BlackHole Vu+ Solo 1.6.6
How did you erased them?
Which language do you need?
I was experimented with translation and accidentally erase all Languages from receiver
(click delete instead of copy), when I was trying to make backup to my PC.
Thank you Tamaki, but I have solved my issue.
Regards.
I think the Solo Bootloader upgrade should solve the bug for large images.
Performances of the box are already good I think.
i have just checked in vu plus web page...
New CFE Image for Vu+ Solo
The CFE image of Vu+ Solo is updated.
The main difference from the old one is supporting the large size image more than 48MB.
Please see the detailed explanation of update as below.
Babbo Natale has just arrived :D
I do not want to open a new thread, that's why i decided to post in this one my inquiries!
I am forcing a problem with the record process on an external HDD...
Although i have installed and mounted (confirmed 100%) 1 USB stick (picons-swap-epg) and 1 external HDD (record) on a USB powered hub and all are working fine (record-timeshift-media player) on my HDD, it seems that somehow Solo losts the connection with it...
The recording paths and the mount root are at the same place, the media player works fine with the recorded stuff in there BUT the HDD can not record and timeshift after it gets in stanby...
I tried to set not to be in standby via Solo's menu but with no success...
The HDD still gets in stanby and losts the communication with Solo...
It needs a new initialize and mount in order to be working again...
I also tried with a new HDD (WD Passport) and the problem does not exist...
Is there any way to make that HDD not to be lost the communication with Solo whenever it gets in stanby? (I recognize the sound of stanby because i am hearing the HDD to start spinning)
