BlackHole Vu+ Uno 1.6.6
thx, first i use vuplus uno i think that no multiboot or similaire for this box second i talks about vertuel keyboard including in the webbroser wirking when pushing the yellow button in remote controle , after updating skin it's work well. in the new vti image 2,3 webbroser and all the others plugings work best, for blackhole ihope that well be good in the next image for vuplus uno thx
Web browser have already worked in image,
with no update of the skin.
both VU Uno and DUO.I have personally tested.
Of course we have test the image before publication.
The only bug that I know was a DVD player
and skin update is related to it.
Rgd MX
Rgd MX
Very thx for your all good job and efforts . And what about vuplus uno and multiboot? thx
About FPGA Upgrade : Where can we find the version number after the install ?
About WebBrowser : How to change something in the setup for an azerty keyboard ?
Is it possible to change the mouse speed (very slow) ?
Is it possible to connect to a Cam WebIf (127.0.0.1 and port number don't work) ?
Regards,
Regards,
About 1st question: we have asked on vu+ directly the same thing and we wait an answer.
For last question: i think yes, but talk about cam is forbidden in this board
About WebInterface :
If we active the http authentification, we need a password. What is it the default password on Uno BlackHole Image ?
I try "root", blank but doesn't work.
I think you must setup a password to use the authentication into webif.
Please make a telnet connection to your box and use "passwd" program to setup a password for user "root".
After this operation you can use SSH instead of telnet and (I think) you can use the webif authentication.
I put a password to test "vuuno".
http authentification to yes.
Now no login (no password) and no problem to connect to the webinterface --> Strange
Hi. how can I config remote control to work with my TV?
Is there any TV list?
Thanks for your great efforts and powerful image.
How can I use my logitec wireless keyboard & mouse for web interface? I can't find any driver for this device.
I use a logitech k260 wireless keyboard and mouse and it is no necessary to have drivers. It works without drivers.
Hello,
Just a quick Q, is the FPGA upgrade (TS PRO.dat) the same as the one thats dated Aug ? or is this a newer version ?
TTfn:)
G
I replace the password "vuuno" by a blank password "" and it is possible to log with "root" and a blank in the pass. Now it works.
FIX for DVD player
YOU Can also download updated skin from Image server
replace skin.xml file in /usr/share/enigma2 with skin.xml from ZIP
I'm sure is a silly question but what is the image server and how I can install this fix (or the v2 for the rihanna5 skin) from that server.
I have installed the file through ftp and is working fine. bue I would like to know how to do it in a more stylish way ;-)
Thanks.
Thanks.
Image server is our server where you can directly download skins and more for our image.
Green button >> Yellow >> Addons Download Manager >>Black Hole Image skins >> Rihann5 Skin Default Update
Hi lorenzo64 and all the Vu+ community team. Thanks for your great work!
Could I ask you how to record subtitles with this image? I tried, but it seems it can only record multiple audio streams :(
thanks,
a19a
