BlackHole Vu+ Duo v. 1.4.4 MediaTomb Server
FRiends you realy like BH team and Bh image in 4 hours you download this image 245 times.
Like you see in this image is MEDIATOMB ; please test and report ............
@Docctore; i think with this old skin on this new version image you no will be see MEDIATOMB changed make in skin to good work this image.Beter way is wait for Army update gradient skin and downalod from feeds
MEDIATOMB........
@bogdanm,
Me and am sure others need more info regarding this media serves!
A tutorial , in how2use and what Equipments,wep site ,,,,,Etc, It would be much appreciated!
Please tolerate me am a newbee,,,to this world of multimedia!
Thanx in BH Team for all the enjoyment U give 2users!
Rgdz
a911
MEDIATOMB........:confused:!
All the info you need is in the first post. Mediatomb=server, DJ client.
Mediatomb is new for most of us
Therefore, test and tell personal experiences and configuration
The Internet has a lot of information .
Rgd MX
@bogdanm,
Rgdz
a911
From first post, just do like this, it easier to do than to explain :)
About Mediatomb:​
You can use Mediatomb for Upnp server on your box and then connect all other boxes with Upnp client. In this way you will have the files of server available on your clients in folder /media/upnp. You will have available in MediaPlayer YOUR MEDIA files.​
You don't need to configure router or other things.​
Mediatomb include a webinterface too to manage your media.​
If you want to play with Mediaplayer configs you can find docs and howto: http://mediatomb.cc​
Location of config file: /.mediatomb/config.xml​
For users with a PS3 I have Mediatomb set up on my Vu + Duo as UPnP Server and supported files such as avi work perfectly as long as you have enabled upnp on your PS3. You now have some extra storage space.
For who want to use mediatomb with PSP3 you can extend funcitions.
Look at this line in /.mediatomb/config.xml
and change it:
<protocolInfo extend="no"/><!-- For PS3 support change to "yes" -->
I do miss to see status of UPnP in "System Info" (Blue-Yellow)
It seems that Media Tomb server eats a lot of memory.
System Info shows "Ram in use 98%" after a plain install.
Stopping Media Tomb it then shows "Ram in use 66%"
Enable button in UPnP server panel should be green and disable should be red.
Neutrino keymap Black Hole 1.4.4E
KEY_OK = open Service List
KEY_UP = zap Down
KEY_DOWN = zap Up
KEY_EXIT = Infobar
2x KEY_EXIT = Full Infobar
Subservice (Sky Germany) KEY_GREEN
KEY_RIGHT = next Subservice
KEY_LEFT = prev Subservice
Copy to usr/share/enigma2 and Hard reset or swich OFF/ON VU+duo
Roko
and change it:
To be able to see this folder with totalcommander and FTP you have to enable in Net (on top of the totalcommander window)
FTP show hidden files
Hmm, it did go down to 71%, it may be using more in starting than running
or something else start :idea:
Samba using 2 to 3 X more mem than enabled server and Client.
But if you use client only samba uses 6x more memory
If you use UPnP disable SAMBA.
