BlackHole Vu+ Ultimo 1.6.7 kernel 3.1.1 beta2
I too had a few issue's getting wifi dongle working propperly.
Spent a couple of hours messing with both BH and VIX images.
Eventually it all worked fine (using wpa2 btw) and the problem seems to be with nameserver setting.
However after it was all working fine, for some reason I noticed my ultimo was using alot of bandwidth via wifi, so I have now disconnected it and used lan instead (faster, more stable and less bandwidth used).
Ok.
May be some one can help on where to put this on "skin_user.xml"
-<screen id="1" size="132,64" position="0,0" name="InfoBarSummary"> -<widget size="132,64" position="0,15" path="picon_oled" render="Picon" source="session.CurrentService"> <convert type="ServiceName">Reference</convert> </widget> </screen>
B.th.w. Great image as always.
Thanks to the BlackHole team
Did you manage to get picons working on the VFD?
