BlackHole Vu+ Solo 1.6.6
Hello.
Image Crashes (Green Screen) on MyTube, every time when I am trying to open video with Greek text description.
I had same problem with 1.6.5.(Same video plays fine with webmedia plugin.)
I have many month to use MyTube so i can not know when this started to happen.
I had no problems when i played videos with Greek Text using MyTube before.
Uploading Crash.log
REGARDS.
Hello.
Uploading Crash.log
REGARDS.
As usual YouTube change something on his site. Your error is:
ValueError: invalid literal for int() with base 10: '22,itag=84&url=http%3A%2F%2Fo-o.preferred.ontelecoms-ath1.v15.lscache6.c.youtube.com%2Fvideoplayback%3Fsparams%3Did%252Cexpire%252Cip%252Cipbits%252Citag%252Csource%252Cratebypass%252Ccp%26fexp%3D9029'
The Bh 1.6.6 is great.
But I think the memory management was changed! Now with my configuration (plugins: weather+livefootbal...) : Vusolo +BH1.6.6 I have 94% RAM in use it means I have only 6Mo of free memory. With the same configuration (I use the BhpersonnalBackup to restore my config) in the BH 1.6.5, I have more than 16Mo free memory.
Could you please explain the changes in memory usage in BH1.6.6 and how can I have more free memory: I want free memory to use epg for 1 week.
New I disable the EPG feature beacause it crashes a lot (with error: now memory available...)
Thanks in advance and thanks for good work...
Rihanna5 SKIN DEFAULT UPDATE V2 ON IMAGE SERVER
Rihanna5 skin default v 2 ONLY FOR BH 1.6.6 (Black Hole E2)
FIX DVD Player
NEW Web Browser Panel
NEW CeC Panel
Any possibility to choose another skyn insthead this default? Rihanna5 is not working with 130x80 picon...
I tried to install Rihanna8, enigma restarted but remains always Rihanna5.
Thanks
Thanks
sorry, i found it.. in the main menu, configuration, system and then skyn.. thanks :idea:
