BlackHole Vu+ Duo 1.6.2 Final
Black Hole team = The best team :clap:
Black Hole image = The best image :clap:
Vuplus Community = The best online community :clap:
Thank you very much for your excellent and hard work ;)
thanks BlackHole team for the great work you do .
i have a question i can not get HDMI CEC work with my Samsung tv
the TV detect the VU+ as " tuner" but can't connect
does anyone tried Anynet+ in Samsung tv with the VU+?
I have the same issue with a Sony TV. It sees the Duo as "tuner 1" and I can send an "enable" signal to the Duo, but it doesn't appear to work.
some one else can confirm?
I think you have not readed the release post:
- Add Hdmi CEC (need the new Vu+ Universal Remote Control)
The new Vu+ Universal Remote Control have a dedicated button for TV - CEC at the top left corner (In this photo it is on the right but my RC of my Vu+ Uno have on the left).
i 'm not sur but i think it's not necessary if i want to control the Vu+ by the TV remote via HDMI CEC . not the contrary
thanks as well from me for this great image.
But i noticed a problem ending with green screen when i want to switch a radio channel previously chosen on the radio list. The OK button does not select the station and if push the exit button, the box reboots.
If a crash log is needed. let me know.
Skin used: Curve HD
Bye
spearkie
Uhmm maybe you are right.
Maybe the CEC support is experimental yet, i don't know.
I will ask to Vu+ developers.
Skin used: Curve HD
Bye
spearkie
Radio mode BUG (older skins )
I already wrote about it
In some skins from my friend Army there is a bug.
Change in System Menu >> Customize (Expert Setup Mode)
>>Alternative radio mode (yes) or use another skin.
