BlackHole Vu+ Duo v. 1.5 Multituner
I've had also two hybrid DVB-C / T Sticks with low pricing of ~ 50€.
- Terratec Cinergy HTC Stick HD
- Win TV HVR 930 C HD
Both worked great on PC Software DVBViewer.
At the mment the two devices are not supported by Linux.
I will publish a list of current supported DVB-C devices.
You can find a first list of USB DVB-C devices please look HERE.
Congratulations..great work guys...our favourite receiver would be less attractive without your images..well done!
A question...are there other improvements in 1.5 compared to 1.4.6?
I mean..I am not interested (for now..who knows..!!) in having two Dvb-T tuners, so I am wondering if this change is to be done for other reasons.
Thanks a lot, and again, I appreciate your work!
The mayor implementation is upgrade of all DVB USB drivers and the new DVB USB Panel to use one or two USB sticks.
Thank you for the excellent work - Black Hole 1.5 Multituner! But I have a problem with the USB tuner DVB-T AF9015. Often it happens that when I toggle channels on DVB-T AF9015 after switching to a black screen and I only reboot helps tuner VU + DUO.Czy to blame drivers for DVB-T USB AF9015? When can we expect that the DVB-T USB AF9015 will work properly? Please, solve this problem.
Please don't double post on the board.
Thanks Rassi, what do you mean exactly by "didn't get to work directly"? :) Doesn't work at all or you eventually got it working?
Cheers
Cheers
It means, i didn't get those work at all same time :)
First loaded drivers for AF9015 and after that sundtek, but i didnt get Tuner D to Tuner setup. There was only AF9015 stick.
Maybe sundtek try ue same vtuner/frontend/what ever than other stick?
Im not linux guru at all, so i didnt test any special tricks.
Thanks, this was my initial fear and I guess I was right :) Can you try to install the Sundtek drivers first and then the AF90015, sorry for using you as a guinea pig.
Cheers
Hi, I have a feeling skin donwload is not doing a thing.... at least that's what's happening to me. Is that right?
I am stuck with Army Curve HD (nice one indeed, I was just curious about the others)
Tnx
Tnx
Hi DD's,
The image server is ok ,,,all/any skin can be downloaded,,,,and then go 2...:-
menu>setup>>system>>>skin,,,a list will show and then select what U looking for,,OK,,,E2 will start ,,,,now U have the a new skin to enjoy!
If this process does not work for U,,,,then check the net connection,,,,:confused:!
Have fun W/BH
At the moment I haven't studied the Sundteck driver packaging.
Could you please report the official link where I can download the drivers?
For Tevii S660 I will make some modifications on the avaiable package on the BH server because is too generic and don'w work at first install attempt.
I have the same device only from 1 day :) Please be patient a little :)
Hey angelofsky1980,
Did you get a chance to look at the Sundtek drivers I gave you the link to? I would love to get a tevii S660 as my 4th tuner but as I understand this will not be possible with the current Sundtek drivers.
Thanks for your help as always.
