BlackHole Vu+ Uno 1.6.6
Thanks to the VU+ Team for this new image, very goog job.
About HDMI_CEC : The box is connected to the HDMI 3 of an Onkyo amplifier and goes to the HDMI 1 of a SONY EX500. Is it possible to have a good HDMI_CEC in this case?
The box connected directly to the TV works fine with HDMI_CEC.
About RemoteControlCode, if we save config., we have the green panel and a reboot.
What is this plugin for exctly?
Thanks for WEBBrowser.
Is it a wireless keyboard and mouse that you recommend?
About plugin MediaScanner.
Impossible to see something in any drive with this plugin. "no files displayable....
Regards
You can scan only files (media files) in root /
example :
/media/usb/file.jpg
or
/hdd/file.jpg
e.t.c
Here we have probably BUG in CVS not in our coding and skin.
But in CVS skin coding.
I'll put FIX in the next update for Rihanna5.
FIX:
Copy icons folder from my ZIP in to
/usr/share/enigma2/Vu_HD/
Now you can USE plugin to setup remote
If you like to control VU UNO with remote for VU duo
use code 1.
FIX:
use code 1.
FIX is on our image server (skins download)
Rihanna5 skin default v3 SKIN UPDATE ONLY FOR BH 1.6.6 (Black Hole E2)
FIX for DVD player BUG,FIX for RemoteControlCode plugin BUG, added new panels for CEC and Web Browser
After update restart image .
RemoteControlCode plugin codes
code 1 Remote VUduo
code 2 Remote VUuno
Thanks, Remote OK.
About HDMI_CEC, can someone explain how to configure it.
Current CEC address : 1.3.0.0 and we can fix it.
But it is a fixed adress, no change possible.
Is it UNO address ??
Regards
Thanks, Remote OK.
Regards
You can not manually change the address of CEC
CEC address is obtained automatically based on the System in which there is a CEC device/devices
CEC devices have both physical and logical addresses. Normally, upon each hot-plug, each CEC source obtains a physical address by reading the EDID of the sink it is attached to. The physical address of each CEC device is expressed as four numbers and indicates
where it is relative to the “root” display, whose address is always fixed at 0.0.0.0.
example, a source attached to input #1 of the “root” display, will have a physical address
of 1.0.0.0 Each CEC device also obtains a logical address - reflecting its product type - by negotiating with other CEC devices in the system.
For better understanding we can partly compare with
assigning IP addresses automatically and fixed.
But here we can not assign own address
but we can only fix address
if we not change our system TV,VU,Audio amp,etc
But in the case of configuration changes, we must again
release automatically assign addresses.
It is therefore necessary to search for VU in TV HDMI setup
If he is not automatically detected.
Sometimes you need to repeat the process
turning off and on VU and agn configuration of HDMI TV setup.
Wakeup signal can be different for different TVs
Therefore it is necessary to find appropriate in the BH Hdmi CeC Setup
(Wakeup signal from TV ................. ????)
Thx alot for the image guyz,
Is ist possible to include a "backup image" script for Uno as well ?
Works perfect with Duo an Solo , why is it so dificult to complile the same script for UNO ?
"Black Hole Personal backup " crashes with Rihanna 5 as well.
The green crashlogg appears when it comes to plugin transfer .
Have tried another skin " Smoke Pro HD" , the same happens with that skin
It is not a skin problem, but surely your device problem.
Check if there is enough free space or if device is properly mounted.
Where did you set to seve backup?
thx for all but i hve a probleme with the vertuel keyboard it doesnt work in the web browser pluging; l have an vuplus uno; very thx and i excuse for my bad english
sorry .i use the new image bh 1.6.6 PLEASE I NEED A SOLUTION AND THX FOR THE GREAT TEAM BLACKHOLE
CAN USE MULTIBOOT WITH VUPLUS UNO IN THE NEXT IMAGE? I HOPE THAT AND IT S VERY EASY FOR THE GREAT TEAM BLACKHOLE VERY THX
SORRY NOW NO PROBLEM With WEBBROSER BECAUSE I UPDATE SKIN IN ADDON DOWNLOAD MANAGER RIHANNA 5 DEFAULT UPDATE V3 BH1.6.6 THX
I tried to use virtual keyboard with vu+uno and it works fine, are you sure you are using right bottons?
Bofore running web browser try to have a look to botton functions.
For info.
Skin update has nothing to do with the web browser
and virtual keyboard .
The reason for your problem was elsewhere.
Perhaps you used the image in the Multiboot or similar
or a wrong use of the web browser.
For info.
thx, first i use vuplus uno i think that no multiboot or similaire for this box second i talks about vertuel keyboard including in the webbroser wirking when pushing the yellow button in remote controle , after updating skin it's work well. in the new vti image 2,3 webbroser and all the others plugings work best, for blackhole ihope that well be good in the next image for vuplus uno thx
