BlackHole Vu+ Duo v. 1.4.4 MediaTomb Server
love this image , mediatomb running but unable to access webif
500 Internal Server Error
I must be missing something here
Can I use the default skin in BH 1.4.3 in this new version? If so, where can I find this skin?
Otherwise, great new release... :)
Regards,
BTJ
Why can't i get mediatomb to work? I can't find the xlm file, and i'm using Total comander, and have show hiden file on..
I have activate mediatomb on the boks. But can't find anything
USB: 07D1:3C09 D-Link System DWA-140 RangeBooster N Adapter(rev.B1) [Ralink RT2870] have tried to plug it in but i does not recognise the dwa-140 and it is rev.b1
is there something i have to aktivate first ?
By the way the best image = the best team :)
Could you please post the output of
cat /proc/bus/usb/devices
and
dmesg
when you plug your device?
Thanks!
It looks nice but, I have 1 question :)
Can I stream a satTV channel straight to my PS3 with mediatomb or another plugin?
Thanks for the nice work BlackHole rocks on my Vu+
I have many problems playing avi's in the latest versions and not only 1.4.4. I mean some avi's are playing ok but many dont. The strange thing is that BH 1.4.1 plays all the avi's i try and i am trying to understand what is the difference as matter lib or whatever between the 1.4.1 and all the versions after.
Imagine that i had updated the module drivers in 1.4.1 to the latest for test and still the avi's can play there fine.
Anyone has any info on this?
I have the same avi files on my HDD in Vu and on w7 pc and they still work perfectly.
Do you have your files on internal HDD or via streaming ?
Also do they play ok on another source such as pc or ps3 ?
Sure m8 the files play fine.. they are in internal HD and maybe you didnt saw what i said.. the files play fine in till BH1.4.1 after this till the latest 1.4.4 they dont. Offcourse the pc also plays the files fine. I compromised with the solution to play this non playable files with VLC but i really dont get why this is huppening really.
I suspect there is a lib or something else that i have it in 1.4.1 and this dont exist in 1.4.4
Either way i suppose is not biggy and i w8 and check every new version to see if this is fixed and till now i revert back to 1.4.1 but im not giving up :) i hope.
