BlackHole Vu+ Ultimo 1.6.7 kernel 3.1.1 beta2
lorenzo64
New drivers 16 dec 2011
Dvbapp update 16 dec 2011
Many Usb Dtt and wifi drivers added
Update driver
Improve recording performance(reduce load)
adjust bmem in uno and ultimo
fix duo cmdline
add firmware for wlan and dvb modules.
fix bug : hdd initialization.
New Vuplus plugin [crashreport]
Note, you can use Bh PersonalBackup between previous beta and this image.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Black Hole Mount Wizard (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-1.6.7-vuultimo_usb.zip
angelofsky1980
BlackHole Driver Specialist
this new update doesn't boot.. stucks with the first blackhole image...and nothing happens..
Dear user,
to help you we need the serial output when the box startup and load image from flash.
You need a nullmodem serial cable, a terminal emulation program like Hypterminal or Minicom. Setup serial port as 115200,8,n,1, connect and report here text output.
rocuelo
i have no idea how to do it....
the thing is that i went back to the beta 1 and the ultimo works.... is just a problem of the beta 2....i will wait when is something new or maybe tomorrow i will try again.....
many thanks..
angelofsky1980
many thanks..
If you have a problem who the Coder (who HAS the box) has not detected, I think you should do all the possible thing to solve the problem.
About serial console, it's too simple and other people who haven't used it before, has reported all the output requested.
You need:
1. nullmodem cable
2. Hypterterminal (Windows) / Minicom (Linux)
Procedure:
1. connect the serial cable between PC and box
2. start communication program (Hypterterminal / Minicom)
3. start a new connection on serial port (connection parameters: 115200, 8, n, 1)
4. turn ON box
If all it's done correctly you should see on the PC display a lot of text: this is the text we need.
Post it, please.
rocuelo
good news mate.. i done all the process again and works.. now..i have the beta 2 now on my ultimo...
thanks mate.. to help me..
rocuelo
hi again.. i normally never write much here, i just read and learn..but after i changes from duo to ultimo, i need it to check with you guys some questions...
i have not idea the reason , but a lost signal in some channels from astra and hotbird.. in astra like pro7 hd, sat1 hd, sixx hd and some other like sky cinema (sky italia) or hbo hd on (cyfra+) hotbird....the question is thats happening from turner B (astra-hotbird) because on my turner A (MOTOR) i have signal..what i notice is that i have low signal in most of the astra and hotbird channels that before with my duo, when i changed on friday...
some other guys have the same problem or have notice less signals, just asking because where are still in beta image.. or maybe wil be my dish after a windy two day long.
angelofsky1980
It's not an image issue.
Follow instructions on post #5 of this thread to report infos about your box. Without infos it's IMPOSSIBLE to help you correctly.
Update:
you have not read Board rules. Another post like your who talk about some TV providers who is impossible to view on other box than the ones given by TV Operator and you are OUT.
hija31
It is not an image feature, it is a SKIN fetaure.
WHen BH skinners will have ultimo they will make skins for it.
May be some one can help on where to put this on "skin_user.xml"
-<screen id="1" size="132,64" position="0,0" name="InfoBarSummary"> -<widget size="132,64" position="0,15" path="picon_oled" render="Picon" source="session.CurrentService"> <convert type="ServiceName">Reference</convert> </widget> </screen>
B.th.w. Great image as always.
Thanks to the BlackHole team
Bruty
Report what wifi device you are using and a dmesg output.
wifi usb dongle vu+ and AP is HTC TD2.WLAN see ok at menu,scan AP found HTC,but not connect...Key at HTC and wlan is same....This issue have too VIX 2.3 released yestarday...
Other security like WPA and WPA2 can not test,HTC support only WEP at wifi router app.
angelofsky1980
I haven't tested WEP on boxes... I have already used WPA or WPA2 ... I suggest to change your router/AP. Wep is very bad encryption for wireless networks.
I will recover my old Netgear router and I will make some tests with it ....
Ev0
Admin
I too had a few issue's getting wifi dongle working propperly.
Spent a couple of hours messing with both BH and VIX images.
Eventually it all worked fine (using wpa2 btw) and the problem seems to be with nameserver setting.
However after it was all working fine, for some reason I noticed my ultimo was using alot of bandwidth via wifi, so I have now disconnected it and used lan instead (faster, more stable and less bandwidth used).
