BlackHole Vu+ Duo v. 1.4.4 MediaTomb Server
If the Config.xml has changed for Playstation. With SONY Bravia the server is to be seen (Widget unter Serverlist ), however, not accessible ( no connect ). Can I try something else?
I changed encoding srt into UTF-8 but don't work yet, when I try to start subtitle (that is in same mkv file folder with same name) on subtitle button, subtitle don't appear.
I don't know what I'm doing wrong or what's missing.
I have a similar "problem".
When I active subtitles (srt format) via Audio button -> Yellow button, the subtitle appear after 5 seconds and works correctly.
I can suggest to wait a minute (as maximum time) to see if subtitles are correctly loaded and viewed.
Thanks. I did that before and now too more than a minute but srt subtitles don't appear, I don't know what's happening.
Thank you very much angelofsky1980 for your excellent work on BH images.
@ biscamax
i tried the tvmobili on my pc,,,and activated djmount on box.
in mediaplayer i find the folder i added to my content.
but theres no files showing in box??
i have alot of movies in the folder when i check the pc.
can you help out.
thx
@ biscamax
can you help out.
thx
Yes certainly. Did you add your movie folder on tvmibili? If not, you have to add your folder doing this:" tvmobili/settings/new directoy/browse you folder", then the folder will appears in "tvmobili/settings/my folders".
You must open the internal port (that one tvmobili requires) in your firewall too.
do i have to register tvmobili to get it to work??
No, you don't need register to work.
Go to VuPlus main menu/media player/DLNA/tvmobili-(your pc name)/my content/videos/movies/then you chose the first letter of your file name(all media files that you have in the folder must be there)/green/>. That's it.
thx must bee something with my router,,,gonna check it out more closely.
thx for your help. m8
You could control if tvmobili on your pc can see any files in the folders in my caontent, if you don't there must be something wrong in your forder, try to remove that folder from my content and add again those folders.
solved it ,,,it was the firewall in win 7 x64 that caused the trouble
now all is working fine and what a great thing,,,now i dont have to upload to my hdd in box anymore.
A Big
to all involved (Tamaki and biscamax)
How to set to display radio name on VFD in radio mode? I tried different skin (default, HD Glass 16, etc) but there is no solution.
What type of media do you have on your HDD ? TS files are not seen on the ps3 but avi and mkv are ok.
