaricarli dai propri server.
Questa caratteristica offre altri benefici quali:
Incremento della velocità di download degli EPG
Download degli EPG da qualsiasi canale
Schedulare i download degli EPG anche durante lo standby del decoder
Gli utenti possono personalizzare i Providers nell'EPG usando Aggiungi/Rimuovi
Funzioni principali dei tasti del telecomando
Tasto OK = Skin con informazioni semplici
Tasto OK x 2 volte = Skin con informazioni Extra
Tasto Blu = Black Hole Blue Panel
Tasto Blu e poi tasto Rosso = Black Hole Epg Panel
Tasto Blu e poi tasto Giallo = Pannello Monitoraggio Sistema
Tasto Blu premuto prolungatamente = Estensioni
Tasto Verde = Black Hole Green Panel
Tasto Verde premuto prolungatamente = Subservices
Tasto Verde e poi tasto Rosso = Fast Plugin Setup
Tasto Rosso = Avvia Registrazione
Tasto Giallo = Time Shift
Addons
Server dedicato per gli Addons
Scarica e installa pacchetti aggiuntivi dal server Black Hole
Infobar/OSD
Orologio Analogico Enigma2
Posizione orbilale del canale
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
Caratteristiche dei Pannelli BlackHole
Blue Panel
Extra Setting
Black Hole Cron Manager (gestore delle schedulazioni)
OSD Settings (configurazione OSD)
Kernel Modules Manager (gestore dei moduli del kernel)
Inadyn Settings (configurazione Inadyn)
Swap File Settings (configurazione File di Swap)
Hard Disk Settings (configurazione Disco Rigido)
Black Hole Mount Wizard (creazione guidata punti di mount)
OpenVPN Panel (pannello OpenVPN)
Samba/Cifs Panel (pannello Samba)
NFS Server Panel (pannello server NFS)
Telnet Panel (pannello Telnet)
FTP Panel (pannello FTP)
Usb Tuner Panel (pannello tuner usb)
Info
1 - E2 Setting (configurazioni Enigma2)
2 - Service Info (informazioni del Sistema)
3 - About (informazioni)
Memory (memoria)
Space (capacità)
CPU (processore)
Process (processi)
EPG Panel
Global setting (impostazioni Globali EPG)
Provider Setting (Impostazioni del provider)
Green Panel
Fast Plugin Setup (configurazione Plugin rapidi)
Fast Plugin (Elenco rapido Plugin)
Addons (aggiunte)
Addons Download Manager (gestore per lo scarico dei pacchetti)
Manual Install BH packages (installazione manuale dei pacchetti Black Hole)
Manual Install IPK packages (installazione manuale pacchetti IPK)
Addons Uninstall Panel (disinstallatore pacchetti)
Black Hole Statistics (statistiche Black Hole)
Scripts
Grazie al gruppo dei Beta Testers.
Grazie a Rytec che ci mette a disposizione il server con tutti gli archivi EPG.dat.
Riconoscimenti
Si ringrazia:
Rytec per l'epg esterno.
MaxZ4 per l'integrazione epg loader.
Llukkino (VDR-Italia) per il codice sorgente di opentv.
Reinh@rd per il file satellites.xml.
ATTENZIONE!
QUESTA IMMAGINE HA UN KERNEL PROPRIETARIO E VA INSTALLATA IN FLASH.
QUESTA IMMAGINE NON FUNZIONA IN MULTIBOOT CON ALTRE IMMAGINI IN FLASH. IL GRUPPO BLACKHOLE NON SUPPORTA IMMAGINI CHE NON SONO INSTALLATE IN FLASH
DISCLAIMER
L'IMMAGINE BLACK HOLE E' BASATA SUL FIRMWARE UFFICIALE VU+ E NEL RISPETTO DELLE LEGGI CONTIENE SOLO AGGIUNTE DI SISTEMA E MODIFICHE GRAFICHE.
L'IMMAGINE BLACK HOLE NON CONTIENE ALCUN EMULATORE NE' ALCUN ALTRO SISTEMA PER LA VISIONE DI PAY TV SENZA REGOLARE ABBONAMENTO O PER IL COSIDDETTO CARD-SHARING.
