BlackHole Vu+ Duo 1.6.2 Final
Thanks for a great image.
I have just installed it, everything is working well, except for *****. I have tried to install several different versions of *****, but none of them show up in the menu.
When i use a CI module it works automatically with my Conax card, but I want to be able to use one of the existing card slots without having to use a CI.
What can i do to successfully install *****?
Post, qeustions and discussions about emu/card servers ARE FORBIDDEN on this Board.
Read RULES before posting !!!
What about the media player? I use 1.5.x BH image, but lot of divx and xvid are laggs. Can u fix this problem, or it is hardware problem?
I think you should install and test the last BlackHole image before to ask to fix any problem.
is there a way to modify the series of the menu items?
eg To be first the PERSONAL BACKUP is totally unuseful to me. i would prefer the SETUP first :)
Multiple posts for SAME problem is not a good idea. Make constructive discussion into your other thread opened.
I get frequent green screen memory and tmp file creation errors with 1.6.2....I have all plugins except glass uninstalled so hopefully the next release is more stable ( for me! )
Glass skin ???
Test clean image with our skins without plugins
and make report on stability.
But you test image with skins and plugins that cause instability
and there We can not help.
Even when you unistall such plugins and skins
They remain partly in image .
So install a clean image and make Test first .
Believe me I have never green screen not with this image version and not with
older image versions
but I do not use plugins and skins that have not been done by our team.
I use the EPG for 3 providers and the image works without problems
for months.I use only two plugins that I know are not with bugs.
I just love your image, its stunning! :thanks:
Just one BIG thing for me, I cant get the surround sound to my amp via Optical?
Tried just about all thinkable combinations of Final/Beta and PB images, settings different channels, media files etc. with no luck.:shocked:
Does this image not support Optical and only HDMI with Surround formats, cause there is absolutely no sounds coming through to the receiver when I chose Optical? :confused:
If this does not work I will cry tears and go back to my previous image that did support surround through optical. :cry:
Forget all about the above bullocks about sound, it works like a charm!
I am not sure why I could not get it to work, maybe loose connection in my head or some wire. But it works now, so now I can enjoy this super image as well :clap:
it is realy great image i love it , but the problem is i cant find *******. can some one please help me
thanks
thanks
This Team don't support any kind of softcams or similar.
Use Google for this kind of requests. Read Board rules before posting in future.
I have a Dual-Band Wireless-N USB Network Adapter LINKSYS (( WUSB600N )) , But I can not install it on my vu+duo and I can't connect it with other device.
please help me!!!
THANKS
