Blue sea ,Black sea,DarkBlue sea,Red sea ...
Very nice skins.:)
Tested today MX Black Sea (for BH 3.0.6 and up ver) on a vu + solo2 running BH 3.0.6.
Really missing birateviewer that works with BH 3.0.6 .
Plugin downloaded from Black Hole Feeds plugins.
Only audio is working and video shows only 0 kbit/s.
Some option to fix bitrateviewer so it works with streams on this skin and otherwise on default skin as well.
But if i use tv channel from satellite, the video kbit/s also works.
Think this is incorrect, this should only work for streamtv ???
Very nice skins.:)
These skins have nothing to do with Bitrateviwer.
It's all about plugin and driver issues.
And problem you have is I think is only with Zero 4K.
I would ask you to report only problems and possible bugs related to the skins
MX DarkBlue Sea I
The OSD is the same as the MX DarkBlue Sea
but many panels with icons
download from Black Hole image server
skin coding support plugins
E2Iplayer (IPTV Player)
Enhanced Movie Center
Weather Plugin
Lcd4Linux
SeriesPlugin
Filebrowser
MenuSort
IMDb
For those who missed it because of problems with the web site
We have three or four versions of skins for BH and OBH image.
Which I personally like very much.
Skin use the most advanced coding for now
Try...You can download from the image download panel.
I had to add another version to this skins collection.
Download from image panel and BH server.
MX BlackSea I
version with panel icons .
Weather Plugin
Lcd4Linux
SeriesPlugin
Filebrowser
MenuSort
IMDb
Im using picons from @halus61
size 220 x 132
You can download from BH/OBH servers from image download panels.
MX Red Sea
skin format 1920 x 1080
picon format 220x132
skin you can download from Black Hole image server
skin support addos/plugins
Enhaced Movie Center (EMC)
Weather Plugin
LCD4Linux
SeriesPlugin
Filebrowser
MenuSort
MX Red Sea I (for BH 3.0.6 and up ver)
same as MX Red Sea but with icons in the panels
Weather Plugin
LCD4Linux
SeriesPlugin
Filebrowser
MenuSort