L'IMMAGINE BLACK HOLE NON CONTIENE INOLTRE ALCUN SISTEMA PER IL DOWNLOAD DA SERVER ESTERNI DI PLUGIN O SOFTWARES CHE POSSONO ESSERE USATI PER FINI NON LEGALI.
LICENZA (TERM OF USE)
L'IMMAGINE BLACK HOLE E' RILASCIATA PER IL LIBERO USO DA PARTE DI TUTTI GLI UTENTI A PATTO CHE NON VENGA MODIFICATA IN ALCUN MODO E CHE SIA USATA SOLO A FINI LECITI.
MODIFICHE O AGGIUNTE ALLA IMMAGINE BLACK HOLE CHE COMPORTINO UN QUALUNQUE USO NON LECITO DELLA STESSA, COME CARD-SHARING ED EMULATORI, SONO IN CONTRASTO CON LA PRESENTE LICENZA D'USO E COMPORTANO L'IMMEDIATA REVOCA DELLA STESSA.
QUI
Riformulo la domanda sperando di non infrangere il regolamento e la pazienza degli admin.......
Con la nuova immagine sono cambiatii nomi degli script.sh dell'immagine, oltre che dei comandi ...............cmd?
Se vuoi un consiglio, fai un backup della tua img attuale, provi questa nuova BH, se hai problemi puoi sempre tornare al backup fatto, ma sono sicuro che di problemi non ne avrai, è perfetta.
Non sono cambiati.
I cambiamenti occorsi sono quelli elencati nel thread di presentazione della 1.4.1 :)
Ocio che sei al limite del regolamento :)
Allora visto che sono molto interessato ai cambiamenti ai moduli nuovi e visto che mi servono quei moduli che avete messo nel config. Appunti gli ieee e alcuni crypto. Si possono scaricare da pannello?
edit: credo ci sia il pannello apposito. kiedo venia..
edit2: non ho trovato quello che cercavo :D, mi servono per i driver rtl.
posso chiedere di aggiungere alla prox versione il crossepg inserito nell'immagine?
grazie per il lavoro svolto;)
Abbiamo scelto di integrare l'epg nell'img, chi non è soddisfatto di questo si può mettere quello che preferisce, ma non potete pretendere che integriamo tutto nell'img per soddisfare le proprie esigenze. Vi rendete conto di cosa diventerebbe l'img?
abbi pazienza,la mia era una richiesta non una imposizione e perdipiù data dal fatto che avendolo testato lo considero la più completa e quindi pensavo fosse cosa gradita per tutti(avere il meglio penso piaccia a tutti);)
il tuo meglio non è detto che lo sia per tutti...io mi trovo meglio con quello di serie...molto probabilmente non sai sfruttare le sue potenzialità.....
se impari ad usare l'epg di serie...vedrai che non sentirai più il bisogno di cross;)......ciaoooooo
Non vedo l'ora di provarla. Una domanda, ma, per chi ha già installato i driver usciti qualche giorno fà, questa immagine quali migliorie apporta?
Grazie ancora a tutti gli sviluppatori :D
Se dai un'occhiata più approfondita al primo post, sono sicuro che qualcosa di interessante la troverai ;)
Si ho letto molte cose interessanti, quindi mi consigli comunque di installarla? Ad una prima veloce lettura avevo capito che in pratica implementava i nuovi driver usciti qualche giorno fà. ;)
volevo fare i complimenti per la nuova skin
do pienamente ragione a pessottino per quello che ti ha scritto subito sotto a questa tua affermazione, che quoto per rafforzare la teoria di pessottino, infatti ( a mio avviso ) non si era mai visto nulla di peggio della skin di base che è stata messa quindi ci vuole coraggio a complimentarsi, quindi tutti i gusti sono gusti, ho risolto scaricandomene un altra come tu puoi risolverti l'epg installandoti crossepg manualmente. buon divertimento
complimenti ai realizzatori per la bellissima immagine molto stabile
Penso che tu abbia già letto questo post.
